Old Thu, Apr-13-2017, 04:55:03 PM   #1
cpandrewschmidt
cpandrewschmidt's Avatar
Reputation: 0 cpandrewschmidt is on a distinguished road
Default rich condition and fuel pressure help
Hi all,
I have a 98 M3 with a Eurosport supercharger recently acquired and I have been doing maintenance. I'm chasing the P1108, 1109 CELs. Done just about everything in the book I can think of, vacuum leaks, new o2 sensors, ICV cleaning, vanos kit, valve cover, fuel filter, CCV, clean MAF. I'm running rich with fuel trims of LTFT -8.6% and STFT -20% ish at 2500 RPM.
I checked fuel pressure. With ignition on car not running I get 41 psi with FPR vacuum line plugged in. However, its pressure starts to drop off quickly. Like 30 psi within a minute. With car running FRP vacuum line in I'm at 41 psi and 51 psi with it off. So, I believe that's OK. Appears FPR is working then? So, I think injectors might be leaking. Unplugged injectors, turned on fuel pump watched injectors, no leaking.....but pressure still drops. So, car runs steady at 51 psi with FRP unplugged, 41 psi with it plugged in. When I start the pump FPR plugged in (not starting the car) the gauge instantly goes to 51, but immediately drops to 41 psi then pressure bleeds off somewhat quickly.
I started the car and turned it all the way off and pressure holds, doesn't drop off. That tells me it doesn't appear to be siphoning back when car is off, I've never had a hard start problem so it's not a check valve. Pressure only drops when key is in AUX position. When I pinched the fuel lines at the back of the rail the pressure on the gauge would go up and down, doubt that means anything.
So, still maybe a partially functioning FPR if there's such a thing? Hate to throw $90 at one not truly knowing. Or maybe it is tune related, but this problem didn't exist when i first got the car. I'm out of ideas. I took to a shop who could dig deeper with their code reader and he claimed if it weren't for the supercharger the car is running within BMW stock specs. He claimed it's probably the tune. I checked with TRM tuning who did the car and they said their specs would have the fuel trims targeted at 0%. So, I still think it's mechanically related.
Thanks for any tips you might have!
Andrew
98 M3 Eurosport SC sedan
Jump to top cpandrewschmidt is offline   Reply With Quote
Old Thu, Apr-13-2017, 06:20:17 PM   #2
NolliM3
NolliM3's Avatar
Default Re: rich condition and fuel pressure help
It seems that you're caught in he says she says. Your fuel pressure although acceptable seems a little weak...should be closer to 50psi. Mechanically related...well, you're still guessing. What size injectors you have...do you smell gas when you pop the hood? How did you determine that you're running rich? Is your FPR stock? Do you have a computer with INPA and the interface to put on the diagnostic port.
Old Thu, Apr-13-2017, 06:45:32 PM   #3
cpandrewschmidt
I believe the injectors are the 36 lb that supposedly come with the kit, they would only have 20k miles on them when the kit was installed:
http://www.eurosporthighperformance....ercharger.html
The FPR looks pretty old, so I assume it's stock. I have a scan tool to read live data and that's how i got my STFT and LTFT readings, which indicate the rich condition.
I thought 51 psi (3.5 bar) with vacuum line off FPR is where pressure is supposed to be, at least that's where it is with car running.
Unfortunately don't have INPA but could probably download it. Is there version or link out there recommended? My brother just bought a cable to code his 135i so I can probably use that.
Old Thu, Apr-13-2017, 10:07:02 PM   #4
NolliM3
NolliM3's Avatar
So, I take it you didn't smell gas...I would take the fuel pressure right after the filter or before the FPR...also if you can get some data while you're driving that would clarify the tune is ok if all the vacuum line looks good (non dry rotting). The fuel pressure does take a while to return to normal when the car turned off (couple hours)...you'll find that out whenever you ever change the filter...you should get 51psi just on the fuel line.
Honestly, it does sound like your tune which data would confirm.
Discussing rich condition and fuel pressure help in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
