Old Wed, Apr-12-2017, 07:45:29 PM   #1
JoaiM3
2005 BMW ///M3 ZCP
JoaiM3's Avatar
Reputation: 0 JoaiM3 is on a distinguished road
Default Connecting Supersprint V1 stepped headers to euro cats
Anyone know if there's an adapter to connect the larger diameter tubing of the V1 stepped headers to the stock euro cats? Need this to pass sniffer in CA. Currently have supersprint high-flow cats in section 1 which show my post O2 sensors in 'not ready' status on OBDII.
Another issue would be the visual which I've been told that many places don't bother checking. Any insight on this?
Really trying not to revert my entire system back to stock but I may have to as my very last option.
Thanks.
2005 BMW ///M3 ZCP
Jump to top JoaiM3 is offline   Reply With Quote
Old Wed, Apr-12-2017, 07:56:35 PM   #2
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
Default Re: Connecting Supersprint V1 stepped headers to euro cats
There is no adapter to attach the V1s to a standard section 1. You would have to have some fabrication done to make it work. If your post cat O2s are in 'not ready', that is the first thing you need to change. You can have them ready, with any cats or no cats. That all depends on the tune.
I had heard, that CA stopped doing sniffer tests on OBDII cars, similar to other states. If this is true, all you need to do is change your tune to pass the OBDII test. You will still fail visual every time, if they check.
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, SSV1 Headers/CPI slip fit catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
Jump to top cozmo kraemer is offline   Reply With Quote
Old Wed, Apr-12-2017, 08:01:58 PM   #3
Subbed as one day I'd like to go to SSv1 from my Euros and I have euro sect 1 as well. I've seen another standard sized sect 1 here on the forum with new, larger ends welded on to mate up with SSv1s, I think one of the vendors was selling it.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop AP Headers Euro cat sect 1 Dinan sect 3 BMW Motorsport 4.10 Besian D/A pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Wed, Apr-12-2017, 08:28:50 PM   #4
JoaiM3
2005 BMW ///M3 ZCP
JoaiM3's Avatar
You're right, no sniffer test in CA.
So the tune dictates the readiness of the O2 sensors. This would be ideal if I don't need to change any hardware. Looks like I need to shop around for a tune. Thanks.
2005 BMW ///M3 ZCP
Old Wed, Apr-12-2017, 09:59:31 PM   #5
aaronpoweruser
Reputation: 0 aaronpoweruser is on a distinguished road
You don't need a tune, you can use this tool to set the post cat o2 sensors to ready http://www.m3forum.net/m3forum/showthread.php?t=508807 . I still highly recommend you get a tune anyway it will help to balance out your AFRs the ssv1's really throw them off, so you may be running lean.
Jump to top aaronpoweruser is offline   Reply With Quote
Old Thu, Apr-13-2017, 12:13:42 AM   #6
Kalahari
Reputation: 0 Kalahari is on a distinguished road
Very interested to see if someone has done the V1 + Euro cats combo and how much fab work was required. This sounds like an ideal set up if it isn't too difficult/pricey.
Jump to top Kalahari is offline   Reply With Quote
Old Thu, Apr-13-2017, 12:56:23 AM   #7
If you want to use the OE cats, I'd suggest using the V2 stepped headers-- that's what they're designed for, I would think you'll get a better result and less effort.
Old Thu, Apr-13-2017, 01:26:03 AM   #8
But what's the hp/tq diff between v1 and v2 Ian? If it's significant enough, then why would someone bother going from euro or other catless header to SS v2 right?
Old Thu, Apr-13-2017, 01:34:08 AM   #9
Yeah, but some of that is because of the larger diameter section 1. Necking it down is going to at least partially negate that difference.
The SSV2s still make more power than the OE Euro headers. Just not as much more as the V1s.
Old Thu, Apr-20-2017, 04:43:13 PM   #10
TheGenius46M
TheGenius46M's Avatar
Looking to do this as well when I purchase V1s. I have a spare oem section 1 and would like to find some adapters that are the appropriate OD. Does anyone know the correct OD for OEM section 1 and the OD for SS V1 stepped?
2003 E46 M3 TiAg/Cinnamon 6MT
MCS | Recaro | OMP | Hyperco | Besian | AKG | UUC | Rogue | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Status Gruppe |
Discussing Connecting Supersprint V1 stepped headers to euro cats in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
