Old Mon, Apr-10-2017, 03:10:38 AM   #21
EricSMG
40 something
Default Re: Pilot Super Sport - awful tread wear ?
That's a great question and I'm perplexed as well. Perhaps the winters are a much harder compound and so slower wearing.
I just know that when I used to run .20ish toe per side I chewed through summer rears like crazy. Halving that solved this for me. Your camber is perfect.
Old Mon, Apr-10-2017, 03:54:04 AM   #22
JTM09
I like cats
JTM09's Avatar
Reputation: 0 JTM09 is on a distinguished road
So you think I should try to run 0.10 toe? The specified range on the spec sheet is 0.13-0.23.
2017 YMB/GB ZCP 6MT
2006 IR/Blk ZCP 6MT-sold
2006 AW/Cinn (slick top) 6MT-sold
2002 TiAg/Grey 6MT-sold
Jump to top JTM09 is offline   Reply With Quote
Old Mon, Apr-10-2017, 04:02:16 AM   #23
rovert604
rovert604's Avatar
Haha my Blizzak LM60 winters got chewed through. But my PSS are fine. I add camber to the PSS and then flattened it out for winters. I wonder how squirrely the back gets with near zero negative toe?
--Trevor in 604--
Vancouver, BC, Canada
Old Mon, Apr-10-2017, 04:06:29 AM   #24
bimmerfan08
bimmerfan08's Avatar
For comparison, I run a moderate amount of camber for both F&R (-2.5 and -1.5) but right around 0 degree total toe. Two sets of PSS tires on my M3 have lasted between 25k-30k miles. Then again I'm on a square setup so I also rotate tires periodically.
Old Mon, Apr-10-2017, 03:31:34 PM   #25
Monte0704
Monte0704's Avatar
Reputation: 0 Monte0704 is on a distinguished road
Michelin gives a 30k miles warranty only for square setups. For a staggered setup it's 15k miles.
2004 E46 M3 SMG II | 1990 Nissan Skyline GTR
Jump to top Monte0704 is offline   Reply With Quote
Old Mon, Apr-10-2017, 03:55:24 PM   #26
Biohazard29
Biohazard29's Avatar
Reputation: 0 Biohazard29 is on a distinguished road
Good luck with warranty, their 30k claim is only for non staggered fitments with proof of proper rotation.
Like others check the RTAB, all you need are limiters on each side to correct the issue
Walking isn't a lost art - one must, by some means, get to the garage.
Jump to top Biohazard29 is offline   Reply With Quote
Old Mon, Apr-10-2017, 05:23:53 PM   #27
JTM09
I like cats
JTM09's Avatar
If my rtabs were bad wouldn't my winters wear badly too?
My buddy that works at the BMW dealer says he sees 8k max out of pilot sports. The roads here must be particularly harsh on them.
If I can get a discount set via warranty I may just sell them and switch brands.
2017 YMB/GB ZCP 6MT
Old Mon, Apr-10-2017, 07:54:42 PM   #28
Monte0704
Monte0704's Avatar
Not sure what you're going to find that grips like a super sport with better wear.
Pilot Sport 4S is the replacement for the super sport though. Supposed to wear better.
Old Mon, Apr-10-2017, 08:02:21 PM   #29
JTM09
I like cats
JTM09's Avatar
Honestly, for as hard as I don't drive the car I guess I don't need all this grip, if it means I need tires ever year.
2017 YMB/GB ZCP 6MT
Old Mon, Apr-10-2017, 09:20:12 PM   #30
EricSMG
40 something
Yes, ~.10-.13 toe in per side, rear.
Discussing Pilot Super Sport - awful tread wear ? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
