Old Sun, Apr-09-2017, 06:36:52 PM   #11
JTM09
I like cats
JTM09's Avatar
Reputation: 0 JTM09 is on a distinguished road
Default Re: Pilot Super Sport - awful tread wear ?
Pulled Blizzak rears - still 8/32 left. 2 winters , probably 5-6k miles on them. Even wear.
I think I got a bad lot of super sports. Hopefully they stand behind them - warranty etc.
The wear looks even. I'll have to find the spec sheet but it's within factory spec from what I recall.
2017 YMB/GB ZCP 6MT
2006 IR/Blk ZCP 6MT-sold
2006 AW/Cinn (slick top) 6MT-sold
2002 TiAg/Grey 6MT-sold
Jump to top JTM09 is offline   Reply With Quote
Old Sun, Apr-09-2017, 07:07:04 PM   #12
BTB
BTB's Avatar
I kinda doubt there would be a defect in the rubber compound... are you sure your suspension is in good condition? Did you get the fronts and rears at the same time?
My Journal
Old Sun, Apr-09-2017, 08:25:41 PM   #13
LINDW4LL
LINDW4LL's Avatar
Reputation: 0 LINDW4LL is on a distinguished road
That's some crazy wear. I got 22k from my last set of rears and am at around 32k on the fronts.
2003 ///M3
| Stahlgrau | FABSPEED Headers | AR20 | Section 2 EVC | Turner Motorsport Sway Bars | Pilot Sport 4S | Porterfield R4-S | OE LED Tails | M-Track Mode |
Jump to top LINDW4LL is online now   Reply With Quote
Old Sun, Apr-09-2017, 08:35:48 PM   #14
JTM09
I like cats
JTM09's Avatar
Yep, fronts and rears installed @same time.
I agree it's crazy. But since my winter tires are wearing fine - I have no other idea what it could be.
2017 YMB/GB ZCP 6MT
Old Sun, Apr-09-2017, 09:06:56 PM   #15
EricSMG
40 something
It's gotta be toe. What're your toe settings?
Old Sun, Apr-09-2017, 10:00:48 PM   #16
BTB
BTB's Avatar
hmm.. that is weird that your fronts are wearing almost as fast as the rears it seems...
Are you sure there was a full 10 or 11 or whatever 32ths of depth when they were new?
My Journal
Old Sun, Apr-09-2017, 10:55:07 PM   #17
JTM09
I like cats
JTM09's Avatar
0.20 degree was the recorded rear toe
Range is 0.13 -0.23 per the spec sheet
I bought them from a local dealer and they sure looked new.
2017 YMB/GB ZCP 6MT
Old Mon, Apr-10-2017, 12:51:23 AM   #18
EricSMG
40 something
That's per side,,yes? Run half that and your tires will last longer with great handling.
What's your rear camber?
Old Mon, Apr-10-2017, 12:57:54 AM   #19
Cha5en
Reputation: 0 Cha5en is on a distinguished road
This.
Toe is what ruins tires, from an alignment cause of course.
Just a FYI, these tires degrade quickly at the track/lots of spirited driving. Great for street tires, though, just don't hold up well under heat cycles.
Jump to top Cha5en is offline   Reply With Quote
Old Mon, Apr-10-2017, 02:01:53 AM   #20
JTM09
I like cats
JTM09's Avatar
I believe the camber was aprox -1.8 .
The odd thing is that I ran a set of 19" Nitto tires with these same alignment specs for a summer ..(5k miles?) with no noticeable change in tire wear.
The Nitto tires came with the car (unknown install date) ..and when I took them off 10k miles later (5k of those miles post alignment) they still had 1/2 life left.
If it is the toe .. why are my winter tires not wearing so quickly?
2017 YMB/GB ZCP 6MT
Discussing Pilot Super Sport - awful tread wear ? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
