Old Sun, Apr-09-2017, 12:35:38 AM   #1
jbse39
Reputation: 0 jbse39 is on a distinguished road
Default Reverse light wire?
I've retrofitted auto-dimming rearview mirror with compass and UGDO, and got everything to work, including clown nose. I added reverse light wire to the wiring harness and just need to locate the reverse light wire and tap it.
I've read that it is located in the cables that go through driver's side footwell area and it is blue/yellow, but it is a mess of wires in there and I am having a bit of hard time. Anyone know of easier access to reverse light wire in the cabin?
Thanks.
Jump to top jbse39 is offline   Reply With Quote
Old Sun, Apr-09-2017, 01:02:31 AM   #2
fiveightandten
fiveightandten's Avatar
Default Re: Reverse light wire?
It is blue/yellow. It's a pain in the ass to trace into the cabin. I didn't bother. Here's a writeup.
http://www.m3forum.net/m3forum/showthread.php?t=417417
-Nick
Old Sun, Apr-09-2017, 12:23:34 PM   #3
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
I don't know if it's easier, but maybe try directly from the gearbox reverse gear switch.
Make sure you calibrate the compass to show the correct rhumb.
I also need to trace the wire, but my source is the factory wire to dimming mirror. I'm going to have the radio auto mute when the PDC is on = reverse gear seclected.
Old Sun, Apr-09-2017, 12:58:43 PM   #4
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
I just checked the ETM, don't know if same for US, but the reverse wire in the EU ETM is easily available in junction box (comb connectors) behind the glovebox.
So just take a new spade connector and stick into the comb. No splicing/cutting necessary, which I never do.
Old Sun, Apr-09-2017, 10:25:30 PM   #5
jbse39
Good to know, I wish I had known, since I just took the glove box out to replace cabin air filter!
Thanks!
John
Discussing Reverse light wire? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
