Old Sun, Apr-02-2017, 12:58:21 AM   #1
tikamak
Reputation: 0 tikamak is on a distinguished road
Default 4 clutch machineless unsprung LSD
Hi guys, anyone got a review on the 4 clutch machineless unsprung LSD kit from thayer motorsports ?
Im looking for some information like maintenance intervals, street driveability, performance and locking pattern ....
Id happy to hear from actual owners who daily it.
Jump to top tikamak is offline   Reply With Quote
Old Wed, Apr-12-2017, 02:33:10 PM   #2
tikamak
Default Re: 4 clutch machineless unsprung LSD
bump, anyone?
Old Wed, Apr-12-2017, 04:39:18 PM   #3
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Interested as well.
Are these kits for the clutch pack unit in our car or is a specific one needed?
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable/TCKline Camber Plates/TMS Adjustable Rear Control Arm/Powerflex Black RTABs/Turner Delrin FCABS/ Brembo GT 6 pot F 4 Pot R/OEM CSL Trunk/ SGT 1 piece lip
Jump to top Sandeep1212 is online now   Reply With Quote
Old Wed, Apr-12-2017, 06:09:11 PM   #4
tikamak
Originally Posted by Sandeep1212 View Post
Interested as well.
specific one needed, E39 M5 TYP210 LSD, it's a ZF unit with 2 clutches.
you can install this 4 clutch upgrade in it.
also e34, 750, 735, 535, etc ... have the same ZF unit
Old Sat, Apr-15-2017, 04:16:24 AM   #5
ColinGreene
Archer
Reputation: 0 ColinGreene is on a distinguished road
id just buy a OS giken diff/
Jump to top ColinGreene is offline   Reply With Quote
Old Sat, Apr-15-2017, 04:59:47 AM   #6
bigjae1976
I was thinking about going the same route. An older diff with the ZF unit will run $250 at a minimum. Then clutch discs, parts, etc...you're getting close to an OS Giken or a ZF conversion from Diffsonline or Jim Blanton.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sat, Apr-15-2017, 05:13:24 AM   #7
tikamak
Explain to me how you got to 3K ?
The clutch disks are like 550$ for 4 of them.
Yourr around 1k in parts ...
Old Sat, Apr-15-2017, 10:20:12 AM   #8
Feffman
Grand Poobah
Feffman's Avatar
Reputation: 0 Feffman is on a distinguished road
You may want to consider the Autotech Driveline Clubsport limited slip (below:
http://www.autotechdriveline.com/clubsport_diffs.htm
or if you want to go all in, consider the Drexler limited slip. I love mine.
http://www.autotechdriveline.com/drexler.htm
Feff
MVP Track Time
Jump to top Feffman is offline   Reply With Quote
Old Sat, Apr-15-2017, 11:12:45 AM   #9
bigjae1976
$3k...probably not but you'll have to DIY everything. You'll need bearings, shims (not cheap), bolts, M12/M14 adaptors, and lots of other little parts. Then you'll need access to a press or buy one. Plus other specialty tools.
It will be an easy $1500. L
Old Sat, Apr-15-2017, 02:07:47 PM   #10
tikamak
Yes 1500 is a more realistic estimation.
If you use the stock motorsport gears 3.64 u dont need the shims and you get all the parts u need from thayer motorsports
Pretty easy mod and easy on the wallet as well
Discussing 4 clutch machineless unsprung LSD in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
