Old Wed, Mar-29-2017, 12:56:53 AM   #1
tripitz
Reputation: 0 tripitz is on a distinguished road
Default Cleaning intake openings on head?
My S52 has been on an engine stand for a while. While I stuffed the intake openings with "lint free" towels and covered the engine, I am worried that some dust/dirt will find it's way into the intake openings. What is the best way to clean the openings out prior to installing the manifold? Use a shop vac to suck any loose debris out?
Jump to top tripitz is offline   Reply With Quote
Old Wed, Mar-29-2017, 06:04:07 PM   #2
englishtom1596q
englishtom1596q's Avatar
Default Re: Cleaning intake openings on head?
Vacuuming it out is probably your best bet. You can try blowing it out with shop air if the valve is closed but you may risk pushing dirt down further around the valve
Old Wed, Mar-29-2017, 08:10:01 PM   #3
tykluss18
tykluss18's Avatar
Reputation: 0 tykluss18 is on a distinguished road
Moisten and use your lips to create a sealed surface around the port and then inhale rapidly.
...but really, don't worry unless there is foreign material in there. The paper towel lint, dust, dirt etc will combust and evacuate as soon as you start the engine. I see no issue, even if it was left uncovered. The paper towel trick is so you don't drop anything like nuts into the ports during dis/reassembly, not to keep dust out.
1997 M3 Coupe, 102k Miles, 5 speed, Cosmosschwarz Metallic, UUC Evo 3 SSK, DSSR & ZHP Shift Knob, Original Staggered M Contours, Original Spare Tire, Factory Heckspoiler, Bridgestone Potenza RE760 Sports, De-restricted airbox, AFE Dry Pro S drop-in filter, Stromüng Cat-back Exhaust
WANT TO BUY
Factory E36 In-Car Phone Kit, Factory OEM Gas Cap with Decals Intact, Factory-Working Re-Chargable Flashlight, New Driver's M3 Floor Mat, European Oil Pressure Gauge, ZKW front headlight set, "City Lights" Relay, 1990's Westlake Rusnak Original License Plate Frame
(Instagram)
Long Live Cannonball Baker
Jump to top tykluss18 is offline   Reply With Quote
Old Wed, Mar-29-2017, 08:35:41 PM   #4
propchef
Toodle-oo Motherf**kers
propchef's Avatar
Reputation: 0 propchef is on a distinguished road
^^Biggest sig ever
Originally Posted by AllwaysLow View Post
x2 and some Chicago style pizza
Originally Posted by M3Dom View Post
He's suffered enough.
Jump to top propchef is online now   Reply With Quote
Old Fri, Mar-31-2017, 03:01:23 AM   #5
tykluss18
tykluss18's Avatar
Originally Posted by propchef View Post
^^Biggest sig ever
Tried to use every allotted character
WANT TO BUY
(Instagram)
Old Wed, Apr-12-2017, 08:16:01 PM   #6
PurpleM3Pursuit
E36 on the way out... E92 on the way in..
PurpleM3Pursuit's Avatar
Reputation: 578 PurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond repute
Like some of the others have said, the lint will burn right off.. You are merely preventing a large particle from entering. To clean off the ports, I used a aluminum safe degreaser and a towel and carefully (but aggressively) cleaned off the residual oil and sludge so the ports were nice and clean. You aren't going to be able to hurt it much unless you are going in there with a screw driver and scraping out material.
Alex... or PM3P... being a good Leader for YOU!
E92 M3 AW/BL Competition
BMWCCA# 368302
Also in the fleet:
'75 Porsche 911 Carrera
'85 Chevrolet Camaro Z28
'87 Porsche 951
'95 BMW 325i GTS2/JP
'15 F150 EB SCrew
Jump to top PurpleM3Pursuit is offline   Reply With Quote
Discussing Cleaning intake openings on head? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
