Old Tue, Mar-28-2017, 09:58:07 PM   #31
Steve M3
Default Re: S65 Swap into E86 (Similar to E46)
In for updates, great project!
Jump to top Steve M3 is online now   Reply With Quote
Old Wed, Mar-29-2017, 02:10:34 AM   #32
ApolloTheGod
ApolloTheGod's Avatar
Reputation: 0 ApolloTheGod is on a distinguished road
UPDATE
I picked up my heads from the machine shop earlier. They were amazed at how straight the heads were. No warpage. Even 02 could not shimmy under anything. Once I got the heads home I sealed them up for storage until my bottom end is done. I've decided I'm pulling the trigger on a 4.8L stroker for this block. Exciting times! I'm still in negotiation with VAC on some of the finer details of the bottom end build. Hopefully I'll get this sent off for getting sleeved and assembled soon. I'll be waiting for my stroker kit first though.
The heads still may look a little dirty in some areas but it's just loose debris sealed in by the oil that was put on the head to keep dust and dirt off. A simple wipe will carry it all away.
2007 Black Sapphire Metallic + Imola Z4 ///M Coupe
S65B40A Swap, DCT, Apex ARC-8, GC Coilovers, H&R Sways, 996 BBK, Straight Pipes, Underdrive Pulley, Tune, aFe Intake
2011 Space Gray + Fox Red ///M3 Coupe
ESS VT2-650 SC, Bilstein PSS10 Coilovers, AP Racing BBK, Recaro Seats, Carbon Fiber Roof, GTS DCT Tune
Jump to top ApolloTheGod is offline   Reply With Quote
Old Sat, Apr-08-2017, 09:51:16 AM   #33
ApolloTheGod
UPDATE
Alright kids, here's the deal. I know you don't want to see this project fall to the way side and take months. My stroker kit is being manufactured, block getting machined and sleeved, and still working out my SCer system, but I don't want to leave you all without updates for MONTHS while I wait for the motor build to finish and then drop it in the car. Instead, I decided today I would go buy an S65 that is already assembled so I can get it in the car and get you guys some cool burn out videos! I'll have the S54 out of the car this weekend and by next weekend I'll have the S65 running in the car with any luck.
If any of you guys want the old S54 let me know. The bottom end will need a rebuild but the rest is fine. Transmission can go as well.
In addition to grabbing the new motor I did a little more work on some of my parts for the motor builds. I'll grab more pics soon.
Old Sat, Apr-08-2017, 10:55:33 AM   #34
liam821
Reputation: 0 liam821 is on a distinguished road
Instead of the nightmare which will be putting all the BMW electronics into the car to make the DCT gearbox and s65 work, have you thought about using a Syvecs ECU? It's a full standalone ecu that can control the DCT gearbox, s65, boost, vanos etc etc.
They even make an s65 "plug and play" kit.
http://www.syvecs.co.uk/products/eng...d-e92-m3-kits/
No idea on price, probably isn't cheap, but it would make your project significantly easier.
e93 M3 Melbourne Red on Black Novillo leather
e46 M3 ZCP Interlagos Blue on Black M-cloth Imola Red
e73 xDrive35d Platinum Gray Metallic on Cinnamon
Jump to top liam821 is offline   Reply With Quote
Old Sat, Apr-08-2017, 11:08:47 AM   #35
ApolloTheGod
I actually have done a lot more research on this but did not throw it in this update, I will next. I will be going with the Syvecs 6Plus ECU actually and it's only a few grand new which is not bad at all for this level of standalone. It will make this swap more plug and play
Old Sat, Apr-08-2017, 07:39:04 PM   #36
twentyseven
@itsmejonnyv
twentyseven's Avatar
Kinda digging the TypeR vibe of the red cylinder heads!
Thanks for the updates
'04 Jet Black + Cinnamon ///M3 coupe
V-CSL, BBS CH, Öhlins R&T, Supersprint, custom Z4M seats, CSL SMG tune
Jump to top twentyseven is online now   Reply With Quote
Old Sat, Apr-08-2017, 08:01:26 PM   #37
bimmerfan08
bimmerfan08's Avatar
When you finally get around to dropping the S65 in, can you do a step by step process so that it's easy to follow and repeat? Thanks
Old Sat, Apr-08-2017, 10:14:18 PM   #38
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
Will be we expecting another detailed DIY?
AKG||Euro Headers||Tilton Twin Disk Clutch||RTD||Mishimoto||Customized Bimmerworld Race Exhaust||Kirk Rollbar||Schroth||Sparco||Momo||OMP||Ground Control||Eibach||JRZ RSpro (rear coilover)||PFC Z31 BBK||Enkei NT03||Maxxis RC-1
Trackspec Autosports
MMI Vehicle Systems
Ravenol
IG: MD__M3
Jump to top mdavidm3 is online now   Reply With Quote
Old Sat, Apr-08-2017, 10:20:17 PM   #39
bimmerfan08
I'm not sure what else at this point I can contribute as my M3 is in great mechanical order at this moment in time. Maybe down the line when I have to do the clutch and clean the TBs, I'll throw together some more DIYs. Or if I ever get a chance to do an engine rebuild...
Old Sun, Apr-09-2017, 07:47:27 AM   #40
ApolloTheGod
I'll be posting all my R&D for everyone here to benefit from. I'll post pics later but it is late and I'm tired. The S54 is pretty much out of the car except for a couple bolts. I decided to call it a night. Tomorrow I'll be fitting up the S65 and I'll hope to have mounts made up by Tuesday and I'll get my driveshaft together by Friday. The plan is to have the car going up and down the street in two weeks. Wish me luck guys
Discussing S65 Swap into E86 (Similar to E46) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
