Old Tue, Mar-28-2017, 05:49:24 AM   #21
T-Rex
Reputation: 0 T-Rex is on a distinguished road
Default Re: S65 Swap into E86 (Similar to E46)
Definitely can't wait to see this thing in action. The more S65 swaps, the better!
Jump to top T-Rex is offline   Reply With Quote
Old Tue, Mar-28-2017, 05:28:01 PM   #22
Sebaflex
Sebaflex's Avatar
Reputation: 0 Sebaflex is on a distinguished road
oh my... *subscribed*
- Seb
Jump to top Sebaflex is online now   Reply With Quote
Old Tue, Mar-28-2017, 06:02:29 PM   #23
Exciting!
Subscribed as well
Old Tue, Mar-28-2017, 06:10:42 PM   #24
Swapping in an S65 is actually an incredibly intelligent move for this chassis. It's lighter than the S54, performs better than the S54, and distributes weight better. It leaves more room in the engine bay for many additions.
The s65 short block (bottom end only) is lighter than the s54 short block. The S65 long block (fully dressed, top end and bottom end) is heavier than the S54 long block. BMW's advertising claim that the s65 was lighter, back when the e9XM was new, was based on comparing the weight of the short blocks-- technically accurate, but very misleading.
http://www.m3post.com/forums/showthread.php?t=953141
He weights them both, on the same scale, in the process of moving his e30 from being s54 powered to s65 powered.
That said, the shorter length of the s65 should mean that weight distribution isn't changed that much.
Old Tue, Mar-28-2017, 06:39:36 PM   #25
ApolloTheGod
ApolloTheGod's Avatar
Reputation: 0 ApolloTheGod is on a distinguished road
If you strip off all the ancillaries then it's still a lighter running engine. A racecar does not need AC, PS, etc
2007 Black Sapphire Metallic + Imola Z4 ///M Coupe
S65B40A Swap, DCT, Apex ARC-8, GC Coilovers, H&R Sways, 996 BBK, Straight Pipes, Underdrive Pulley, Tune, aFe Intake
2011 Space Gray + Fox Red ///M3 Coupe
ESS VT2-650 SC, Bilstein PSS10 Coilovers, AP Racing BBK, Recaro Seats, Carbon Fiber Roof, GTS DCT Tune
Jump to top ApolloTheGod is offline   Reply With Quote
Old Tue, Mar-28-2017, 06:50:41 PM   #26
You should weight them to compare! More data points are always better .
When the e30 builder I linked above compared them both in his form of race trim (both free of AC, etc), his s54/trans was 120 lbs lighter than his s65/trans.
(though his s54 was running the e36 5mt, which is ~25 lbs lighter than the 6mt that comes in the e46 M3, and presumably the s65's 6mt is heavier still since it has more power to cope with)
Old Tue, Mar-28-2017, 07:15:22 PM   #27
Just looked, because I was curious.
According to BMW,
S65 with no ancillaries: 158 kg
S54 with no ancillaries: 148.5 kg
Old Tue, Mar-28-2017, 07:27:18 PM   #28
ApolloTheGod
According to BMW,
It would seem I stand corrected. I appreciate you letting me know about this "clerical error" BMW seemed to perpetuate. What a shame. I will certainly weigh everything as it comes off from the S54 and I'll weigh everything that goes back in with the S65. We can finally have some numbers down.
My plan right now is still to go with the DCT which I can already tell from picking it up is MUCH heavier than any BMW 6 speed made.
Old Tue, Mar-28-2017, 07:51:04 PM   #29
youinreverse
Reputation: 0 youinreverse is on a distinguished road
Subscribed. This is going to be awesome!
Jump to top youinreverse is online now   Reply With Quote
Old Tue, Mar-28-2017, 09:46:06 PM   #30
driller
your hole is our goal
driller's Avatar
Reputation: 0 driller is on a distinguished road
Wow
Awesome build
Thanks for posting
Looking forward to finished project
Sent from my SM-G870W using Tapatalk
Jump to top driller is offline   Reply With Quote
Discussing S65 Swap into E86 (Similar to E46) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
