Old Wed, Mar-22-2017, 04:53:42 PM   #21
Bimmerman325i
Beardface McMountainMan
Bimmerman325i's Avatar
Default Re: Gauge pod & gauges
I have Stack Pro-Control Oil Temp and Water Temp gauges with the Rallyroad pod. I wanted analog (but still digital) gauges with a wide sweep area for easy value and rate-of-change readability on track. I'd like an oil pressure gauge but was more concerned with temps. These have both a data logger output and can be programmed to change gauge face color above certain temperature thresholds, and flash super annoyingly to alert you that it's too damn hot.
I wired the light circuit into an oem hifi switch so that I can turn the (bright) backlight off when desired.
Turns out the Z3M cluster water temp is unbuffered, so....didn't need that one. At least now I know what the temp swings are! Ignore the SES light, that's for a ornery SAP.
1998 BMW M3/4/5 -- DD rev1
Old Wed, Mar-22-2017, 05:55:49 PM   #22
Originally Posted by mpwrcpe View Post
Backwards how?
That would be classic as Rally Road assembled them before they shipped it lol.
Thanks, now I'm going to go OCD on it as I never really paid any attention.
Edit: You're right Brett it's backwards lol. Oh well it's not coming out now.
Old Wed, Mar-22-2017, 08:03:15 PM   #23
BlackHawkRacing
Reputation: 0 BlackHawkRacing is on a distinguished road
Innovate MTX-D gauges in the RR dual ear pod. They are programmable as well. I have since rotated both gauges down a bit but the setup is great and highly visible. Oil pressure & temp on the left, water temp and battery voltage on the right.
I'll be installing that exact gauge/pod setup in a few weeks; what wires did you tap for power and ground?
Jump to top BlackHawkRacing is offline   Reply With Quote
Old Wed, Mar-22-2017, 08:16:30 PM   #24
mpwrcpe
The Throbbing Gristle
Reputation: 0 mpwrcpe is on a distinguished road
I ran a switched/fused power lead from the X20 plug when I did the S54 swap harness that was specifically for the gauges. Ground was pulled from the chassis grounding block on the drivers side, under the kick panel. Sensor/sending unit wires were all pulled through the fuse box.
///'95 Avus M3 S54B32 - Stripped, caged @ 2681#
///'90 Calypso 325ic (70K miles)
///'72 Chamonix 2002 (Restoration project)
///'87 Alpine 535is
'15 Touareg TDI (Race car hauler)
Jump to top mpwrcpe is offline   Reply With Quote
Old Wed, Mar-22-2017, 08:43:27 PM   #25
JitteryJoe
Hey, thank you both for the pictures. Those are great. I'm going to go ahead and order the RR pods. Just have to decide which gauge set. They both look good.
Jump to top JitteryJoe is online now   Reply With Quote
Old Wed, Mar-22-2017, 08:44:48 PM   #26
BlackHawkRacing
Thanks for the quick response, I have a follow up to that but don't want to get the thread OT so I'll shoot you a PM
Old Wed, Mar-22-2017, 09:54:50 PM   #27
I ran AEM gauges with mine.
http://www.m3forum.net/m3forum/showp...&postcount=154
Old Wed, Mar-22-2017, 11:44:23 PM   #28
englishtom1596q
englishtom1596q's Avatar
i've quite liked the Prosport gauges. Anyone every tried them?
Old Thu, Mar-23-2017, 03:37:25 AM   #29
PITT M3 RR
PA
PITT M3 RR's Avatar
Is the A pillar not an option?
Got it on eBay, $34 to my door and heat molded it to my a pillar.
Will have oil press / temp and WB02 prob
S54 E36 BUILD
Old Thu, Mar-23-2017, 12:18:41 PM   #30
I have been running the standard grade pro sport for years in coolant and oil temp and think they are fine. Not Stack, but not nearly as expensive.
Discussing Gauge pod & gauges in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
