Old Sat, Mar-04-2017, 11:22:44 PM   #1
Jazzkat
Reputation: 0 Jazzkat is on a distinguished road
Default Floor mats - Velcro vs Through Post Style
A while back Ian had commented that he changed out the Velcro pad style floor mats in his (new from Kevin) M3 wagon as the mats were not staying in place. If I remember correctly, he sourced the old tried and true through post style mats and floor anchors.
I was having the same issue in my M. No grip between the floor pads and the back of the mat.
Recently put a new set of mats in my wife's 7. Noticed that the new Velcro pads gripped the mat very securely. Put some of the new pads in the M, and now the mats are held in place like they are welded. It seems the hooks on the pads are longer and more aggressive.
Since my mats/pads were purchased about the time Kevin indicated he had installed the mats new in the wagon, it is possible that the pad design has changed.
Jump to top Jazzkat is offline   Reply With Quote
Old Sun, Mar-05-2017, 01:50:41 AM   #2
TMSNYC
TMSNYC's Avatar
Reputation: 0 TMSNYC is on a distinguished road
Default Re: Floor mats - Velcro vs Through Post Style
Are you talking about the round velcro discs? I replaced my mats last year and they have vecro discs and they hold like a champ. No complaints at all.
Jump to top TMSNYC is online now   Reply With Quote
Old Sun, Mar-05-2017, 01:55:24 AM   #3
WyattH
The velcro is strong. It's the lining on the underside of the mat that is not.
Old Sun, Mar-05-2017, 01:59:14 AM   #4
TMSNYC
TMSNYC's Avatar
Yeah, my old mats were in decent shape but they were tearing away on the underside. Time will tell wether the new ones do the same, but so far so good.
Old Sun, Mar-05-2017, 04:39:51 AM   #5
Jazzkat
The underside of the mats on the 7 tore away. Mine were covered by one year warranty so I replaced. Seems like the mat area that mates to the plastic disk is more robust on the new ones.
However, on the mats I purchased several months back, the disk simply did not grab the bottom of the mat securely. So must be hit or miss type deal.
Old Sun, Mar-05-2017, 12:37:42 PM   #6
e46IX
e46IX's Avatar
Reputation: 0 e46IX is on a distinguished road
I actually much prefer the twisting plastic rivets that you see in E46 non-M's and E36's. Much better design and easy to remove when you need to clean the car.
Jump to top e46IX is offline   Reply With Quote
Old Sun, Mar-05-2017, 03:16:50 PM   #7
markiemark
Reputation: 0 markiemark is on a distinguished road
Did the design change from disc to post in a certain year? My 05 has the drivers side plastic posts sticking up. New to the E46 so not familiar.. Thanks
Jump to top markiemark is offline   Reply With Quote
Old Mon, Mar-06-2017, 08:24:27 PM   #8
sergbaja5t
Uncle Grandpa
sergbaja5t's Avatar
Reputation: 0 sergbaja5t is on a distinguished road
What I did is I cut the the Velcro disc off the stupid foam under padding. Then removed the rest of the under padding and used a upholstery glue, and glued back the Velcro disc to the mat. that was two years ago!.
2016 Ford F150 Screw sport Egoboost
2005 SilberGrau Met/Schwarz M3 Smg, VMR 703 reps, Megan Racing sec 3, Bilstein PSS10/Koni
2002 StahlGrau MET/Schwarz M3 6spd AA headers, Supersprint x-pipe, AA Gen 4 sec3, Besian hub and seals, Turbotoy hardware, Rouge Engineering Vanos & Coolant pipe, Arp studded, H&R/ST/Bilstein coilovers, M220 19's. S54 timing tool w/ two guide pins**FOR RENT** Atlanta valve adjustment service(ask about rates)! Simple coding & DME scanning (Atlanta area)
Jump to top sergbaja5t is offline   Reply With Quote
Old Mon, Mar-06-2017, 08:26:12 PM   #9
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
only problem with the velcro, after time the velcro on the mats will tear off.
Tischer aka GetBmwParts
Old Tue, Mar-07-2017, 04:30:30 AM   #10
Kirra
Reputation: 0 Kirra is on a distinguished road
Ditto. I didn't attempt to peel the rest of the foam off the back of the velcro piece. Used 3M Foam Fast glue (doesn't soak in), and it's been holding solid since I did it 3 years ago.
Jump to top Kirra is offline   Reply With Quote
Discussing Floor mats - Velcro vs Through Post Style in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
