Old Fri, Apr-21-2017, 06:54:26 AM   #31
SinaE46
Reputation: 0 SinaE46 is on a distinguished road
Default Re: SMG Compression Spring DIY
Originally Posted by macming View Post
Great write up! I'm thinking of changing my spring as well. Did anyone change all 4 springs listed here?
http://www.realoem.com/bmw/showparts...87&hg=23&fg=15
I'm thinking of getting these 4 part #s:
23317511337 - Main Spring (5)
23311228393 - 02
23111222720 - 06
23311228405 - 15
I also need some clarification if all 4 springs should be replaced is having problems (specifically gears 1-4). Additionally, are these part numbers all the "upgraded spring" part numbers?
Jump to top SinaE46 is offline   Reply With Quote
Old Fri, Apr-28-2017, 12:21:42 AM   #32
SinaE46
Hey guys.
Following up my last post. Did anyone here change all 4 springs? Additionally, have all 4 springs been "beefed up" by BMW to avoid future breakage?
Seems only compression spring #23317511337 has been improved.
Old Wed, Jun-07-2017, 04:12:50 AM   #33
SleeveofWizard
SleeveofWizard's Avatar
Reputation: 0 SleeveofWizard is on a distinguished road
Time to revive, also flame suit equipped!
So, I have access to a full shop, lifts and what not. But don't necessarily have the time to do all that crap like dropping exhaust, and drive shaft, time is money. Blah blah blah, also I'm no stranger to turning wrenches; been doing it for a good while now.
With that said, I know this is not the proper way to do it, but I know I cannot be the only one who hasn't been tempted to just cut a small whole in the tranny tunnel and you have access to everything on top of the tranny?
I know, all the BMW lords will freak the eff out, but seriously. Die grinder, cutting wheel. Done in an hour. IDK maybe I'll be the guinea pig for this and let you all know, I'll give my VIN out too so you guys can put me on the blacklist of cars not to buy.
Serious note, I plan on owning this car until I die or it dies; sooooooo I can live with a small hole then just weld it back in.
Jump to top SleeveofWizard is offline   Reply With Quote
Discussing SMG Compression Spring DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
