Old Mon, Jun-29-2009, 08:10:04 PM   #1
ClutchKickChris
Reputation: 0 ClutchKickChris is on a distinguished road
Exclamation Engine starts up in "cold start" mode 90% of the time
I've noticed over the past 2 months of owning my M3 that it almost ALWAYS goes into cold start mode after starting the engine. It does this 9/10 times and it doesn't seem to matter how hot or cold the engine is.
Has anybody else noticed this? In addition to this the car seems to have less power than if it doesn't do cold startup.
For anyone wondering what cold start mode is, it's when the engine is cold and immediately after the engine starts the RPM is high and the exhaust tone very raspy and loud. My car does this even when the engine is fully warmed up!
Jump to top ClutchKickChris is offline   Reply With Quote
Old Tue, Jun-30-2009, 12:08:37 AM   #2
akbrazil
Reputation: 0 akbrazil is on a distinguished road
how do you know ur in cold start mode?? Does the lights on the Tech never turn off??
2003 M3 SMG - Headers, Borla Mid, ASA Muffler, 4.10 Gears, EVOsport Underdrive Pulleys & Electric Fan conversion, Snow Performance Meth/Water Injection.
Coming Soon: NITROUS
Jump to top akbrazil is offline   Reply With Quote
Old Tue, Jun-30-2009, 01:22:24 AM   #3
ClutchKickChris
Please re-read the last part of my post.
Old Tue, Jun-30-2009, 02:48:18 AM   #4
stolidog
stolidog's Avatar
Reputation: 0 stolidog is on a distinguished road
I thought I read somewhere that it was normal start up procedure for the engine. Who knows though, mine does it too.
Jump to top stolidog is offline   Reply With Quote
Old Tue, Jun-30-2009, 04:42:36 AM   #5
akbrazil
Yeah, I never heard such thing. I just know that once your tech light all goes out (up to 7500 rpm) then your all warmed up.
Old Tue, Jun-30-2009, 07:27:16 AM   #6
ondafly
E46M3CAB_NOW E36M3COUP_BYE_BYE
ondafly's Avatar
Reputation: 0 ondafly is on a distinguished road
Ireland
My 01 cab does this "cold start" mode for about 5/10 mins of driving when starting from cold. I would like to know how to get it to stop
not exactly - ever notice the oil temp isn't at the half way point even though the lights are out?
www.bmw-driver.net
Jump to top ondafly is offline   Reply With Quote
Old Tue, Jun-30-2009, 02:38:21 PM   #7
itchyn
Reputation: 0 itchyn is on a distinguished road
This applies to the E9X M3 and isn't concusive, in any way, but check out the following link and draw your own conclusions, if any:
http://www.m3forum.net/m3forum/showp...1&postcount=76
My, seat of the pants thoughts are that, IF this applies to the E46 M3, then "cold start" refers to "cold" cats and not necessarily "cold" ambient temperatures. I believe the operating temperature for cats is somewhere in the neighborhood of 500 deg. F or higher. IF this applies and IF it is the cause of your "rough" idle, then it MAY be normal.
OK enough speculation and conjecture, hope this helps.
Jump to top itchyn is offline   Reply With Quote
Old Wed, Apr-19-2017, 06:28:41 PM   #8
Masterchoans1
Reputation: 0 Masterchoans1 is on a distinguished road
Default Re: Engine starts up in "cold start" mode 90% of the time
My s54 swapped m3 does the exact same thing. I've been trying to figure out what is the cause of this cold start mode even when the engine is warmed up. My car is TTFS tuned with no CEL. It's driving me nuts. This can't be a normal thing, no way. Anyone has any suggestions ?
Jump to top Masterchoans1 is offline   Reply With Quote
Old Thu, Apr-20-2017, 12:38:59 PM   #9
Pahkthebeemah
Reputation: 0 Pahkthebeemah is on a distinguished road
So if there is one amber light on the rpm left, it should be fully warmed up and go directly to a hot start process? Or is it an oil temp reading that has the engine revert to a hot start/cold start? Or are the amber lights directly associated with a set oil temp range?
06' VW GTI, Stage II+ (first car, gone)
08' BMW 328xi, Stock (gone)
06' Kawazaki 636 (gone)
12' Jeep Sport (gone)
13' BMW 335i MSport, Stock (gone...regret it)
13' Kia Rio (current daily driver)
03' BMW M3 SMG (pleasure only)
Jump to top Pahkthebeemah is offline   Reply With Quote
Old Fri, Apr-21-2017, 07:37:13 AM   #10
ColinGreene
Archer
Reputation: 0 ColinGreene is on a distinguished road
its a procedure to heat the cats up as quickly as possible.
Jump to top ColinGreene is offline   Reply With Quote
90%, cold start, engine, mode, starts, time
Discussing Engine starts up in "cold start" mode 90% of the time in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
