Old Thu, Apr-20-2017, 07:14:42 PM   #21
Pirelli Condoms
Pirelli Condoms's Avatar
Reputation: 0 Pirelli Condoms is on a distinguished road
Default Re: Charleston Sc subframe reinforcement.
Taking it to the shop now
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.”
― Ayrton Senna
2002 E46 M3 CB/Cinn. 102k 6MT
AST 4200 Coilovers | Square 67's with 275 NT01's | Swaybarian front bar | Poly errthing | Powerflex lca | Gtfour cage | Rogue front strut bar | Recaro SPG w/ black vinyl cover | Z3 shifter | Gloc R12/10 | Macht schnell elbow/filter | Mishimoto efan |
Jump to top Pirelli Condoms is offline   Reply With Quote
Old Thu, Apr-20-2017, 07:19:18 PM   #22
Pirelli Condoms
Originally Posted by nasieg View Post
Well that throws a wrench, to the theory for using the subframe bolt
Don't give up hope yet.
― Ayrton Senna
Old Thu, Apr-20-2017, 07:20:30 PM   #23
Pirelli Condoms
Originally Posted by m3az05 View Post
I live in Sumter, would love to get something like this together
Sent from my SM-G930V using Tapatalk
That sounds great. I could get a few racecars there too if you want!
― Ayrton Senna
Old Thu, Apr-20-2017, 08:47:04 PM   #24
nasieg
nasieg's Avatar
I haven't. It was meant as passive aggressive comment on my behalf, because of another thread. ;-)
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Rally Road/P0lar Adapters, SS Brake Lines, Motul 600,Hawk HT-10 Pads, Braille Lightweight Battery, Hotchkis Sway Bars, SR2 CF Sunroof Panel,Apex ARC-8 & Sportline CS8's, Recaro Sportser CS Seats,SAP delete,Lightweight Cabin Filter Housing, SG CSL Diffuser, OEM CSL Trunk, Modified Stock Muffler
Jump to top nasieg is offline   Reply With Quote
Old Thu, Apr-20-2017, 10:02:00 PM   #25
Pirelli Condoms
Sooooo, it's looking like the front diff bolt
― Ayrton Senna
Old Thu, Apr-20-2017, 11:52:18 PM   #26
HD-M3
HD-M3's Avatar
Reputation: 0 HD-M3 is on a distinguished road
Puerto Rico
Good to hear. I was thinking that if your car gets the SF torn with all that you have, the rest of us are doomed.
2004 BMW ///M3 E46
Jump to top HD-M3 is offline   Reply With Quote
Old Fri, Apr-21-2017, 12:31:22 AM   #27
PITT M3 RR
PA
PITT M3 RR's Avatar
Called it haha much better / quick fix
S54 E36 BUILD
Jump to top PITT M3 RR is online now   Reply With Quote
Old Fri, Apr-21-2017, 01:09:27 AM   #28
Pirelli Condoms
Lol yep. I'm gonna do all poly while I'm in there. I have most everything but the subframe bushings. Gonna run 80a for the diff, 95a for Rtabs, 95a or alum for subframe.
― Ayrton Senna
Old Fri, Apr-21-2017, 04:30:11 AM   #29
PITT M3 RR
PA
PITT M3 RR's Avatar
I use aluminum subframe bushings, with 95 a differential bushings. That's perfect, but that's in my E36. The E 46 differential doesn't like the harder differential bushings if it's not 100% healthy. You'll get a little more m klunk the harder you go with differential bushings. My new E 46 is getting aluminum subframe with 95A differential… But I'm also going to make the jump to a mechanical LSD. I also used to run 75D subframe bushings with 75D differential bushings also… It was very harsh so I replaced the differential ears with OEM and that really eased everything up to a good street feel, but I did still have some m klunk
S54 E36 BUILD
Old Fri, Apr-21-2017, 03:12:51 PM   #30
Pirelli Condoms
relatively new diff
― Ayrton Senna
Discussing Charleston Sc subframe reinforcement. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
