Old Thu, Mar-23-2017, 09:20:52 PM   #91
armst06
Reputation: 0 armst06 is on a distinguished road
Default Re: SMG Shift Paddle Install
Great info compiled in this thread. Even after watching youtube video and looking at posted pictures, getting the airbag off was a b****. The photos and descriptions helped me understand that my switch was the problem so immense time was saved. I ended up having to resolder the downshift microswitch. Everything went back together and paddles now both work great!!!
Jump to top armst06 is offline   Reply With Quote
Old Fri, Apr-21-2017, 02:07:13 PM   #92
Awdsome
Reputation: 0 Awdsome is on a distinguished road
I seem to have lost the torx screw that holds the paddle in place
Anyone have a part number or extra screw laying around?!
Jump to top Awdsome is offline   Reply With Quote
Old Tue, Apr-25-2017, 01:26:15 AM   #93
E46Hoonigan
Reputation: 0 E46Hoonigan is on a distinguished road
https://www.turnermotorsport.com/p-7...pxUaAoX48P8HAQ
Jump to top E46Hoonigan is offline   Reply With Quote
Old Tue, May-02-2017, 01:33:12 AM   #94
spiderz17
spiderz17's Avatar
Reputation: 0 spiderz17 is on a distinguished road
First off, for the thread.
Second, seriously does no one make the little plastic pieces separately? Like the smart guy I am, I damaged the little plastic cover over the switch and need a replacement. $200 for a little piece of plastic is a little ridiculous.
If I don't hear anything, I'll probably spend a while just driving with the console shifter while I try to 3D print one! If I can get it sorted, it sounds like there might be a bit of market to make a few bucks on the side! I'll keep y'all posted on my progress. Of course, if someone knows of a cheap way to just buy one, I'd prefer that.
Jump to top spiderz17 is offline   Reply With Quote
Old Tue, May-02-2017, 08:17:19 PM   #95
Good
@GOOD_M3
Good's Avatar
Reputation: 0 Good is on a distinguished road
Those paddles look dope, might have to get some for myself!
Exhaust: Active Autowerke Headers, Euro Section 1, Statusgruppe Resonated X-pipe Section 2, Supersprint Sport Section 3
Suspension: Polyurethane FCAB, ST XTA Coilovers
Other Mods: B-Spec Tune, Mishimoto Electric Fan, Macht Schnell Elbow/filter, Xtrons Headunit.
Major Maintenance: WPC Rod Bearings, Cooling System Refresh, Subframe Bushings & Reinforcement, Differential rebuild, Beisan solenoid.
Jump to top Good is offline   Reply With Quote
Old Wed, May-03-2017, 03:01:26 PM   #96
humarahumara
Reputation: 0 humarahumara is on a distinguished road
Have some left over smg parts. Screw and plastic thingy as well as wiring in the steering wheel. PM me if needed.
Jump to top humarahumara is offline   Reply With Quote
Old Mon, Feb-05-2018, 05:11:16 PM   #97
Qix
Reputation: 0 Qix is on a distinguished road
Italy
Mounted myself the shift paddles ten minutes ago following carefully all the steps of the guide and using the 12 o'clock suggestion.
Did everyting slowly and carefully and it all went smooth! No need to remove airbag
I can now enjoy some good paddles!
Great guide! Thanks!
My babies: Alfa GT - BMW M3 e46
Jump to top Qix is online now   Reply With Quote
Old Mon, Feb-05-2018, 08:04:42 PM   #98
steve03m3
Reputation: 0 steve03m3 is on a distinguished road
A couple of points about the procedure. There are also 2 screws under the steering wheel which must be removed to get the trim off. Also if you loosen the paddle switch the covers can be replaced more easily.
steve
Jump to top steve03m3 is offline   Reply With Quote
install, paddle, shift, smg
F/S black CF SMG paddle shift NightKidz Parts for Sale/Wanted 6 Fri, Sep-26-2008 05:45:59 AM
SMG shift paddle glitch sprbxr E46 M3 (2001-2006) 10 Fri, May-11-2007 02:30:30 AM
Right SMG paddle Doesnt SHIFT! NMT Faults, Fixes and DIY 8 Tue, Oct-04-2005 12:42:59 AM
SMG Paddle Shift Vs Traditional Manual box Sam Catling General BMW Discussion 11 Wed, Jun-22-2005 01:53:54 PM
SMG shift paddle size 20C4S E46 M3 (2001-2006) 12 Wed, May-19-2004 12:55:12 PM
Discussing SMG Shift Paddle Install in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
