Old Sat, Jul-10-2010, 04:53:41 PM   #501
deeznutz972
Reputation: 0 deeznutz972 is on a distinguished road
10W60
'11 e92 M3 ZCP DCT Lemans/Nappa [Volk, Recaro CS, Corsa, BMW Wheel v2, aero]
'04 M3 AW/Nappa 6-Spd [Evolve airbox, SS V1 headers, TTFS, PSS9, Apex, RTD, Dinan, Sparco]
'14 Accord Sport Sedan
'13 Lexus GX 460 Premium
'11 e90 M3 SG/Nappa 6-Spd [ZCP, leather, slicktop] - Sold
Jump to top deeznutz972 is offline   Reply With Quote
Old Sat, Jul-10-2010, 10:06:59 PM   #502
bfrederick521
bfrederick521's Avatar
Reputation: 0 bfrederick521 is on a distinguished road
Default 10/60
For an 01-06 M3 and I just checked mine but clearly right under the hood on the air intake is a sticker annotating the Castrol 10/60. Anyone else?
SOLD:
2002 ///M3 Carbon Black/Grey
2002 X5 3.0i Black/Beige
1996 ///M3 Lux Boston Green/Modena
1992 318is Silver/Blue
1984 318i Silver/Black
1980 320i Blue/Blue
1980 320i White/Tan
Jump to top bfrederick521 is offline   Reply With Quote
Old Sat, Jul-10-2010, 10:57:55 PM   #503
Rausch
I <3 rasp.
Reputation: 0 Rausch is on a distinguished road
Germany
The 5W30 was for the rest of the engine line in the 3 series, among many others I'm sure. I'd guess the SA isn't too familiar with the particulars of the M.
Jump to top Rausch is offline   Reply With Quote
Old Sat, Jul-10-2010, 11:50:16 PM   #504
Khanman
Bored. Probably drinking.
Khanman's Avatar
Reputation: 0 Khanman is on a distinguished road
same with mine. on the owners manual that i got from the previous owner they had put in 5W30.
but the BMW dealer puts in 10W60, same as what it says right under the hood.
Daily/Stuff carrier - Some Porsche no one on this stupid forum likes.
Track ride - 2008 Yamaha R6
Jump to top Khanman is offline   Reply With Quote
Old Sun, Jul-11-2010, 01:17:27 AM   #505
TitaniumSilber
TitaniumSilber's Avatar
Reputation: 0 TitaniumSilber is on a distinguished road
I called roxbury bmw again, they quoted me 250 for the oil change.....(mind u, this place first told me the m3 needs 5w30, then after i said 10w60, they said yea, they can put that in too)
I called Paul Miller BMW in wayne, and they said $120 (10w60)
I guess ill be going to Paul Miller on monday.
Jump to top TitaniumSilber is offline   Reply With Quote
Old Sun, Jul-18-2010, 01:01:26 AM   #506
Khanman
Khanman's Avatar
Have a question. My e46 has 62k on it and I'm about to put do an Inspection II on it. but of course I want the best price.
dealer wants 1900 all said and done, 700 for parts.
a local dealer place is asking 964 (very reputable place, VS motorsports, have heard nothing but amazing things).
but I want to order the parts from http://www.turnermotorsport.com/html...CT_ID=INSP2S54 and they give this:
Inspection II Maintenance Package - E46 M3, MZ3 (S54)
Part #: INSP2S54
Applications: 2001 - 2006 (E46 MZ3)
Inspection II Package for 2001-2006 E46 M3 and MZ3 (S54).
Includes: Castrol TWS 10w60 engine oil (7 quarts), OEM oil filter, Ate Super Blue brake fluid, A/C microfilter, OEM NGK spark plugs, OEM air filter, Red Line transmission and differential oil (2 quarts of each), OEM fuel filter. Optional items for the Do-It-Yourselfer are the valve cover gaskets -- for if you or your mechanic are performing the BMW recommended valve adjustment, a Peake Fault Code/Reset Tool and/or a Bentley Service Manual. CRC Airflow Sensor cleaner included at no charge!
We also offer the OEM fluids for the transmission and differential. You can add these instead of the Red Line Oil if you prefer. We use the OEM Pentosin transmission fluid (comparable to MTF LT2) and OE BMW SAF-XJ+FM Booster for the differential. Select the option below if you would like to substitute them. For E46 M3 only - the MZ3 does not use these fluids in either the transmission or diff.
wondering what else I'm missing other then the valve cover gaskets?
Old Tue, Jul-20-2010, 08:42:19 PM   #507
geoffreybeachy
Reputation: 0 geoffreybeachy is on a distinguished road
My "check engine soon" light just came on this morning.... My car is currently at 92k, does that mean inspection 2 is needed?
Jump to top geoffreybeachy is offline   Reply With Quote
Old Tue, Jul-20-2010, 09:23:04 PM   #508
nope, totally unrelated. The countdown when you turn on the car tells you when inspection should be. The SES light means something is failing/failed.
Old Sat, Jul-24-2010, 10:30:34 PM   #509
Khanman
Khanman's Avatar
noob question about brakes:
I will probably need some work done on my brakes very soon. The question is, do I have to get a whole new brake set or can I just go by with replacing the brake pads? I was told I would probably have to get the rotors replaced too?
Old Sun, Jul-25-2010, 03:07:48 AM   #510
BlazenXLT
We've had one yes, what about second breakfast?
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
You don't have to replace the rotors when replacing pads, although I fear that's a line used by a lot of dealers or shops looking for extra $$$. Regardless of pad changes, rotors have a minimum thickness marked somewhere on the outer edge that they are safe to use until they are at that point.
Your rotors may actually need replaced if they are that worn. The good news is, replacement blanks are cheap and installing them is surprising easy.
Jump to top BlazenXLT is offline   Reply With Quote
e46, getbmwparts.com, maintenance, thread, tischer
:: ECS Tuning :: Selection of E46 M3 Maintenance Products and Service Kits ECSTuning M3Forum Sponsor Announcements and Specials 1 Wed, Sep-24-2008 06:21:18 PM
E46 maintenance / DIY support ? jav1 E46 M3 (2001-2006) 19 Tue, Aug-21-2007 05:29:00 AM
FS: 2002 E46 M3 (SMG) - CPO/Extended Maintenance (BMW Individual) NoSoup4U Parts for Sale/Wanted 6 Thu, Jun-29-2006 09:14:08 PM
The Preventative Maintenance Thread Obioban E46 M3 (2001-2006) 1 Tue, Jul-05-2005 11:38:25 PM
E36 M3 vs. E46 328Ci -- Maintenance Costs gdhyde E36 M3 (1992-1999) 13 Sat, Dec-11-2004 07:23:39 PM
Discussing e46 M3 Maintenance Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
