Old Tue, Apr-29-2008, 05:47:17 PM   #101
IGotId
No longer driving an e46 after 1 e46 or another for a decade
IGotId's Avatar
Reputation: 0 IGotId is on a distinguished road
Originally Posted by JeST View Post
I replaced my bank 2 header due to a failing cat I believe around 55k miles. Theres no tell tale sign of when a cat will go bad. Good thing is it's covered 8 years or 80,000 miles
covered by whom? BMWNA?
under the original warranty?
Silver Grey/Cinnamon Premium, Nav, Xenons, CWP; TC Kline S/A Coilovers; Gunmetal RAC RG4 v.2 19x9/10"; Stoptech BBK; OEM CSL Bootlid & Diffuser, V-CSL v2 bumper; Dinan SSK, Dinan exhaust, & Dinan Front Strut Tower Brace
Jump to top IGotId is offline   Reply With Quote
Old Tue, Apr-29-2008, 07:07:17 PM   #102
yes, bmwna is legally require to cover the cats till 8/80,000
Old Wed, Apr-30-2008, 12:34:01 AM   #103
IGotId
IGotId's Avatar
Old Wed, Apr-30-2008, 12:38:24 AM   #104
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
I was covered by CPO warranty, but yes like Ian said its also covered 8year,80k miles.
Daily Driver: 2002 Steel Grey M3
Garage Queen: 1994 Toyota Supra 6speed Red/Black
Gone:
'03 AW/Cinn e46 M3
'08 DTM B7 S4
'87 Mtech 1 S50 e30
'88 Hennarot e30 M3
'11 LeMans Blue / chestnut Mtech 335d
'11 e70 VF stage 2 X5M
'08 Interlagos e92 M3
Jump to top JeST is offline   Reply With Quote
Old Sat, May-03-2008, 05:13:15 PM   #105
B18Cjdm GSR
B18Cjdm GSR's Avatar
Reputation: 0 B18Cjdm GSR is on a distinguished road
Awsome source for great info!
2002 Steel Gray/Black M3 AA Supercharged-Current
Alpine White/Imola Red Coupe 6SPD-sold
Black/Black 2006 M5-sold
Jump to top B18Cjdm GSR is offline   Reply With Quote
Old Sun, May-04-2008, 05:08:43 AM   #106
E46M3FTW
Reputation: 0 E46M3FTW is on a distinguished road
Iran
I had brand new rotors, pads & sensors installed from factory through warranty. I want to bleed my breaks because the squeak is just crazy. Would you guys say 8 60MPH-10MPH would be enough? After I let it cool down from the first cycle of 8 times, should I repeat the process in the same day or another day?
Edit: Forgot to mention, I have the drilled rotors if it changes anything.
Also, does the Inspection II magically start to appear on your dash? When I turn the key, the only thing that it says is the OILSERVICE.
Jump to top E46M3FTW is offline   Reply With Quote
Old Sun, May-04-2008, 02:47:00 PM   #107
The number of cycles really depends on the pads you have. I just do it till they begin to fade a little.
In terms of the inspection interval, you should be resetting the service interval every time it gets to 0 (and you service the car). Then the next service in the cycle will begin
Old Mon, May-05-2008, 01:05:20 AM   #108
JeST
Old Skool
JeST's Avatar
China
If you have the zcp brakes (im guessing since you said you have drilled rotors) they do tend to squeak on light applications of the brakes. Bleeding the brakes have nothing to do with brake noise. Bleeding the brakes means your bleeding the brake fluid (people do this if the brake pedal feels mushy like theres air in the lines). What your about to do is called bedding the pads (stops from 60-10 8 to 10 times is more then efficient).
Your service indicator is not magical in any way. It says "OIL SERVICE XXX miles" because thats all you need is an oil service. After the oil service is due (when the indicator says 1000 miles or less) and performed and the service is reset the next service will then be an Inspection (whether its inspection I or II depends on what the previous service was).
Gone:
'03 AW/Cinn e46 M3
'08 DTM B7 S4
'87 Mtech 1 S50 e30
'88 Hennarot e30 M3
Old Mon, May-05-2008, 03:24:54 AM   #109
E46M3FTW
Iran
Yes it is competition package, I did it 6 times today the sqeek went away for now. We'll see what happens. It was bothering me a lot but seems to be a common thing with true sport cars. My friend has a 911 997 Turbo Cab and he said his does it as well.
Also as far as Inspection II, my oil service said I have 11000 left of driving. So after this 11000, when I get my oil change done the next service would be my Inspection II correct?
Old Mon, May-05-2008, 11:05:07 PM   #110
JeST
Old Skool
JeST's Avatar
China
It can either be an inspection I or inspection II. Depends on what the previous service's were.
Example:
First service 1200 mile: self explanatory
2nd service: 15k service (oil service and a microfilter change)
3rd service: Inspection I (Again self explanatory)
4th service: 15k
5th service: Inspection II
6th service: 15k
7th service: Inspection I
etc. etc. etc.
Gone:
'03 AW/Cinn e46 M3
'08 DTM B7 S4
'87 Mtech 1 S50 e30
'88 Hennarot e30 M3
e46, getbmwparts.com, maintenance, thread, tischer
:: ECS Tuning :: Selection of E46 M3 Maintenance Products and Service Kits ECSTuning M3Forum Sponsor Announcements and Specials 1 Wed, Sep-24-2008 06:21:18 PM
E46 maintenance / DIY support ? jav1 E46 M3 (2001-2006) 19 Tue, Aug-21-2007 05:29:00 AM
FS: 2002 E46 M3 (SMG) - CPO/Extended Maintenance (BMW Individual) NoSoup4U Parts for Sale/Wanted 6 Thu, Jun-29-2006 09:14:08 PM
The Preventative Maintenance Thread Obioban E46 M3 (2001-2006) 1 Tue, Jul-05-2005 11:38:25 PM
E36 M3 vs. E46 328Ci -- Maintenance Costs gdhyde E36 M3 (1992-1999) 13 Sat, Dec-11-2004 07:23:39 PM
Discussing e46 M3 Maintenance Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
