View Poll Results: Has your VANOS Pressure Hose failed?
Yes 15 20.83%
No 43 59.72%
No, but I've seen other peoples'. 14 19.44%
Voters: 72. You may not vote on this poll
Old Tue, Aug-12-2014, 10:04:59 PM   #1
will.c
will.c's Avatar
Reputation: 0 will.c is on a distinguished road
Default VANOS Pressure Hose Failure?
As an extension to another thread that discussed this issue briefly, I'd like to take a quick survey.
http://www.m3forum.net/m3forum/showt...=483987&page=3
OEM PN 11367837614
Mine is fine for now, but I met 3 people so far who has had these fail on track, which resulted in complete loss of oil pressure (I need a gauge/alarm for this) and pretty much trashing the engine.
But only a handful of cases out of hundreds of hard-tracked S54s out there doesn't seem alarming to me, so if the poll shows enough cases, maybe I'll convince myself to just replace it.
If preventative replacement is concluded, OEM or aftermarket?
Bimmerworld: http://store.bimmerworld.com/bimmerw...ine-p2030.aspx
Rogue Engineering: http://www.rogueengineering.com/rogue/ENG/S54VAN.html
Jump to top will.c is offline   Reply With Quote
Old Tue, Aug-12-2014, 10:10:52 PM   #2
Hacksaw
What broke now?
Hacksaw's Avatar
Reputation: 0 Hacksaw is on a distinguished road
Default Re: VANOS Pressure Hose Failure?
Really need to add in a mileage marker in the survey honestly. I have not seen a single one fail. Of course I advocate updating to the newest revision when I have them in for vanos related service.
'02 BMW ///M3
Imola Red|Blk Cloth|6MT|FS CSL Custom TUNE -MSS54HP|CSL Replica Airbox|Euro Headers|BimmerWorld 3.5" race front Y and resonator|Hacksaw's custom 3.5" SS exhaust system w/Magnaflow and 4 tipped goodness|SGT RS-ENR Coilover Kit|Evo Sport Performance Pulley Set|CDV Delete|UUC USS & DSSR|Sparco Roadster Seats|StopTech ST-40 BBKs on all 4|Beisan Systems vanos rebuild w/original stock exhaust hub|Kirk 4 point roll bar|CF CSL Rep Trunk|GC Race F/R Sway Bars|TR Motorsports MT-1|Avin Avant 2|Seibon CF GTR Hood
Jump to top Hacksaw is offline   Reply With Quote
Old Tue, Aug-12-2014, 10:42:30 PM   #3
will.c
will.c's Avatar
Ah, good point. Forgot that... but I can't seem to edit the poll now.
All - please chime in the mileage at which it failed if you remember.
Old Tue, Aug-12-2014, 11:47:55 PM   #4
wrcdave
Mr. Chicken rules!
Reputation: 0 wrcdave is on a distinguished road
I had one fail on track and it started a small fire on my exhaust. The same thing happened to another track friend. Mileage was about 45k at the time. BMW improved the part so if you have an 01-02 M3 it should be replaced. BW has one for $50. You also can't tell by just looking at the pipe if it's good or not. When it goes the 1500 psi that the vanos system runs at will make a real mess of the engine bay.
Jump to top wrcdave is offline   Reply With Quote
Old Wed, Aug-13-2014, 12:18:55 AM   #5
bigjae1976
Just curious...is this a common reason why motors catch fire?
I know a lot of people remove the heat shields when they install headers...does this increase the likelihood of a fire?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Aug-13-2014, 12:37:45 AM   #6
Feuerbach86
Reputation: 0 Feuerbach86 is on a distinguished road
Mine failed at TWS this year in May... fun to open your hood to a 4 foot geyser of oil, and entertaining for the track marshal.
2002 SMG @ 110k
Lots of mods, had the header heat shield was still in. My motor didn't catch fire, oil was coming out of the M3 side vents in the front fender, which is what black flagged me... so I tested the "douse engine bay in oil and run at track temps to see if catch fire" urban myth as false.
2002 Silver SMG Cloth No Sunroof... Track Project
2005 Mystic Blue 6MT on Grey... RIP
Jump to top Feuerbach86 is offline   Reply With Quote
Old Wed, Aug-13-2014, 01:11:09 AM   #7
elbert
Sikkens Autocryl MM
elbert's Avatar
Reputation: 0 elbert has disabled reputation
Wales
I have a 2004 and mine cracked at the junction between the tube and banjo fitting. The oil would mist out and accumulated on the underpanel where it would slosh out.
It was at around 20k miles IIRC (I've owned my car since new), and it happened at the track for me too. At the time I overfilled the oil by about 1/2 quart or more, but I have since then stopped doing that. I think I was told they are somewhat related.
Jump to top elbert is offline   Reply With Quote
Old Wed, Aug-13-2014, 01:24:41 AM   #8
will.c
will.c's Avatar
Pretty scary so far...
Old Wed, Aug-13-2014, 01:54:53 AM   #9
Shadytype
Undercarriage checker
Reputation: 0 Shadytype is on a distinguished road
Will....did i scare you at the track?? Lol
First one was at 103k miles on track at Lightning in NJ.
Second one was on the Garden State Parkway at 105k miles. Yeah 2000 miles later. Split in the same spot. I think it was making contact or was a bad piece.
Either way its 6L of oil out of motor in about 10 seconds.
Jump to top Shadytype is offline   Reply With Quote
Old Wed, Aug-13-2014, 01:57:24 AM   #10
giantkeeper
Arrogant Bastard
giantkeeper's Avatar
Reputation: 0 giantkeeper is on a distinguished road
I've heard enough, I'm replacing mine stat!
Jump to top giantkeeper is offline   Reply With Quote
hard line, high pressure, pressure hose, vanos
Discussing VANOS Pressure Hose Failure? in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
