Old Sat, Mar-12-2016, 10:35:57 AM   #51
911Fiddler
Reputation: 0 911Fiddler is on a distinguished road
United Kingdom
Default Re: Help diagnosing 2003 E46 M3 engine ticking noise?
Try checking the frequency of the tick, ie camshaft runs at half the crank speed so assuming the tick happens once per rev, measuring the frequency of the ticking can tell you if its crank (pistons/rods) or cams (tappets etc).
Tricky part is measuring. I would take video at idle inc sound, import to a video editor tool that shows the sound track peaks and count the number of peaks per second....then its quantified & clearer...
Jump to top 911Fiddler is offline   Reply With Quote
Old Mon, Aug-27-2018, 01:46:11 PM   #52
whips333
whips333's Avatar
Sub'd just to remember to read this thread later
Old Mon, Oct-15-2018, 06:45:33 AM   #53
LaSource
LaSource's Avatar
Reputation: 0 LaSource is on a distinguished road
United Kingdom
I haver similar problem which cannot be solved for quite a long time. Have taken it to many places
Some say 'they all do that'...though it is too loud to be ignored
Everyone firstly suspects valve clearances - they've been adjusted now multiple times
Rockers/followers have all been replaced
Cam replaced with a good used one from an upgraded car
Exhaust manifolds checked for leaks
Still same noise.
Now going in to yet another specialist for valve check (again!) plus this one has isolated it to the rear exhaust bank and is looking to put a camera down from the top of the rear engine...
Sigh
That sounds smart. May give it a go.
Jump to top LaSource is offline   Reply With Quote
Old Thu, Oct-18-2018, 09:51:01 PM   #54
Zhemel
Zhemel's Avatar
Reputation: 0 Zhemel is on a distinguished road
Have you guys checked your water pump? I had a horrible knocking/ ticking sound and I traced it back to my water pump
Jump to top Zhemel is offline   Reply With Quote
Old Wed, Dec-19-2018, 01:45:49 AM   #55
bduff51
Reputation: 0 bduff51 is on a distinguished road
Has anyone had any oil supply problems to the valve train? I have a similar noise and I’m going to replace cams and followers but unless we figure out why the cams are wearing prematurely I feel that the problem will come back some time on the future.
Jump to top bduff51 is offline   Reply With Quote
e46, e46m3, engine, s54, vanos
Discussing Help diagnosing 2003 E46 M3 engine ticking noise? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
