Old Thu, Oct-21-2010, 06:08:47 PM   #41
04LSBM3
04LSBM3's Avatar
Reputation: 0 04LSBM3 is on a distinguished road
1. Year of Car: 2004
2. Current Mileage: 60,000 miles
3. Euro? U.S.? Canada? US
4. Mileage at failure or discovery: 60,000
5. Actual failure type: VANOS pump drive cog on exhaust cam gear
6. Symptoms of your VANOS issue: None
7. How did you determine what parts or parts failed? Inspection II check
8. Did you have dash warning lights show up? No
9. What fault codes if any showed up? None
10. Who fixed your VANOS issue? TBD
11. Cost to repair (details please): anywhere from 2500 up to 6500
12. Track use? None
13. Original owner? No, 2nd
14. Changed oil at what interval: 7.5K miles
15. Other comments or history of car: Damn car is pristine in and out, inside the engine is spotless
Jump to top 04LSBM3 is offline   Reply With Quote
Old Sun, Oct-24-2010, 01:25:30 AM   #42
Owebaby
Reputation: 0 Owebaby is on a distinguished road
1. Year of Car: 2005
2. Current Mileage: 38,000
3. Euro? U.S.? Canada? U.S
4. Mileage at failure or discovery:38,000
5. Actual failure type (solenoid, actuator, VANOS pump drive cog on exhaust cam gear, cam gear bolts, camshaft position sensor , other, or combination): 4 of 6 cam gear bolts on intake and exhaust sheared, two that were attached were 1.25 turn out, and about to sheer, about 1 month until complete engine failure.
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?) Engine sounded almost metallic, just slightly, had dealer Tech check it before, and said "they are a noisy engine", it's ok..... Second Tech a month later said "o yeah, there's something wrong here", originally believed it was a loud VANOS.
7. How did you determine what parts or parts failed? After BMW of American approved tech. to take apart motor to determine issue.
8. Did you have dash warning lights show up? Not one
9. What fault codes if any showed up? None at all
10. Who fixed your VANOS issue? BMW
11. Cost to repair (details please): Under CPO
12. Track use? (none, a little, some, often) Often
13. Original owner? 2nd
14. Changed oil at what interval: 500 miles before computer says
15. Other comments or history of car: Car made full power, never rough idle, other than a slight metallic sound, nothing abnormal, well unless a metallic sound is normal.... Our Tech. had told bmw that the car had rough idle to approve to look at Vanos, BMW told the Tech to look at Cam Gear Bolts, and there lied the problem. Took 18 hours of work and 3 days at dealer.
Jump to top Owebaby is offline   Reply With Quote
Old Sun, Oct-24-2010, 01:29:49 AM   #43
Owebaby
Originally Posted by M.Williams View Post
Interesting that no 2001's are listed yet.
The 2001's blew up due to main engine bearing being manufactured wrong....
Old Wed, Oct-27-2010, 02:24:46 PM   #44
mattyd
mattyd's Avatar
Reputation: 0 mattyd is on a distinguished road
my car is a 2004 u.s. m3 6 speed. mileage, 59k. i had no loss of power and no warning lights all i had what a horrible noise and i realized it was the vanos bolts after doing some research. i change the oil ever 4 to 5k and take car of the car very well, dont race at all. this is why i was suprised to see this happen.
Jump to top mattyd is offline   Reply With Quote
Old Thu, Oct-28-2010, 12:08:35 AM   #45
G550PLT
G550PLT's Avatar
Reputation: 0 G550PLT is on a distinguished road
2. Current Mileage: 54000
4. Mileage at failure or discovery: 54000
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?) No lights, just very rough idle suddenly
7. How did you determine what parts or parts failed? Autologic and dissasembly
9. What fault codes if any showed up? Misfires on all cylinders, Cam Position Sensor
10. Who fixed your VANOS issue? Indy Shop
11. Cost to repair (details please): $2400 (Rebuilt Vanos, New vanos pump drive cog)
12. Track use? (none, a little, some, often) Never
13. Original owner? Nope, 2nd
14. Changed oil at what interval: 5000k
Jump to top G550PLT is offline   Reply With Quote
Old Thu, Nov-11-2010, 06:39:23 PM   #46
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
Lightbulb
2. Current Mileage: 43,800
3. Euro? U.S.? Canada?: USA
4. Mileage at failure or discovery: 42,772
5. Actual failure type: Actuator and/or camshaft position sensor. I replaced both and the problem was fixed
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?): Nothing perceptible. Just SES light.
7. How did you determine what parts or parts failed? I researched the problem here, spoke to Dr. Vanos, and PMed members with similar problems and determined it was likely the solenoid. Unfortunately, a new solenoid did not fix my problem so I narrowed it down to the actuator or camshaft position sensor.
8. Did you have dash warning lights show up?: Yes, SES
9. What fault codes if any showed up?: Peake: B9 - Exhaust camshaft VANOS position control; GT1: 185 Function, exhaust VANOS
10. Who fixed your VANOS issue?: Indy Shop
11. Cost to repair (details please): Parts: Dr. Vanos rebuilt VANOS actuator (~$400 net of core exhange), exhaust camshaft sensor (~$80), numerous gaskets (~$100); Labor: 4 hrs. at $90/hr.
12. Track use? (none, a little, some, often): None to my knowledge, but I'm the 3rd owner
13. Original owner?: No, 3rd
14. Changed oil at what interval: About every 8,000/mi.
15. Other comments or history of car: My VANOS problems arose after about one month and a couple hundred miles of ownership. I suspect that the previous owner knew about it and hid the problem by resetting the SES light!
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Sun, Nov-14-2010, 07:10:15 AM   #47
ketchup
Reputation: 0 ketchup is on a distinguished road
I was hoping this was a 03.5 and up issue. I'm amazed that there isn't a recall issued yet for the vanos bolts.
Valve shim kit + tools for loan, PM me.
Originally Posted by 05e46M3
It doesn't look like you are familiar with the forum rules from the looks of your FS thread... I got a higher post count and more I-trader feedback than you, so don't tell me to go review them and please don't pm me again, not interested. Thanks
Jump to top ketchup is offline   Reply With Quote
Old Fri, Nov-19-2010, 05:36:11 AM   #48
Nunnink23
Reputation: 0 Nunnink23 is on a distinguished road
2. Current Mileage: 65556
4. Mileage at failure or discovery: 65556
5. Actual failure type: None
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?): Decreased power, no ses light, marbles sound
7. How did you determine what parts or parts failed?: Still not sure cars been in the shop for 2 weeks
8. Did you have dash warning lights show up?: No only once before SES
9. What fault codes if any showed up?: n/a
11. Cost to repair (details please): 1200 so far in labor, new cam bolts, new gaskets, more to come probably a solenoid or actuator.
13. Original owner?: 2nd
14. Changed oil at what interval: 7,500/mi.
15. Other comments or history of car: Has never felt very torquey compared to another m3 i rode in and im very easy on my car compared to him.
Jump to top Nunnink23 is offline   Reply With Quote
Old Mon, Nov-22-2010, 03:51:39 PM   #49
dumpm3
dumpm3's Avatar
Reputation: 0 dumpm3 is on a distinguished road
wow this is scarey. I see alot of vanos issue on 2003-2004 models mostly, but i know this can happend to any M3 out there. Im going to get mines replaced soon.
Jump to top dumpm3 is offline   Reply With Quote
Old Mon, Nov-22-2010, 07:53:43 PM   #50
rhumbline
rhumbline's Avatar
Reputation: 0 rhumbline is on a distinguished road
Noticed same thing, being a 2001 owner with crossed fingers. Was there a running change from 2002-on or just chance that no 2001s have fragged their motors and owner's wallets?
Jump to top rhumbline is offline   Reply With Quote
failure, gathering, information, poll, vanos
Discussing Poll ii: Vanos failure information gathering in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
