Old Sun, Aug-15-2010, 04:50:00 PM   #11
normcaldwell
Reputation: 0 normcaldwell has a spectacular aura about
1. Year of Car: 2006
2. Current Mileage: 62,000
3. Euro? U.S.? Canada? U.S.
4. Mileage at failure or discovery: 27,500
5. Actual failure type (solenoid, actuator, VANOS pump drive cog on exhaust cam gear, cam gear bolts, camshaft position sensor , other, or combination): Drive tab on exhaust gear for VANOS oil pump drive.
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?) Power loss.
7. How did you determine what parts or parts failed? Dealer analysis.
8. Did you have dash warning lights show up? SES light.
9. What fault codes if any showed up? Failure Codes 94 (inlet VANOS adaptation) and 184 (Function inlet VANOS) stored in the DME.
10. Who fixed your VANOS issue? Dealer.
11. Cost to repair (details please): Done under new car warranty.
12. Track use? (none, a little, some, often): No track use by the original owner up to that point.
13. Original owner? I'm the 2nd owner. The VANOS failure happened to the original owner.
14. Changed oil at what interval: 1,200 mile break-in, then every 7,000 miles thereafter.
15. Other comments or history of car: The original owner maintained this car perfectly. He ensured that the 1,200 mile break-in service was performed; which included engine oil/filter, transmission and diff oils. He used only Castrol TWS 10W-60, and changed the engine oil/filter again at 7k, 13k, 20k, and the Inspection I at 25k miles.
Since the VANOS replacement at 27,500 miles, neither the original owner or I have had any issues. I purchased the car at 30,500 miles. The car is now at 62,000 miles. Inspection II was performed at 50k miles. I change the engine oil every 4 to 5k miles, still using Castrol TWS 10W-60. I've tracked the car a number of times, and it has performed flawlessly.
Here is the dealer's report on the VANOS at 27,500 miles:
Drive tab on exhaust VANOS gear for VANOS oil pump drive failed, and the piece went through the VANOS gears and damaged the VANOS gears, and stretched the timing chain.
The VANOS test run failed.
Replaced VANOS unit due to damage to the VANOS oil pump drive.
Replaced the stretched timing chain and damaged VANOS gears on the camshafts (intake and exhaust).
Removed the oil pan to find the broken piece from the exhaust VANOS gear and VANOS oil pump drive.
Reassembled engine and performed VANOS function test. It passed, and cleared fault memory.
Here is Mike's report when the VANOS failure occurred: http://www.m3forum.net/m3forum/showthread.php?t=212573
Jump to top normcaldwell is offline   Reply With Quote
Old Sun, Aug-15-2010, 04:54:39 PM   #12
Hdriver
Hdriver's Avatar
Reputation: 0 Hdriver is on a distinguished road
2 72800
3 USA
4 70500
5 Exhaust cam gear cog failed (broke off)
6 No indications no sounds no performance changes
7 Valve service Indy shop
8 No
9 No
10 Indy shop
11 $ 1500 included labor $1200 part
12 No
13 Second owner
14 Use to every 7500 now 3500
7
2004 JB M3
1998 CB M3 SOLD
1993 B RX-7 SOLD
1992 V-MAX SOLD
"For those who understand, no explanation is needed.
For those who do not understand, no explanation is possible."
Jump to top Hdriver is online now   Reply With Quote
Old Sun, Aug-15-2010, 05:37:23 PM   #13
sunboy97
Reputation: 0 sunboy97 is on a distinguished road
Response below.....
Originally Posted by drmudryk View Post
1. Year of Car: 2003
2. Current Mileage: 41600
3. Euro? U.S.? Canada? US
4. Mileage at failure or discovery: 41000
5. Actual failure type (solenoid, actuator, VANOS pump drive cog on exhaust cam gear, cam gear bolts, camshaft position sensor , other, or combination): Solenoid
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?) roughness, SES
7. How did you determine what parts or parts failed? Indy shop
9. What fault codes if any showed up? 184, 72
10. Who fixed your VANOS issue? Indy shop
11. Cost to repair (details please): Solenoid $700, labor $300
12. Track use? (none, a little, some, often) none
13. Original owner? yes
14. Changed oil at what interval: 10k
Jump to top sunboy97 is offline   Reply With Quote
Old Sun, Aug-15-2010, 06:25:18 PM   #14
lorkar
Ulitimate Fahrmaschine Spezialist
lorkar's Avatar
Reputation: 0 lorkar is on a distinguished road
Norway
I'm sorry I don't have time to post this in your format. I've had 7 vanos bolt failures on M3s from 2004 -2006. 4 us cars and 3 from Canada. All came in making noise. 2 of them had one broken bolt and all bolts loose with damage. The average repair cost was 700Cad. included bolts, valver cover gasket, vanos gasket, filter for the vanos and labor. (5 hrs)
Note that 4 customers had quotes from the local dealers for over 5500 stating the vanos had failed.(no mention of possible loose bolts)
19"SSR GT3s Satin finish,General UHPs, Eisenmann Race Exhaust, Sharked,CSL bumper, CSL diffuser,Depo smoked clears, Authentic ACS rear lip spoiler, Angel eyes.
Jump to top lorkar is offline   Reply With Quote
Old Sun, Aug-15-2010, 06:56:49 PM   #15
snowghost
Acolyte of Aeolus
snowghost's Avatar
Reputation: 0 snowghost is on a distinguished road
Default 2006 6MT Coupe
2. Current Mileage: 42.7k
3. Euro? U.S.? Canada? USA
4. Mileage at failure or discovery: 42.5k
5. Actual failure type (solenoid, actuator, VANOS pump drive cog on exhaust cam gear, cam gear bolts, camshaft position sensor , other, or combination): Inlet camshaft drive sprocket centering sleeve retaining bolts sheered. Inlet camshaft stopped spinning. Numbers 2 and 6 cylinders slammed intake valves and damaged cylinder head which was also damaged by impact with valves. Cylinder head and all valves (24) replaced along with inlet camshaft drive sprocket center sleeve retaining bolts.
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?) No antecedent symptoms. Car just died (limp mode) with no audible sound at approximately 50 mph and would not restart.
7. How did you determine what parts or parts failed? BMW dealership.
8. Did you have dash warning lights show up? None prior. Or after. It looked like an alternator failure.
9. What fault codes if any showed up? Don’t know.
10. Who fixed your VANOS issue? Local BMW dealer.
11. Cost to repair (details please): Repaired under warranty. Although tech told me cylinder block was around $3000 itself for the part.
12. Track use? (none, a little, some, often) None.
13. Original owner? Purchased 12/06 with 5k miles.
14. Changed oil at what interval: Every 7500 miles.
15. Other comments or history of car: Car ran like a top and never a hint of malfunction in the VANOS.
"The best long distance runners eat red meat, run naked and sleep in the snow."
_____________________________________________
Jump to top snowghost is offline   Reply With Quote
Old Sun, Aug-15-2010, 09:02:46 PM   #16
jhanford1
Captain Parker
jhanford1's Avatar
Reputation: 0 jhanford1 is on a distinguished road
Seems all dealers claim it's a sealed unit with no serviceable parts. Such bull$hit. They just want to rape people for 5 grand.
Jump to top jhanford1 is offline   Reply With Quote
Old Mon, Aug-16-2010, 02:47:07 AM   #17
drmudryk
Dr. Dan
Reputation: 0 drmudryk is on a distinguished road
BUMPING back up
FOR SALE 2005 M3 SMG, PSS10, Borla Cat-Back, Turner Sway Bars, H&R Spacer F/R, Turner Bar links F/R, Turner camber plates, K&N Cold Air, Navigation.
I have my eyes on a 2008 M5. (I have kids)
http://www.m3forum.net/m3forum/showthread.php?t=329255
Jump to top drmudryk is offline   Reply With Quote
Old Mon, Aug-16-2010, 04:25:52 AM   #18
MegamanDS
Haters keep hatin
MegamanDS's Avatar
Reputation: 0 MegamanDS is on a distinguished road
Armenia
1. Year of Car: 2005
2. Current Mileage:63000
4. Mileage at failure or discovery:63000
5. Actual failure type (solenoid, actuator, VANOS pump drive cog on exhaust cam gear, cam gear bolts, camshaft position sensor , other, or combination): Not sure yet, still at dealership
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?) - loss of power while driving. Knock in the engine when driving at steady 50-60mph, car turned off with no audible noise, SES light on.
7. How did you determine what parts or parts failed? TBD
9. What fault codes if any showed up? TBD
10. Who fixed your VANOS issue? dealer
11. Cost to repair (details please): hopefully under warranty
13. Original owner? 3rd
14. Changed oil at what interval: 12k
15. Other comments or history of car - no problems prior to this
Can anyone help me out here. I still am under factory warranty until 11/10 of this year and have the extended third party warranty for extended coverage until 11/11. Would this problem be covered? They haven't told me yet, they said they need to daignose it first before they tell me exactly whats covered.
2005 SMG, Carbon Black Metallic with black interior, Cold Weather Package, Sports Package, Premium Sound, Navigation, 19" Rims, Bone Stock!
Jump to top MegamanDS is offline   Reply With Quote
Old Mon, Aug-16-2010, 02:02:55 PM   #19
drmudryk
Dr. Dan
Back to the top.....
Old Mon, Aug-16-2010, 05:56:30 PM   #20
MY02M3DINAN
MY02M3DINAN's Avatar
Reputation: 0 MY02M3DINAN is on a distinguished road
1. Year of Car: 2002
2. Current Mileage: 92,000
4. Mileage at failure or discovery: 68,000
5. Actual failure type; Still Unknown.
6. Symptoms of your VANOS issue: Excessive noise/knocking from vanos/valve cover area above 3000RPM.
7. How did you determine what parts or parts failed? Replaced/inspected EVERYTHING on the vanos and valve train.
9. What fault codes if any showed up? Rare: Intake cam Vanos retard 1
10. Who fixed your VANOS issue? Indy shop installed new Dr. Vanos. Knocking sound still present.
11. Cost to repair (details please): $2000 so far.
12. Track use? (none, a little, some, often) Little track use.
13. Original owner? No
14. Changed oil at what interval: 7500
15. Other comments or history of car: According to SIB 11 05 06 the noise is normal.
2002 TiAg M3 Cabriolet
Dinan S-M3 Kit
{Throttle Bodies/CAI/MAF/Stage 4 software}
Dinan Strut tower brace & Front sway bar
Auto Solutions SSK
UUC Motorwerks "Rasp-X" mid-pipe
Urethane RTAB's/FCAB's/RSM's
Hawk HPS Brake Pads
CDV delete
V1 Hardwired
THIS CAR IS NOW FOR SALE!
Jump to top MY02M3DINAN is offline   Reply With Quote
failure, gathering, information, poll, vanos
Discussing Poll ii: Vanos failure information gathering in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
