Old Sat, Aug-14-2010, 06:24:26 PM   #1
drmudryk
Dr. Dan
Reputation: 0 drmudryk is on a distinguished road
Default Poll ii: Vanos failure information gathering
This is the follow up poll to gain more specifics about the 33 failures listed to date on my previous poll. Thanks for your votes.
http://www.m3forum.net/m3forum/showthread.php?t=329790
Those whom have had vanos failure, please fill in the information and be as specific as you can.
Thanks again.
FOLLOWING POST WITH HAVE THE TEMPLATE... Please copy and paste the template below and fill out in a reply...
FOR SALE 2005 M3 SMG, PSS10, Borla Cat-Back, Turner Sway Bars, H&R Spacer F/R, Turner Bar links F/R, Turner camber plates, K&N Cold Air, Navigation.
I have my eyes on a 2008 M5. (I have kids)
http://www.m3forum.net/m3forum/showthread.php?t=329255
Jump to top drmudryk is offline   Reply With Quote
Old Sat, Aug-14-2010, 06:24:49 PM   #2
drmudryk
Dr. Dan
1. Year of Car:
2. Current Mileage:
3. Euro? U.S.? Canada?
4. Mileage at failure or discovery:
5. Actual failure type (solenoid, actuator, VANOS pump drive cog on exhaust cam gear, cam gear bolts, camshaft position sensor , other, or combination):
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?)
7. How did you determine what parts or parts failed?
8. Did you have dash warning lights show up?
9. What fault codes if any showed up?
10. Who fixed your VANOS issue?
11. Cost to repair (details please):
12. Track use? (none, a little, some, often)
13. Original owner?
14. Changed oil at what interval:
15. Other comments or history of car
Old Sat, Aug-14-2010, 06:34:19 PM   #3
drmudryk
Dr. Dan
Everyone who answered positively to the 1st poll has been PM'd. Look forward to seeing the results!
Old Sat, Aug-14-2010, 07:19:46 PM   #4
nolocontendere
nolocontendere's Avatar
Reputation: 0 nolocontendere is on a distinguished road
52,000 miles at failure (yes, 2K out of warranty)
Catastrophic failure (vanos exhaust gear lobe broke off and ran through timing chain and fragged valve cover
How I knew? smoke and oil everywhere
needed entire new vanos and exhaust gear and timing chain, etc.
many thousands of dollars to repair
some track use
BMW refused to goodwill (pieces of **** they are)
original owner
at that time was changing oil about every 7K
Jump to top nolocontendere is offline   Reply With Quote
Old Sat, Aug-14-2010, 07:39:01 PM   #5
170bpm
170bpm's Avatar
Reputation: 0 170bpm is on a distinguished road
2. 55,000 current miles
3. U.S.
4. 46,000
5. Cog on Cam Gear Failed
6. Symptoms were loss of power and SES light
7. Took my car to reputable BMW shop to find out diagnosis
8. SES light was the only warning light I got
9. Fault code was 184 Vanos
10. Strictly Bimmer in Mission Viejo, CA did the work
11. $2000 to fix
12. No track use
13. 3rd owner
14. Oil changed every 7,500
Here is the thread on my Vanos failure: http://www.m3forum.net/m3forum/showthread.php?t=312194
Jump to top 170bpm is offline   Reply With Quote
Old Sat, Aug-14-2010, 08:27:56 PM   #6
twboy1999
twboy1999's Avatar
Reputation: 0 twboy1999 is on a distinguished road
1. Year of Car:
2003.5
2. Current Mileage:
74000km
canada
68000km
I don't know
-idle drop coming to a stop, on 2 occasions the idle were extermely rough and sounded like tracker trailor
code
B8
48
yes and no
B8
48
-no one. Swaped for a used solenoid, that didn;'t do the trick. New vanos will be on in a few month. Was debating dr.vanos, however i think the acturator is not rebuilt, just the solenoid is new. I don't want to waste more time and money on labour. etc. . I just want to do it once and get it done
no track use
13. Original owner?
nope
the original owner didn't change the oil too often .. there was sludge built up. every 3000-3500km oil change since i got it
Jump to top twboy1999 is offline   Reply With Quote
Old Sat, Aug-14-2010, 08:40:03 PM   #7
jhanford1
Captain Parker
jhanford1's Avatar
Reputation: 0 jhanford1 is on a distinguished road
Originally Posted by drmudryk View Post
1. Year of Car: 2003.5
2. Current Mileage: 42k
3. Euro? U.S.? Canada? US
4. Mileage at failure or discovery: 40K
5. Actual failure type (solenoid, actuator, VANOS pump drive cog on exhaust cam gear, cam gear bolts, camshaft position sensor , other, or combination): No idea. Dealer said it was "bad" and needed replacement.
6. Symptoms of your VANOS issue (idle, roughness, noises, power loss etc…?) SES light, followed by limp mode. Dealer read the codes, cleared them, ran like a top. For 50 miles, then SES, limp mode, diagnosis of "bad"
7. How did you determine what parts or parts failed? Didn't
8. Did you have dash warning lights show up? SES
9. What fault codes if any showed up? Don't know exactly, Inlet something and Exhaust someting.
10. Who fixed your VANOS issue? Dealer
11. Cost to repair (details please): After a long battle with BMW NA & Dealer, covered under rod bearing recall warranty, as many here had done. Interesting that a member here emailed me his invoice, and under cost it showed "Warranty". Mine said Goodwill. Trying to nip it in the bud for further claims?
12. Track use? (none, a little, some, often) Not by me.
13. Original owner? Second owner
14. Changed oil at what interval: Not sure, but acceptable intervals for BMW NA otherwise no way they would have replaced it for free.
I bought the car from an indy dealer who said it was bought at an off-lease auction. Pretty sure they were full of it on that count, and pretty sure they knew about the VANOS issue. Should have joined M3F BEFORE buying and had a PPI done. Knock on wood, all has been fine since.
Jump to top jhanford1 is offline   Reply With Quote
Old Sat, Aug-14-2010, 11:19:05 PM   #8
JRM3
Reputation: 0 JRM3 will become famous soon enough
2. 84,100
3. U.S.
4. 83,700
5. VANOS gear bolts
6. Upon cold start up engine made marble type sound
7. checked the cam gear play
8. no
9. no
10. myself
11. 5 hrs labor, $100 parts
12. Some track use
13. 2nd owner
14. 7500
Jump to top JRM3 is offline   Reply With Quote
Old Sun, Aug-15-2010, 03:30:30 AM   #9
drmudryk
Dr. Dan
Bumping back up. Hope more of the PM's I sent fill this out. I know this is really early, but 2003.5 and 2004 looks like there was a bad man or robot on the engine building line, or some bad metal outsourced fabrication.
Old Sun, Aug-15-2010, 09:09:07 AM   #10
curtisG
Reputation: 0 curtisG has disabled reputation
2. 52,000 current miles
3. U.S.
4. 31,000
7. Local BMW stealership (car was still under warranty at the time)
9. Don't know, but dealer had problem identifying the problem at first (took several visits)
10. BMW of Fairfax VA
11. $0 (car was still under manufacturer warranty)
12. No track use
13. 2nd owner
2003.5 6MT Carbon Black + Cinnamon
Jump to top curtisG is offline   Reply With Quote
failure, gathering, information, poll, vanos
Discussing Poll ii: Vanos failure information gathering in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
