Old Fri, Sep-24-2010, 12:09:00 AM   #81
cscat87
cscat87's Avatar
Reputation: 0 cscat87 is on a distinguished road
Any update on BMW taking responsibility for this?
1997 M3 Coupe
2003 M3 Convertible
2003 M3 Coupe
2014 320i Jalopnik Edition
2011 Ram 3500
Jump to top cscat87 is offline   Reply With Quote
Old Fri, Sep-24-2010, 01:18:46 AM   #82
JRM3
Reputation: 0 JRM3 will become famous soon enough
They did absolutely zero on this. Called the dealer 2X and BMW NA 1X.
Jump to top JRM3 is offline   Reply With Quote
Old Fri, Sep-24-2010, 01:25:05 AM   #83
cscat87
cscat87's Avatar
What were there responses? What about from the lawyers who took care of the subframe issue? Is anybody following up? It seems like this is too common of a matter to just let go.
1997 M3 Coupe
2003 M3 Convertible
2003 M3 Coupe
2011 Ram 3500
Old Sun, Sep-26-2010, 01:04:30 AM   #84
JRM3
Response from the dealer who contacted the area BMW rep was "yes we've seen this before".
Response from BMW NA, "thank you for informing us of this issue I'll pass it along".
I spoke with my attorney and he told me that unless you can find a lot of people who have had the EXACT same issue then there isn't really much there. The key emphasis is exact, meaning broken vanos gear bolts, and to my knowledge there has only been 3-5 that I'm aware of.
Old Wed, Oct-27-2010, 11:33:02 PM   #85
nschmdbrg
Reputation: 0 nschmdbrg is on a distinguished road
subscribed..
Jump to top nschmdbrg is offline   Reply With Quote
Old Sun, Dec-05-2010, 05:29:43 PM   #86
live2race
Reputation: 0 live2race is on a distinguished road
Default DIY mechanics are lucky when they don't bend valves
Yeeeeeee Hawwwwwwww as they say in TX.
Re assembled everything and cranked up the car. Runs like a champ and NO CEL's!!
I let it idle for about 10 minutes and purred like a kitten.
It's still on jack stands so I haven't driven the car on the street. I'll get to street driving this week and will post any changes etc...
JRM3, you must have the angels on your side! Had my indy shop with about a 100 years combined BMW experience replace my 12 bolts (even though the originals turned out to still be tight), the exhaust (outlet) cam gear which had sheared off one of the tabs that drives the vanos oil pump, and the vanos with one rebuilt by Dr. Vanos. Even using all the specified tools to lock the cam, etc., and turning the engine by hand before starting it, they bent all 12 exhaust valves at start-up. The whole repair was billed at $7624 of which the shop ate all but $2490 (and that includes a Level I Inspection, replacing the bolts and the cost of the rebuilt vanos). I bought a practically new exhaust cam gear on this forum for $300 and the buyer threw in a vanos which I traded along with the original off the car to Dr. Vanos for core charges. I think the way the shop explained the mistake to me was that apparently they installed the helical gear into the cam gear one tooth off. The shop had heavily researched the repair with other professionals and found lots of ambiguity in the service bulletins and among the mechanics about how to align everything during reassembly. They've definitely got the procedure down pat now if anyone in SE VA wants a referral.
Jump to top live2race is offline   Reply With Quote
Old Sat, Dec-24-2011, 07:28:39 PM   #87
Dato513
Reputation: 0 Dato513 is on a distinguished road
Default Re: Vanos bolt failure, vanos gear, videos & pictures
I agree BMW North America must take responsibility for bad parts. I just ended up doing a complete engine swap on my 2002/M3/SMG/86,xxx miles due to intake cam gear bolt failure that ran me over $10000.00. Unfortunately in my case all 6 bolts broke off and pistons came in contact with valves so I had to go with a swap. From reading up on the issue it looks like a large amount of S54 engines have the same problem. How can BMWNA get way with acknowledging that the bolt are no good and replacing them at the parts department but not doing a recall after so many of their loyal customers are having issues. If anything comes of this please advice I did keep all my receipts and I would love to sign the petition if one comes up. I love my M but I am not sure if i can do this again... it is not a cheap car to work on especialy if you live in Alaska....
Jump to top Dato513 is offline   Reply With Quote
Old Sat, Dec-24-2011, 10:44:11 PM   #88
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
vanos
Old Mon, Dec-26-2011, 04:53:40 PM   #89
cold m3
___///M3___
cold m3's Avatar
Reputation: 0 cold m3 has disabled reputation
i cross my fingers everyday that this doesnt happen
Photos of My ///M3
Jump to top cold m3 is offline   Reply With Quote
Old Sat, Dec-13-2014, 03:49:03 AM   #90
M3Gage
Reputation: 0 M3Gage is on a distinguished road
Old thread I know but this just happened to me, 4/6 bolts sheared on the intake cam gear. Lucky to catch it now
Jump to top M3Gage is offline   Reply With Quote
bolt, failure, gear, pictures, vanos, vanos bolt failure, vanos failure, vanos issues, videos
Discussing Vanos bolt failure, vanos gear, videos & pictures in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
