Old Mon, Jan-20-2014, 09:14:12 PM   #11
bzsbimmer
Reputation: 0 bzsbimmer is on a distinguished road
South Korea
Default Re: VANOS Nitrogen Charged Accumulator, shouldn’t we be servicing this?
For those that have done a VANOS job where pressure had to be relieved or an SMG job where pressure had to be bled, there must be a reference on how to recharge it.
I have not seen one which leads me to believe it's not nitrogen based.
29 to 43 Bar is 421 to 624 PSI
Helping the economy one mod at a time
Alpine E90 M3
Jump to top bzsbimmer is offline   Reply With Quote
Old Mon, Jan-20-2014, 09:22:46 PM   #12
dafoe
dafoe's Avatar
Haven't seen anything about recharging. Would just assume it's replaced.
But, have a read here on the vanos section. It talks about how it's nitrogen based.
http://www.google.com/url?sa=t&rct=j...59568121,d.cWc
Old Mon, Jan-20-2014, 09:31:45 PM   #13
bzsbimmer
South Korea
Good read!
I'd love to see a x-cut unit to see inside. These are much smaller than the accumulators we have in our hydraulic systems... that's for sure.
Alpine E90 M3
Old Mon, Jan-20-2014, 11:34:22 PM   #14
nowanker
"He's no wanker!"
Never investigated it... Early 5/6/7 series cars that used P/S pump pressure for brake assist (the "H-31" system) had a similar nitrogen charged pressure reservoir for engine-off brake boost. They required no service, and were supplied fully charged as replacements. They did fail, and it was easy to tell, not only by the lack of assist with the engine off, but also by lag in the boost if you nailed the pedal.
Would a failed vanos accumulator similarly result in sluggish vanos action?
Old Tue, Jan-21-2014, 12:56:54 AM   #15
kuksul08
Maybe it's just like the nitrogen reservoir on a shock? You can run those basically forever without replacement. It's the seals that wear out in that case.
Old Tue, Jan-21-2014, 02:21:18 AM   #16
RedM3/4
No expert, but seems unlikely. Pressure almost certainly bleeds down after the car is off. Not the accum/charge in it, rather other seals/pumps in the system will leak down to "exhaust", aka tank pressure, in this case the oil pan.
An accumulators normal job is to fulfill an initial extra surge in the need for pressure; they in essence store energy.
Think of it as a buffer in the event the vanos is quickly actuated many times in a row where the vanos pump may not quite keep up with the load, maybe like revving the engine up and down all the way through the actuation range of advance/retard several times (can't think of a track or street scenario but you get the idea).
ADS
Originally Posted by dafoe View Post
After talking to some folks, reportedly this just pre charges the vanos system when or prior to starting the car, after that the pressure is maintained by the pump and pressure regulator. Apparently they don't need re filled.
Old Tue, Jan-21-2014, 03:16:15 AM   #17
Hacksaw
What broke now?
Hacksaw's Avatar
Reputation: 0 Hacksaw is on a distinguished road
Since there are no provisions to service said accumulator I feel BMW intended it to be lifetime. Now what that lifetime is remains to be seen.
I have however added the oil line going to this accumulator as a service item to any vanos rebuilds I perform. Here in Texas at least the lines are really starting to show signs of heat breakdown. There is a steel braided section near the accumulator that seems to bake rather nicely. YMMV
'02 BMW ///M3
Imola Red|Blk Cloth|6MT|FS CSL Custom TUNE -MSS54HP|CSL Replica Airbox|Euro Headers|BimmerWorld 3.5" race front Y and resonator|Hacksaw's custom 3.5" SS exhaust system w/Magnaflow and 4 tipped goodness|SGT RS-ENR Coilover Kit|Evo Sport Performance Pulley Set|CDV Delete|UUC USS & DSSR|Sparco Roadster Seats|StopTech ST-40 BBKs on all 4|Beisan Systems vanos rebuild w/original stock exhaust hub|Kirk 4 point roll bar|CF CSL Rep Trunk|GC Race F/R Sway Bars|TR Motorsports MT-1|Avin Avant 2|Seibon CF GTR Hood
Jump to top Hacksaw is offline   Reply With Quote
Old Tue, Jan-21-2014, 03:22:01 AM   #18
driller
your hole is our goal
driller's Avatar
Reputation: 0 driller is on a distinguished road
I have seen hydraulic accumulators in my hydraulic systems on my drill rigs
They can be recharged at a hydraulic shop
Over the years they do tend to lose its charge
Sent from my SGH-I547C using Tapatalk
Jump to top driller is offline   Reply With Quote
Old Tue, Jan-21-2014, 03:55:34 AM   #19
RedM3/4
I've not seen this one specifically, have seen the SMG accum. Looking at realoem.com, the vanos accum likewise seems to have one opening, and no way to be dis-assembled. I'd estimate it to be about 8oz in size. It is possible there's a way to put a syringe in and charge it somehow; after all, it had to be charged initially. It occurs to me they may have a bladder versus a simple o-ring, but this is totally speculative.
But I don't think it is directly comparable to the gear you see on a large rig, or in my case, what I've seen in machine tool systems.
ADS
Old Tue, Jan-21-2014, 06:31:39 AM   #20
bzsbimmer
South Korea
ADS
This was my thought about a bladder system. Our hydraulic systems, probably much like Drillers, are large piston units for high pressure die casting. Our hydraulic pressure units for our CNC machines are much smaller however I don't have much knowledge of their inner workings.
For some reason I keep thinking about the SMG pressure system vs the original topic of VANOS high pressure accumulator
Alpine E90 M3
accumulator, charged, nitrogen, servicing, shouldn’t, vanos
Discussing VANOS Nitrogen Charged Accumulator, shouldn’t we be servicing this? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
