Old Fri, May-22-2009, 08:10:51 PM   #101
nyprober
Reputation: 0 nyprober is on a distinguished road
Luis,
About 4 or 5 posts back I detailed how to take the adjusting unit and sealing plate off. Let me be a bit more clear: when unscrewing the allen bolts, screw them COUNTERCLOCKWISE to loosen, then clockwise to tighten during reassembly.
C'mon man, it's not hard Go out and do it. Just try to keep things clean, and keep junk out of the oil ports that you will see in the adjusting unit.
James
Jump to top nyprober is offline   Reply With Quote
Old Fri, May-22-2009, 09:25:17 PM   #102
huhhuhwha
hater
huhhuhwha's Avatar
Reputation: 0 huhhuhwha is on a distinguished road
Nicaragua
that would be awesome if someone would did a DIY(step by step) for this.
Jump to top huhhuhwha is offline   Reply With Quote
Old Fri, May-22-2009, 10:28:23 PM   #103
King Luis
Porsche Fanboi
King Luis's Avatar
Reputation: 0 King Luis is on a distinguished road
Originally Posted by nyprober View Post
Luis,
James
ya, i read the first half of the post...missed the second half.
2015 Ducati Monster 821 Dark
2013 Volkswagen Golf TDI Wolfsburg Edition
Sold: 2004 BMW M3 Coupe.
My Flickr
Jump to top King Luis is offline   Reply With Quote
Old Thu, May-28-2009, 08:57:47 AM   #104
jakedasnake1
jakedasnake1's Avatar
Reputation: 0 jakedasnake1 is on a distinguished road
First of all please do this with a cold engine. A little oil will come out and will burn the crap out of you and the vanos unit stays hot for a long time. (Learned this first hand)
You will first need to take out the left side of the plastic black fan shroud. There are two pins/clips that you will need to take out to remove this. Next take out the 5 hex bolts from the top of the VANOS. That will allow the solenoid to drop down which should allow the sealing plate to slide out. If you want to you can unplug the wires from the left side and remove the entire solenoid unit for better cleaning, but I was in a hurry and just simply slid out the old plate, wiped the oil from the solenoid and slid the new plate in its place and bolted the thing back on. Put your fan shroud back on and fire her up! If you have any other questions let me know.
Options & Mods:
2002 Carbon Black/Cinnamon \ 6MT \ Prem/Cold Wx Pkg \ 19" OEM \ K&N Intake \ Painted Reflectors \ Smoked Corners \ UUC Aluminum Pedals \ Axxis Ultimate Pads \ Power Slot Cyro Rotors \ Interior Xenon Kit
Jump to top jakedasnake1 is offline   Reply With Quote
Old Thu, May-28-2009, 12:03:06 PM   #105
mills84
Reputation: 0 mills84 is on a distinguished road
I swapped out that little filter last weekend and it had alot of debris for 40k miles.
Jump to top mills84 is offline   Reply With Quote
Old Fri, May-29-2009, 02:33:21 AM   #106
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Quick question, I replaced the filter cartridge (#4) and the bigger rubber o-ring (#6); I also bought the smaller o-ring (#5) however I fail to see where that one goes on my pressure valve. There's no room for it nor was there an "old" one anywhere on the vavle. Any comments?
Old Fri, May-29-2009, 03:04:40 AM   #107
beemerb0y
beemerb0y's Avatar
Reputation: 0 beemerb0y is on a distinguished road
Armenia
i had the same problem.. go back and read the last 2 pages. they explained how to change it, i still dont understand it, so i said F it. im sure it wont make ANY difference if that little thing is new or not
2002 Titanium Silver M3, topless, SMG - Current
2006 Jet Black M3, SMG, Competition Package - Sold
2003.5 Phoenix Yellow M3, 6 speed - Sold
2002 Titanium Silver M3, SMG - Sold
Jump to top beemerb0y is offline   Reply With Quote
Old Fri, May-29-2009, 03:23:46 AM   #108
mrtt
mrtt's Avatar
Reputation: 0 mrtt is on a distinguished road
so you just re-used the o rings and replaced the filter only?
Jump to top mrtt is offline   Reply With Quote
Old Fri, May-29-2009, 05:39:11 AM   #109
kaiv
kaiv's Avatar
France
Thanks. Looks like we have the same stuff. I too have some kind of washer made of hard plastic there, not a rubber o-ring. I don't see it being a problem at all. My car is an 01 FWIW, maybe they changed things over the years.
Old Fri, May-29-2009, 01:29:01 PM   #110
Mr.G3
Resident User
Mr.G3's Avatar
Reputation: 0 Mr.G3 is on a distinguished road
I believe a good soul should recollect all the additional useful information provided here and produce a step by step DIY with pics to clarify any doubts - I personally like pictures when it comes down to DIYs and parts. There is a lot of trial/error feedback in this thread that supplements Tonester's original post that should contribute to an excellent DIY
Now, all we need is a good soul with enough time and patience in his hands!
Jump to top Mr.G3 is offline   Reply With Quote
$30, insurance, unit, vanos
how much for a new vanos unit andyh M3Forum Welcome Center 1 Mon, Mar-24-2008 12:36:27 PM
Vanos unit??? H Bomb E46 M3 (2001-2006) 11 Fri, Apr-14-2006 02:40:15 AM
94 m3 vanos unit gordie E36 M3 (1992-1999) 0 Sat, Jan-11-2003 06:23:23 PM
94 m3 vanos unit gordie E46 M3 (2001-2006) 0 Sat, Jan-11-2003 06:07:50 PM
94 m3 vanos unit gordie E46 M3 (2001-2006) 0 Sat, Jan-11-2003 06:01:00 PM
Discussing $30 insurance for your VANOS unit. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
