Old Sat, Sep-15-2018, 09:18:51 PM   #1
apeters912
Reputation: 0 apeters912 is on a distinguished road
Default Help, Mid Rod-Bearing DIY, How much play is too much play?
Hello All,
I am currently in the middle of a rod bearing DIY on a 2003 e46 m3 (160k miles). I have been following the links below for reference.
http://www.m3forum.net/m3forum/showthread.php?t=455681
http://www.m3forum.net/m3forum/showthread.php?t=558412
Upon going through the second set of torque-ing on cylinder one, I noticed the new bearing also feels loose, though better than before the bearing was replaced. I imagine this is a sign of engine wear. How much play is too much play? Should I continue with the install? What would you guys recommend? While it isn't ideal is this within tolerance?
https://www.summitracing.com/parts/k...77xp/overview/
See video below:
Perhaps the last round of torque will help.
2003 E46 M3 Silver-Grey 6spd Manual, 19" Staggered VMR VB3, Vogtland Sport Springs, Cat-less Headers, Derlin Billy Club Shifter, BMC Performance Air Filter, CCFL Angel Eyes, Rear CSL CF diffuser, CSL front bumper, Stoptec Stage II Big Brake Kit.
Jump to top apeters912 is offline   Reply With Quote
Old Sat, Sep-15-2018, 09:53:17 PM   #2
rbmwiv
rbmwiv's Avatar
Reputation: 0 rbmwiv is on a distinguished road
Default Re: Help, Mid Rod-Bearing DIY, How much play is too much play?
Plasticuage and visual inspect when you remove the cap to plastiguage measurements -0.00031, +0.00031
Jump to top rbmwiv is offline   Reply With Quote
Old Sun, Sep-16-2018, 08:36:37 AM   #3
mrgizmo04
mrgizmo04's Avatar
Is that the new bearing clearance hitting the crank or is that a loose endcap on the rod? Last round of torque could help if you have not gone through the final angle torque step, since the bolts yield and elongate.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, Sep-17-2018, 12:40:30 AM   #4
digger
Once the cap is on whether you put 5 or 50ftlb you won't feel a difference. I suspect you might be detecting the axial play but the video is hard to tell. You need to plastigage to tell you what's going on
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Old Mon, Sep-17-2018, 03:01:17 PM   #5
fastmonbbs
Reputation: 0 fastmonbbs is on a distinguished road
Measure the crank and get the right bearings for your measurement. BMW sells 3 different ones. Yellow, green and red
///M...Nur Fliegen ist SchŲner
Jump to top fastmonbbs is offline   Reply With Quote
Old Mon, Sep-17-2018, 04:54:36 PM   #6
M3AZ
///M3AZ
Reputation: 0 M3AZ has disabled reputation
Originally Posted by apeters912 View Post
$150 for rod bearings? What's the catch?
████████████████████████ 2003 E46 M3
Old Mon, Sep-17-2018, 05:01:45 PM   #7
rbmwiv
rbmwiv's Avatar
Plastiguage is cheap and will tell you exactly what your clearance is. The instructions on how to use it are on the package it comes in a lot of different sizes. So get the size thatís going to fit what your specified clearance is. If itís too tight you may have wrong bearings also if itís loose they are either too big or the crank is worn and needs re grinding.
Old Wed, Sep-19-2018, 11:11:13 AM   #8
digger
According to realoem its blue and red for upper and lower
1996 e36 M3 Evo
Discussing Help, Mid Rod-Bearing DIY, How much play is too much play? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
