View Poll Results: Your E46 M3 Original Clutch has how many miles on it?
Less than 89k 28 34.15%
Between 90k and 119k 15 18.29%
Between 120k and 149k 33 40.24%
Greater than 150k 6 7.32%
Voters: 82. You may not vote on this poll
Old Sun, Jun-15-2014, 11:52:37 AM   #31
cruizer97
cruizer97's Avatar
Reputation: 0 cruizer97 is on a distinguished road
Jamaica
Default Re: E46 M3 Clutch Life
6MT and just hit 100k on the original. No slipping but bearing makes very low noise when my clutch is not depressed, I only hear it when inside a garage (enclosed area). Not really worried about it. I can chirp 2nd gear still, great feeling lol.
-Ray
Jump to top cruizer97 is offline   Reply With Quote
Old Sun, Jun-15-2014, 12:51:52 PM   #32
I replaced mine at 100,000 for giggles, but it was a waste of money/time-- it wasn't even half used up yet.
6mt driven HARD.
Old Sun, Jun-15-2014, 01:05:21 PM   #33
niart906
Reputation: 0 niart906 is on a distinguished road
190k miles on my original clutch.
Current Car:
2013 F30 335i Estoril Blau II/Black
Previous:
2006 E60 M5 Silver-Gray/Indy Red
2003 E46 M3 Jet Black/Cinnamon
Jump to top niart906 is offline   Reply With Quote
Old Sun, Jun-15-2014, 05:32:11 PM   #34
playskool1
NorCal's S54 VANOS/Valve Adjust./Rod Bearing spc.
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
177k on my original clutch. The clutch disc decided to go out on me at Thunderhill track day.
Sent from my iPhone 5S using Typotalk
01/01 build date[LSB][Cinn.][6 Spd.]MAXIMUM PSI TURBO 14psi PT6266 [230k total miles][original motor]
[115k supercharged miles][17k E85 miles][9k turbocharged miles][1.9k track miles]
INSTAGRAM: @skweakykleen
Full Beisan VANOS overhaul, TMS Subframe Reinforcement, WPC rod bearings = bulletproof
fully built S54 w/ Precision 6870 coming soon!
Jump to top playskool1 is offline   Reply With Quote
Old Wed, Jun-18-2014, 01:13:58 AM   #35
edips
Reputation: 0 edips is on a distinguished road
My mechanic says 130 to 150k. Can't compare, I'm at 51k. I'd start worrying at 130, myself.
Jump to top edips is offline   Reply With Quote
Old Wed, Jun-18-2014, 02:34:38 AM   #36
bimmerfan08
bimmerfan08's Avatar
I'm almost at 150k miles. Clutch still engages just fine.
Old Wed, Jun-18-2014, 03:42:22 AM   #37
M3Dom
M3Dom's Avatar
Reputation: 0 M3Dom is on a distinguished road
Mine parted at 80k when I boosted it.
https://www.instagram.com/d_sicily/
Porshapwr:I thought every day was steak and BJ day?
Ghost : "She'll prolly suck your balls so hard they'll hatch"
Ben Z.;The Ultimate Driving Simulation Machine
LALaw :OP has been surprised by everything that's happened since the 13th Amendment
Cars : some verts some bikes and a 2012 veyron
Jump to top M3Dom is offline   Reply With Quote
Old Tue, Jun-24-2014, 12:43:18 AM   #38
uscbeemerM3
uscbeemerM3's Avatar
Reputation: 0 uscbeemerM3 has disabled reputation
139k, I'm mostly freeway with little traffic during the weekdays.
Current Car; 2008 S63 AMG. Still active on m3f, benz forums are empty.
Sold to my cousin; 2005 SMG II. Imola Red Inside
Koni Yellow struts/shocks with stock springs. M Track Mode (with M Track Mode light in the cluster),
CSL factory software via autologic (launch control is at 4800rpm), genuine CSL sway bars; front (30.8mm/hollow/8lb) and rear (22.5mm/solid/8lb), brake light mod all LEDs enabled when braking.
Jump to top uscbeemerM3 is offline   Reply With Quote
clutch, e46
Discussing E46 M3 Clutch Life in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
