Old Thu, Sep-10-2009, 02:47:31 AM   #1
parad0x
E46 M3 Jet Black 6spd
Reputation: 0 parad0x is on a distinguished road
Default Troubleshooting the Clutch Fan E46 M3 2002 75k miles
Hey there guys, before I go in to replace my belt tensioner I wanted to troubelshoot my clutch fan which I think might possibly be faulty. Just want to state a few facts, and hopefully i can hear some of your guys thoughts on em.
After a 30 minute drive mixed highway/city, in 16 celcius/43 Farenheit temperature.
-With the engine fully cold and off, I give the fan a good spin and it probably turns about 1.5 full turns before stopping, very little resistance.
-With the engine cold, but runnin I use a magazine and can fully stop the fan.
-with the engine hot, and running I am able to stop the fan.
-When turning off the engine while hot, the fan spins by itself for about 4 seconds before coming to a complete stop.
-With a fully warmed up hot engine, and off, I am able to get about 3 full spins on it before it stops very little resistance.
Now my thoughts are that the clutch fan is faulty, I believe the resistance on the fan spinning is suppose to go up quite a bit when it is fully warmed up correct? In that with the engine off, the fan should maybe turn 1/3 the way and stop? 30 minute test drive should be plenty correct? But if it is faulty, then why isint it seized? wouldn't a clutch fan start to increase steadily in resistance ?? I mean mine is doing the exact opposite and the resistance is decreasing whats happening with it?
Jump to top parad0x is offline   Reply With Quote
Old Thu, Sep-10-2009, 02:51:42 AM   #2
deilenberger
deilenberger's Avatar
What happened to it is the coupling fluid has leaked out. The fan uses a temperature controlled viscous clutch (google it..) Think of how an automatic tranny torque converter works.. then think of a temperature controlled passage for the coupling fluid between the converter vanes..
Anyway - it's a common failure mode. It's actually fairly rare for them to lock up.. they do that if the bearing goes bad. More often - it fails just like you've described.
  • 2011 Lexus RX-350. SWMBO's toy.
Old Thu, Sep-10-2009, 03:20:00 AM   #3
parad0x
ahh I guess i'll be needing to replace the fan coupling in that case... realoem says 11527831619 is the p/n# so guess i'll be ordering that, thanks for your very descriptive reply it gave me good insight as to what happened.
I guess while I am at it, is there any point in replacing the water pump or the thermostat? I heard the thermostat is electronic, so I would imagine any problems with the water pump/thermostat would throw a code right?
If there is a way to truobleshoot a water.pump would appreciate any feedback, I dont see any leaking of coolant fluid though. I will be doing the work myself as I do have a 32mm wrench/long screwdriver to hold the w.pump pulley, I will probably take this opportunity and replace the coolant though and my faulty hydraulic belt tensioner/pulley.
Old Thu, Sep-10-2009, 03:24:31 AM   #4
Function7
Function7's Avatar
Reputation: 0 Function7 is on a distinguished road
Your fan clutch sounds like it's gone.
Just replaced my fan clutch a month ago - don't go with the OEM unit - the "standard" Behr ones are supposedly more prone to failure than the Sachs clutch (alternative OEM part).
You may find this helpful:
http://www.m3forum.net/m3forum/showthread.php?t=281168
...but you'll probably want to skip the part about the motorsports thermostat unless you're in a really hot area.
-A
Function7 Engineering
Queen Creek, AZ
Jump to top Function7 is offline   Reply With Quote
Old Fri, Feb-17-2012, 07:30:21 PM   #5
SDpnoy
E46 01' 330ci, 05' M3
SDpnoy's Avatar
Reputation: 0 SDpnoy is on a distinguished road
Default Re: Troubleshooting the Clutch Fan E46 M3 2002 75k miles
Thanks for the info
Jump to top SDpnoy is offline   Reply With Quote
2002, 75k, clutch, e46, fan, miles, troubleshooting
Discussing Troubleshooting the Clutch Fan E46 M3 2002 75k miles in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
