Old Wed, Dec-11-2019, 02:30:50 PM   #1
MTiz
Reputation: 0 MTiz is on a distinguished road
Default Would you sacrifice transmission choice for Color Combos/Options?
I was asking myself this while browsing autotrader. With manual swaps being more common, and assuming both cars have a very good service history, would y'all pick an SMG in your dream color/dream options over a black/silver/grey manual stripper?
Recently found a 1 owner LSB/Grey car with 70K miles, but it's SMG. Very tempting
Jump to top MTiz is offline   Reply With Quote
Old Wed, Dec-11-2019, 02:54:14 PM   #2
Default Re: Would you sacrifice transmission choice for Color Combos/Options?
Never
Edit: to be fair, I didn't read the post, just the title. If a manual swap is possible, that's a diff story, but would never not own a manual just to satisfy a color desire.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · zero options · ~3100lbs · JOURNAL
Evolve-R Alpha N · Evolve CF CSL Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 2.5" sect 1 · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pulleys/fan delete · CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs · Hotchkis front sway · F & R strut bars · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk · Cobra Nogaros + BK + manual OE bases · TMS black pedals · Sportline 8S 18"x 8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 345mm CSL + Textar & 328mm CSL + ATE · ZHP "712" rack
DD: 2012 TiAg/Blk 128i · N52 · ULEV · Slicktop · 6MT · manual heated seats
Eibach springs & sways · Koni STR.T · Whiteline SF bushes · Dinan camber plates · M3 FCAs
Old Wed, Dec-11-2019, 02:57:20 PM   #3
Cubieman
Cubieman's Avatar
Reputation: 0 Cubieman is on a distinguished road
Nope.
Jump to top Cubieman is offline   Reply With Quote
Old Wed, Dec-11-2019, 03:04:34 PM   #4
Steve M3
Yes, because it's a non-issue these days with manual swaps being so common and well documented.
Jump to top Steve M3 is online now   Reply With Quote
Old Wed, Dec-11-2019, 03:06:51 PM   #5
yhp2009
yhp2009's Avatar
Reputation: 0 yhp2009 is on a distinguished road
It was non-negotiable for me.
But it really depends on your personal preference. If the smg is not a big dealbreaker for you then smg is something you can try.
Jump to top yhp2009 is online now   Reply With Quote
Old Wed, Dec-11-2019, 03:12:50 PM   #6
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Only with the intention of swapping to manual. Mine is ~1 of 5 IIRC, so transmission was not something I had much choice in initially.
911 Journal/Build Thread
Old Wed, Dec-11-2019, 03:15:27 PM   #7
yhp2009
yhp2009's Avatar
Also imo i dont think its ever wise to buy something that "aint broke" and "fix it". If you want a manual you should probably just get a manual
Old Wed, Dec-11-2019, 03:21:09 PM   #8
albino09
Engineer
With that mileage, history, and how accessible the manual swap seems to be, I'd say do it. Similar to you I pulled the trigger on my car because of its proximity and mileage (39k when I found it) and everything else was less important. If I could do it again, the only feature I'd look harder for would be a slick top.
Jump to top albino09 is online now   Reply With Quote
Old Wed, Dec-11-2019, 03:21:30 PM   #9
Texaz3
I would. But I also don't care for 6MT and actually prefer an SMG in E46M.
Old Wed, Dec-11-2019, 03:22:20 PM   #10
In an e46 where the manual swap is cheap and easy? Sure. Most other cars no.
Discussing Would you sacrifice transmission choice for Color Combos/Options? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
