Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted > E36 / E30 - Parts for Sale/Wanted
E36 / E30 - Parts for Sale/Wanted Use this section to post parts for sale or wanted that are related to the E36 or E30 only.
Old Sun, Jul-23-2017, 01:54:59 AM   #1
greenlantern181
Reputation: 0 greenlantern181 is on a distinguished road
Default E36 KW V3's - NEW - Still in box
Full KW V3 Coilover kit for an E36 - new - never installed - not even removed from oringinal box. This kit normally retails for near $2,000.00. This kit can be purchased for $1,450 for local pickup in the LA area or $1,525 shipped anywhere in the U.S.
This kit uses progressive rate springs in the rear, and linear in the front, with infinately adjustable and rebound damping. So, you can slam it on the street without a harsh, stiff ride. The KW V3 is also suitable for track use.
TECHNICAL DETAILS
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by KW engineers. Independently adjustable damping technology - rebound and compression damping.
Height adjustable front and rear axles (front axle threaded strut housings, rear axle adjustable springs + dampers).
Lowering front = 0.8 to 1.5 inches and rear = 0.8 to 1.5 inches. Spring rates are progressive front and rear.
Inox-line stainless steel technology
Individual height adjustment
German TUEV-tested adjustment parameters
High-quality components for long life
Comprehensive documentation
Infinitely adjustable rebound damping
14- level adjustable compression damping
Unique, independently functioning damping power adjustment
This kit is for a non M, but can be used on a M with non M sway bar links.
Jump to top greenlantern181 is offline
Rate Seller View Rating
Old Sun, Jul-23-2017, 05:35:04 AM   #2
bluptgm3
Default Re: E36 KW V3's - NEW - Still in box
If these fit a Coupe, then they fit a Sedan.
Old Sun, Jul-23-2017, 04:12:54 PM   #3
greenlantern181
I know this. I copied that from KW. Don't know why they said that. I'll fix it.
Jump to top greenlantern181 is offline   Reply With Quote
Old Sat, Jul-29-2017, 09:00:24 PM   #4
dkirvida
Reputation: 0 dkirvida is on a distinguished road
Negotiable at all? I'm located in Costa Mesa
Jump to top dkirvida is offline   Reply With Quote
Old Mon, Jul-31-2017, 05:53:03 AM   #5
greenlantern181
Maybe a little. I'll PM you.
Old Mon, Aug-07-2017, 06:08:20 AM   #6
greenlantern181
Price drop!
Discussing E36 KW V3's - NEW - Still in box in the E36 / E30 - Parts for Sale/Wanted Forum - Use this section to post parts for sale or wanted that are related to the E36 or E30 only. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
