Old Sat, May-27-2017, 06:13:04 PM   #1
crisis1231
Reputation: 0 crisis1231 is on a distinguished road
Default M3 e46 ZCP wheels for 330ci
Hey everyone!
I tried using search bar and had no luck finding this. Can I fit m3 ZCP wheels on my 2001 (pre-facelift) 330ci? If so which sizes should I buy to get them to fit?
What other modifications would I need to consider.
Please let me know and thanks in advance!
Jump to top crisis1231 is offline   Reply With Quote
Old Sat, May-27-2017, 10:40:43 PM   #2
akagc
Reputation: 0 akagc is on a distinguished road
Default Re: M3 e46 ZCP wheels for 330ci
I tried my m3 zcp wheels on the my zhp while on jack stands and didn't like so I didn't bother checking for fitment. Just looked a bit off as the m3 zcp wheels have an aggressive offset (19s and wider tires) compared to the the 330 which runs on 18s with the 135m wheels... but again I'm not sure since I didn't drop it down to the ground to see. All I've seen with what you're looking for were CSL replica wheels.
It's probably a good idea for look for this answer on e46fanatics.com... there are a lot more 330i and 330ci owners there that may have done this mod that could help you.
I have an 04 330i zhp and imo the 135m wheels that come with the zhp from the factory are the best oem wheels for the 330, esp on on the coupe, so I kept them. Anything else looks a bit off because of the less aggressive front and rear fenders.
135M on a zhp Coupe (A guy I know):
135M on a zhp Sedan (mine):
- 04 Silver (tiag) ZHP 330i
- 06 Silver Grey ZCP M3
- 02 Black Civic. Beater
Jump to top akagc is offline   Reply With Quote
Old Sat, May-27-2017, 10:56:13 PM   #3
mrfuzzybagels
(❍ᴥ❍ʋ)
mrfuzzybagels's Avatar
Reputation: 0 mrfuzzybagels is on a distinguished road
Rears won't fit without rolling fenders and even with rolled fenders will probably rub. You can run 4 fronts or better yet just get csl reps in compatible sizes.
Jump to top mrfuzzybagels is offline   Reply With Quote
Old Sat, May-27-2017, 11:38:05 PM   #4
PITT M3 RR
PA
PITT M3 RR's Avatar
I'll trade you 2 fronts for your 2 rears? Win win? Pm me
S54 E36 BUILD
Old Sun, May-28-2017, 01:28:33 PM   #5
crisis1231
Thank you everyone! I haven't bought them yet but I was thinking about running two fronts if necessary. I just wanted to get all the details out of the way before I made a purchase. I'll try at e46fanatics maybe they have a thread about this.
Old Mon, May-29-2017, 05:08:16 PM   #6
Edgy
Constantly Learning M3 and M5 Owner
Edgy's Avatar
Reputation: 0 Edgy is on a distinguished road
Love my wheels, but dirty little secret -- 18s would make for a better street ride. I used to have 18" CSL wheels from Velocity Motoring on my E36 -- good wheel if you decide to go reps.
The stock front tire size is 225, but if you go four fronts with same size all around you might be able to go larger. Not sure on clearance with the 330.
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Jump to top Edgy is offline   Reply With Quote
Old Mon, May-29-2017, 09:43:42 PM   #7
crisis1231
Do you know the exact width and offset I would need to get if I buy the 18s or the 19s. I will likely try to find a good deal on either and snatch either one up.
Old Mon, May-29-2017, 10:13:08 PM   #8
Edgy
Edgy's Avatar
I think a good place to start would be what the E46 330 ZHP came with stock. That would be 225/40/18 front and 255/35/18 rear. In this case the rears are 8.5 wide, fronts 8. Offset 47 front and 50 rear.
Like I said -- starting point. You've got options, and there are reasons not to go staggered. Decide what you want and confirm all the numbers before spending any money. TireRack is good source of info for fitment. Good luck!
BLUE HEAVEN:
Old Tue, May-30-2017, 12:17:39 AM   #9
crisis1231
Thank you very much for letting me know! I will do some more research before I decide exactly what I want to go with. I am leaning towards 18s just to keep ride comfort, but I will see what I end up with.
Old Tue, May-30-2017, 01:04:32 AM   #10
Tove
They See Me Rollin'
Tove's Avatar
Reputation: 0 Tove is on a distinguished road
The 135m's look legit
BMW Enthusiast since 1987 | Tove aka Genuine
Jump to top Tove is offline   Reply With Quote
Discussing M3 e46 ZCP wheels for 330ci in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
