Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > F80 M3 (Sedan) / F82 M4 (Coupe) / F83 M4 (Convertible) : (2015-TBD)
F80 M3 (Sedan) / F82 M4 (Coupe) / F83 M4 (Convertible) : (2015-TBD) Discuss the 5th Generation M3
Old Thu, May-18-2017, 08:00:40 PM   #1
ApexRaceParts
Default ► New Stronger & Lighter SM-10 & FL-5 Wheels by APEX
Last year APEX worked with the community to develop a new and improved track wheel. Over 700 of you took our lengthy survey and we ended up moving forward with both proposals instead of just one. You wanted a wheel that was lighter and stronger than our more recent designs. The SM-10 and FL-5 were developed based on your feedback.
Both wheels arrive early-mid June 2017, and we’re already working on expanding the number of available sizes.
Feature Highlights
  • Lighter by 2 lbs. on average vs. EC-7
  • Stronger than all prior designs
  • I” Beam Machining on spokes
  • Revised inner lip design
  • VIA certified in Japan to JWL standard
  • BBK clearance including 380mm kits
  • OEM mounting hardware and stud kit compatible
  • OEM center cap compatible
  • TPMS compatible
The SM-10 and FL-5 designs are APEX’s first wheels to feature advanced CNC machining that removes material along the sides of every spoke. This creates a stronger and lighter “I” beam spoke design. To get a similar styling cue, many other brands just use aesthetic accent lips on their designs which add material and weight.
Style is the lowest priority on our list. We prioritize function over form. These wheels keep the superior BBK clearance of our older EC-7 design. Brembo 380mm and other 380mm kits can clear. We beefed up the inner lip by adding extra material, resulting in better protection again bends during serious abuse.
Like all APEX wheels, these are produced via flow-forming. This process roll forges the barrels, reducing weight and gives the wheel the strength it needs take on the street and the track.
SM-10 Sizes and Specifications
The SM-10 combines a straight 10-spoke design with “I” beam machining to produce a lightweight wheel that is a departure from our traditional mesh styles. Multiple face profiles continue to provide superior big brake clearance and maximized concavity for all sizes.
  • 18x8.5” ET35 - 18.4 lbs. - Arriving June
  • 18x9.0” ET30 - 19.5 lbs. - Arriving June
  • 18x9.0” ET42 - 19.3 lbs. - TBD
  • 18x9.5” ET22 - 20.5 lbs. - ETA Q3
  • 18x9.5” ET28 - 20.3 lbs. - Aug/Sept. Dependent on M2 Group Buy
  • 18x9.5” ET35 - 20.0 lbs. - Arriving June
  • 18x9.5” ET43 - 19.9 lbs. - TBD
  • 18x10.0” ET25 - 20.5 lbs. - Arriving June
  • 18x10.0” ET33 - 20.7 lbs. - TBD
  • 18x10.5” ET22 - 21.4 lbs. - ETA Q3
  • 18x10.5” ET40 - 21.2 lbs. - Aug/Sept. Dependent on M2 Group Buy
  • 18x11.0” ET44 - 21.0 lbs. - Arriving June
Profile 2 Face
Profile 3 Face
FL-5 Sizes and Specifications
The FL-5 takes advantage of Dual Flow Forming plus our newest “I” beam machining technique. Still a one-piece wheel, the Dual Flow Forming strengthens both inner and outer barrels while maximizing front lip depth for each unique width and offset
  • 18x8.5” ET35 - 19.0 lbs. - Arriving June
  • 18x9.0” ET30 - 20.2 lbs. - Arriving June
  • 18x9.0” ET42 - 20.0 lbs. - TBD
  • 18x9.5” ET22 - 20.2 lbs. - Arriving June
  • 18x9.5” ET28 - 20.9 lbs. - Aug/Sept. Dependent on M2 Group Buy
  • 18x9.5” ET35 - 20.5 lbs. - Arriving June
  • 18x9.5” ET43 - 20.4 lbs. - TBD
  • 18x10.0” ET25 - 21.0 lbs. - Arriving June
  • 18x10.0” ET33 - 21.4 lbs. - TBD
  • 18x10.5” ET22 - 21.3 lbs. - Arriving June
  • 18x11.0” ET44 - 21.6 lbs. - TBD
Medium Lip
Deep Lip
Gallery
Click the images to view more finish options on Flickr
Jump to top ApexRaceParts is offline   Reply With Quote
Old Thu, Jun-01-2017, 09:27:11 PM   #2
David@ApexRaceParts
David@ApexRaceParts's Avatar
Default Re: ► New Stronger & Lighter SM-10 & FL-5 Wheels by APEX
We love the new design of our SM-10 and FL-5 wheels! Here are some up close beauty shots of the new I Beam Machining on the spokes
Old Sun, Jun-04-2017, 11:31:37 PM   #3
Tove
They See Me Rollin'
Tove's Avatar
Reputation: 0 Tove is on a distinguished road
Very clean, these might be my favorite aftermarket rims so far
BMW Enthusiast since 1987 | Tove aka Genuine
Jump to top Tove is offline   Reply With Quote
Old Mon, Jun-05-2017, 09:49:59 PM   #4
David@ApexRaceParts
We appreciate the kind words!
-Matt
Old Mon, Jun-05-2017, 09:50:23 PM   #5
David@ApexRaceParts
Check out these detail shots of our FL-5 wheels which showcase the new "I" beam machined spokes, and the new lip design!
Old Wed, Jun-07-2017, 11:22:54 PM   #6
David@ApexRaceParts
Here is another great shot showing the differences between the FL-5 and SM-10 wheels!
Old Thu, Jun-08-2017, 10:50:11 PM   #7
David@ApexRaceParts
Here is a first look of the SM-10 and FL-5 wheels in the Satin Black finish!
Sm-10:
FL-5:
Old Tue, Jun-13-2017, 07:51:21 PM   #8
David@ApexRaceParts
Here is a comparison of all of the available finishes on the SM-10 and FL-5 wheels:
Old Wed, Jun-28-2017, 10:21:32 PM   #9
David@ApexRaceParts
Check out the SM-10 wheels on this E46 M3 race car! We think they look fantastic!!
Old Thu, Jul-06-2017, 08:18:27 PM   #10
David@ApexRaceParts
Check out this E46 M3 with the new APEX 189.5 ET22 FL-5 wheels in Race Silver. These are wrapped with 265/35-18 Pirelli P-Zero Trofeo R Tires. This setup requires 3.8 camber on the front and about 2 on the rear.
Discussing ► New Stronger & Lighter SM-10 & FL-5 Wheels by APEX in the F80 M3 (Sedan) / F82 M4 (Coupe) / F83 M4 (Convertible) : (2015-TBD) Forum - Discuss the 5th Generation M3 at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
