Old Sun, Apr-16-2017, 03:58:10 PM   #1
zem
Reputation: 0 zem is on a distinguished road
Default Zem and the art of M3 Maintenance
Right - so at ~84k, the M is due for and Inspection 2, which of course means the Valve lash adjustment. Along with that, I wanted to do a few other things like:
-Oil change
-New coils and spark plugs
-New VANOS seals, plus o rings for the sealing plate.
-And a new air filter while I'm in there.
Overall, a simple enough job, if you are methodical and pay attention to what you're doing. The most PITA is all the plastic shrouds and the fan that you have to remove, after that it's cake.
Nice unmolested motor. Long way to go!
After the fan, shrouds, etc removed, you get to this point. Takes a while just to SEE the coils.
soon enough... nice clean valvetrain. Nice oil sheen over everything.
Wiseco shim kit, feeler gauge, along with a micrometer- you will need it as the marking wear off the old shims.
A tip for taking off the VANOS: To avoid the wrench dropping into the timing chain area, I tied them together. This way, if one goes for it, you can fish it out
Everything is in good shape, my tabs are intact:
I have the Beisan disc, which has been put in during the last service, 30k ago. Def. worth the money!
VANOS seals- this took awhile, just to get the new seals carefully on. Poor picture, sorry.
O-rings for the sealing plate:
New O-rings and filter:
And finally, plugs and coils. I used NGKs and the BOSCH coils (not pictured)
A few notes -
Put aside a day to do this. It takes a while.
Be really careful about keeping the area clean, and clear - you do not want to drop shims, or even small bolts/part anywhere in the engine area. The shims are easy to lose, just focus and do them one at a time.
That being said, the washer for the oil return line (on the side of the head), must have a strange magnetic attraction to the ground. I must of bumped it a few times, even though I left it on my bench, out of the way
It's a good idea to disconnect the battery while you do this.
Torque values - I used the PDF that is available here, mucho thanks to the writer for putting it together.
And finally, turning the motor- my car has the bolt on the crank pulley, so I was able to use a huge socket to turn it. The size you need is 32mm.
Gezim
2006 6MT Coupe
Mystic Blue/Gray
Cruise/Sunroof/Cold Weather pack
Jump to top zem is offline   Reply With Quote
Old Sun, Apr-16-2017, 04:19:11 PM   #2
E46 Mystic M3
Reputation: 0 E46 Mystic M3 is on a distinguished road
Default Re: Zem and the art of M3 Maintenance
Also for SMG guys make sure the car is in neutral before you disconnect the battery! You wont be able to rotate the engine in gear for the valve adjustment.
2002 M3 Convertible SMG Steel Gray/Imola Red
1997 Toyota 4Runner SR5 (Daily)
2004 M3 Coupe SMG Mystic Blue SOLD
1997 M3/4/5 Dakar Yellow AA Stage 1 Supercharger SOLD
2004 M3 Coupe 6MT Laguna Seca Blue SOLD and very missed
2002 745i Sterling Grey SOLD, gone and not missed
Instagram: @thetypicalm3guy
Jump to top E46 Mystic M3 is offline   Reply With Quote
Old Sun, Apr-16-2017, 04:37:20 PM   #3
mrfuzzybagels
(❍ᴥ❍ʋ)
mrfuzzybagels's Avatar
Reputation: 0 mrfuzzybagels is on a distinguished road
I spit on my shirt sleeve and rubbed bird poo off my hood earlier, so same thing.
Jump to top mrfuzzybagels is offline   Reply With Quote
Old Mon, Apr-17-2017, 04:15:31 PM   #4
PITT M3 RR
PA
PITT M3 RR's Avatar
write up DIY?
OP nice bit of maint all at once with no issues. props to you haha
S54 E36 BUILD
Old Tue, Apr-18-2017, 03:18:20 AM   #5
Jazzkat
Reputation: 0 Jazzkat is on a distinguished road
Nicely done.
Special props for the thread title which to me is as impressive as the work,
Jump to top Jazzkat is offline   Reply With Quote
Old Tue, Apr-18-2017, 04:00:09 AM   #6
aznniche
aznniche's Avatar
Did you have to do any timing adjustments when changing the vanos seals (TDC, locking pin)? Were the seals flat compared to new?
Old Tue, Apr-18-2017, 11:42:26 AM   #7
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
Great idea tying the wrenches together!
Jump to top Chapelle is offline   Reply With Quote
Old Tue, Apr-18-2017, 12:57:42 PM   #8
zem
Thanks everyone - I figured that the wrenches were most likely to fall in there, so tying them was good insurance.
I didn't end up using any timing tools - I never took off the splined shafts, so the timing wasn't disturbed. Obviously I made sure to line up the tabs with the Oil pump disk when assembling. The old seals were the original ones for all I know, so they were well worn in, pretty flat. I noticed the VANOS pistons are a bit harder to move in/out, partly because of the seals and partly because the assembly was dry. I put a bit of oil in them afterward.
oh, and
Originally Posted by Jazzkat View Post
Nicely done.
hehe, I figured some will appreciate it .
Gezim
2006 6MT Coupe
Mystic Blue/Gray
Old Tue, Apr-18-2017, 03:02:06 PM   #9
WyattH
Looking good and props on DIY.
Old Wed, Apr-19-2017, 04:55:04 PM   #10
Tove
They See Me Rollin'
Tove's Avatar
Reputation: 0 Tove is on a distinguished road
Very clean! Great work keeping everything tip top.
BMW Enthusiast since 1987 | Tove aka Genuine
Jump to top Tove is offline   Reply With Quote
Discussing Zem and the art of M3 Maintenance in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
