Old Mon, Feb-13-2017, 12:33:18 PM   #1
duracellttu
Default Nav unit alarm warning??
So lately I've been getting this "ALARM" warning show up when I am listening to the radio or DICE into with my iPod. This warning will show up and the volume will increase at random. I have no idea what is causing it. Has anybody seen this before??
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Restoration: RKP CF Roof Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion+MAP Sensor | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams+DLC Coated Followers | CSL Karbonious Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Mon, Feb-13-2017, 03:21:12 PM   #2
t3ddftw
The BlueBus Guy
t3ddftw's Avatar
Reputation: 0 t3ddftw is on a distinguished road
Default Re: Nav unit alarm warning??
It's probably the DICE as those can be buggy and spam the I-Bus. Try unplugging it and seeing if the symptoms go away.
2006 M3 ZCP 6MT Interlagos Blue on Cinnamon interior
Mods
Engine: Full Beisan Systems VANOS rebuild
Transmission: CDV Delete
Exterior: Smoked Corners | Black Side & Kidney Grills | Painted Reflectors
My Build/OCD thread
I made a Bluetooth module for our cars!
Jump to top t3ddftw is offline   Reply With Quote
Old Mon, Feb-13-2017, 04:37:23 PM   #3
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Nope it's the BM53 amp going bad. That's exactly what happened to my radio.
Old Mon, Feb-13-2017, 10:51:05 PM   #4
duracellttu
Thanks! Where is the BM53 amp? Is it one of the amps in the rear pillars?
Old Mon, Feb-13-2017, 11:08:25 PM   #5
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Yes it is. Behind the driver side panel. It's the one behind the Alpine unit in the photo.
Old Tue, Feb-14-2017, 01:32:00 AM   #6
t3ddftw
The BlueBus Guy
t3ddftw's Avatar
That's an odd failure mode
You're welcome to borrow my BM53 to test, if you want. :thumbup2:
Mods
My Build/OCD thread
Old Tue, Feb-14-2017, 02:13:26 AM   #7
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Ya it is but that's what causes this. It will be intermittent and then get worse over time.
You can get a BM53 on eBay for $100-$200. The BM53L322 out of a Range Rover will work as well.
Carphonic's can repair the BM53 by doing an amp upgrade.
http://www.carphonics.co.uk/bm54upgrades.htm
DIYParadise if you want to DIY the BM53 yourself.
http://diyparadise.net/bm54.html
Old Tue, Feb-14-2017, 05:12:13 AM   #8
duracellttu
Have you used either of these services? I'm interested in the DIY from Paradise. Do you know if it comes with instructions or just parts?
I read about the Carphonics service from another thread. Really tempting, especially since they can also do firmware upgrades, RCA preouts and Bluetooth. It would leave a ton of flexibility for audio upgrades in the future. It's just reaalllly expensive.
I might take you up on that. Thanks!
Old Tue, Feb-14-2017, 08:08:10 AM   #9
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
usually when the bm53 is on the way out, it makes an intermittent static noise. kinda like aliens trying to contact you
Tischer aka GetBmwParts
Old Tue, Feb-14-2017, 11:32:29 AM   #10
duracellttu
Yes, I'm getting that too! I only hear that with the radio though, not through the DICE when my iPod is playing. So I originally thought it was an antenna amp issue.
Discussing Nav unit alarm warning?? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
