Old Sun, Aug-08-2010, 01:38:55 AM   #1
thp
Reputation: 0 thp is on a distinguished road
Default Tire Width vs. Tire Weight, which is more important?
What's more important, tire width or tire weight?
Most of the time I think the 225/255 OEM sizes are best in terms of feel. But 255/285 is more rubber so that's better right?
Some fun weights for instance.
Conti Exteme DW
225 22.00 lbs.
255 26.00 lbs.
235 22.00 lbs.
265 25.00 lbs.
245 22.00 lbs.
275 26.00 lbs.
255 26.00 lbs.
285 28.00 lbs.
Is it really worth the 12lb penalty going from 225/255 to a 255/285 setup?
For those who spend soo much $$ to reduce the weight of the rims, but end up loosing all that weight with their bigger tires, was it really worth it?
All for everyday driving with occasional track days (not hardcore enough to get track tires and all that, it's all for fun!).
Inside every good car is a bunch of wires and mechanical stuff... and a crazy driver
Jump to top thp is offline   Reply With Quote
Old Sun, Aug-08-2010, 02:27:15 AM   #2
Chris(NJ)
Back home in Jersey
Chris(NJ)'s Avatar
Reputation: 0 Chris(NJ) is on a distinguished road
I'd say the lighter weight is more important. However, when you ask if its better, you have to specify what it's better for? 225/255 setup is plenty of tire for the majority of what those tires would see
2002 Topaz/Black M3-Slicktop-SMG: OEM CSL Bootlid, Mini-CSL Battery, TMS Pulleys, Stoptech SS Lines, Borla muffler & Midpipe, Hotchkis Sways, Eibach Springs, RE RSMs, PowerFlex Rtabs, PowerFlex Subframe Bushings, TMS Subframe Reinforcement, Blk Grills, Blk Side Gills, VCSL Center Console, Euro Front Bumper, Hamann Fog Ducts, ACS Lower Lip Spoiler, FUCY Rear Diffuser, LED Tail upgrade w/ outer ring mod, D/A street software, RPI Scoops, e92 m3 18" rims w/ PS2s
Jump to top Chris(NJ) is offline   Reply With Quote
Old Sun, Aug-08-2010, 02:33:04 AM   #3
emax13
emax13's Avatar
Reputation: 0 emax13 is on a distinguished road
More important for what? Lighter weight is more important for acceleration and the extra width is better for handeling. If you are looking for better gas mileage, just put a few more PSI in the tires.
'06 CB/IR w/SMG/NAV/HK/Eibach/19" BBS RGR/Hankooks
Jump to top emax13 is offline   Reply With Quote
Old Sun, Aug-08-2010, 02:46:32 AM   #4
mugenh22a4
เป็นคนจีน
mugenh22a4's Avatar
Reputation: 0 mugenh22a4 is on a distinguished road
Hong Kong
My question too....good for what?
For me, I don't drive my car hard enough to notice the small differences in unsprung weight. I would go with the width that looks the best on the size wheel you have...not too much "stretch", but not too "meaty."
2008 ISF, Smokey Granite Mica on Black
[IMG]http://img25.imageshack.us/img25/780/dsc3038mod.jpg[/IMG ][IMG]http://img641.imageshack.us/img641/6913/dsc2821edited.jpg[/IMG ]
Jump to top mugenh22a4 is offline   Reply With Quote
Old Sun, Aug-08-2010, 04:23:22 AM   #5
AmirsM3
AmirsM3's Avatar
Reputation: 0 AmirsM3 is on a distinguished road
Conti Exteme DW
225 22.00 lbs.
255 26.00 lbs.
235 22.00 lbs.
265 25.00 lbs.
245 22.00 lbs.
275 26.00 lbs.
255 26.00 lbs.
285 28.00 lbs.
I went 245/275 so I didn't penalize myself with extra weight lol.
Importance is in the eye of the beholder. Someone who's got 500+ whp could care less about the extra unsprung weight when the car can't keep traction.
Then there are people who will spend tens of thousands of dollars on magnesium/carbon fiber wheels because they've expended all the other avenues of shedding weight.
2011 e90 M3 Space Grey DCT
2005 M3 SMG Convertible Jet Black : Depo Corners / DiCE SOLD
2007 350Z A/T Enthusiast Carbon Silver 296 rwhp 270 rwtq SOLD
2003 911S 6 Spd Guards RedStock
2010 Panamera Turbo Black PDK
Jump to top AmirsM3 is offline   Reply With Quote
Old Sun, Aug-08-2010, 04:50:49 AM   #6
EricSMG
40 something
I totally agree... the tire/wheel combo has to look right. A 255 on an 8" wheel looks sloppy.
Personally, I think the slight stretch of the OEM setup is ideal.... looks just right and delivers ultra tight repsonse without a harsh ride. Wider tires are 100% useless on the street.
Current - 2017 F82 M4 ZCP DCT Blk/Blk Fully Loaded
Current - 2004 E46 M3 6MT SG/Black
Sold - 2018 F80 M3 ZCP 6MT AW/Black Cloth "stripper"
Old Sun, Aug-08-2010, 09:57:33 AM   #7
selflove
selflove's Avatar
Reputation: 0 selflove is on a distinguished road
I bought an extra pair of rear wheels to put in the front so I can use 255 tires all around. The handling performance was greatly improved. I would prefer tire width over the weight but you don't have to have 285; you can make yourself another option with 255 all around.
Jump to top selflove is offline   Reply With Quote
Old Sun, Aug-08-2010, 12:44:46 PM   #8
Everything on cars is a takeoff; you just have to find the tradeoff that meets yours wants/needs. Personally, I find a 225 front to be pretty undriveable, whereas a 255 front is a perfect tradeoff (for me).
Also, I think your listed tire weights are suspect. There's no way the tire weights don't go up with each extra step of wideness.
Old Sun, Aug-08-2010, 04:41:15 PM   #9
EricSMG
40 something
Well, wider tires usually come with small aspect ratios, making for an overall shorter tire in some cases, which means less sidewall rubber.... which offsets the extra width's weight.
I mean, if you stand a 255/35/19 tire next to a 275/30/19 tire the 255 is quite a bit taller, no?
Old Sun, Aug-08-2010, 05:17:13 PM   #10
jph28
Back in 'Merica
Reputation: 0 jph28 is on a distinguished road
Depends what you mean by "better" and "worth it".
Since you say for DD'ing with occasional track days I'll assume you're wants are like mine (partial DD with ~6 HPDEs a year). I swapped out the heavy OEM 19" wheels with light tires (PS1) for light 18" wheels (MT1) with relatively heavy tires (265/35 Star Specs all around).
I can't remember the exact weight savings, but I think my new fronts saved fairly minimal weight (1-2lbs each) and the rears saved about 5lbs each. So, the weight savings isn't huge, but the increase in grip is freaking astounding! Plus, the "real" weight savings over keeping the heavy wheels and adding bigger/heavier tires is what you should be looking at, not just the absolute change.
So for me, "yes" it was completely worth switching to light wheels and heavier tires. If you're tracking the car a bit then I'd have to say that you are also going to find it "worth it" to have 255s up front instead of the 225s.
Current - 2018 M2, 2018 F31 330i
2004 SilverGrey 6MT Sold
Past - 18 Tahoe / '15 F31d / '02 M5 / '04 M3 / '12 VW JSW TDI / '91 Saab 900TC / '98 M3 / '06 WRX / '98 ITR / '88 Saab 9000T
Jump to top jph28 is offline   Reply With Quote
important, tire, weight, width
Discussing Tire Width vs. Tire Weight, which is more important? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
