Old Tue, Oct-16-2018, 06:23:08 AM   #1
nwGTS
Reputation: 0 nwGTS is on a distinguished road
Default LED and Xenon Programming
I'm headed to the dealer to get the airbag recall sorted.
While there I figured I'd have them code the LCM for OEM LED tails and front Xenons that I'm going to put on the car.
My question is, do I have to wait to install the lights first or can I 'prep' the car by having it coded for these first and then install the LED tails and front xenons at a later time?
2003 E46 M3 Cpe Imola/Black 6MT
2012 997.2 GTS Black/Black 6MT/LSD/Aero
Jump to top nwGTS is online now   Reply With Quote
Old Tue, Oct-16-2018, 06:36:17 AM   #2
HassanEido
HassanEido's Avatar
Lebanon
Default Re: LED and Xenon Programming
The headlights are boltons, the rears I'm not sure
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Tue, Oct-16-2018, 06:41:24 AM   #3
nwGTS
Everything I've read says my 09/2002 production date has an LCM that accepts coding for Xenons but it needs to be programmed if installing them. Are you saying that's not the case?
Old Tue, Oct-16-2018, 08:00:13 PM   #4
Just code it yourself.
Old Tue, Oct-16-2018, 08:06:40 PM   #5
nwGTS
I looked up the coding work needed and don’t have that time to invest given the cost for someone else to do it. I’ll pay it. Just need to know if I can save some time doing it now or have to wait until after the lights are actually installed.
Old Tue, Oct-16-2018, 08:11:05 PM   #6
You can do the coding before or after.
Old Tue, Oct-16-2018, 08:20:04 PM   #7
I mean it's literally like 10 minutes to install the software and 30 seconds to actually flip the switches, but whatever.
There should be no harm to pre-coding the taillights other than losing your "bulb out" warnings
For the headlights, you'll lose your highbeams if you code before installing them. If you install the headlights without coding, the low beams will flicker on/off before the LCM cuts power to them completely.
Old Tue, Oct-16-2018, 08:26:08 PM   #8
nwGTS
Thank you both very much.
Discussing LED and Xenon Programming in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
