Old Tue, Jan-02-2018, 07:56:34 PM   #1
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Default Turner Polyurethane Shifter Arm Carrier Bushing
Can anyone provide any feedback that has this installed? NVH, difference felt, ect.
The cost is low and it states the DIY time is a .5 hours. On paper it sounds great. If for $33 dollars and less than an hour of my time is correct, it sounds like a no brainier.
https://www.turnermotorsport.com/p-3...01022018_25672
Build///Journal
IG: @Khan_Art_
Old Tue, Jan-02-2018, 08:29:53 PM   #2
Brian N
wubalubadubdub
Brian N's Avatar
Default Re: Turner Polyurethane Shifter Arm Carrier Bushing
Cool find!
Would love to hear feedback on this product as well.
-My Journal-
Old Tue, Jan-02-2018, 08:38:29 PM   #3
trumpsterfire
Reputation: 0 trumpsterfire is on a distinguished road
Having Replaced my shifter bushings before .5 hours is very optimistic. Unless you have a lift and plenty of experience. I would put it more in the 2 to 3 range. (still not horrible)
Jump to top trumpsterfire is online now   Reply With Quote
Old Tue, Jan-02-2018, 10:06:06 PM   #4
redline8000
M-Power Hungry!
redline8000's Avatar
Reputation: 0 redline8000 is on a distinguished road
From what I have heard and seen, it is a PIA to replace this thing. Its sitting right between the transmission tunnel and the transmission, in a very tight spot. Without a lift you are in for a big job.
“Everything is determined…by forces over which we have no control. It is determined for the insect as well as for the star. Human beings, vegetables, or cosmic dust—we all dance to a mysterious tune, intoned in the distance by an invisible piper.”
—Albert Einstein --- Quoted in interview by G.S. Viereck , October 26,1929. Reprinted in “Glimpses of the Great”,1930.
Jump to top redline8000 is offline   Reply With Quote
Old Tue, Jan-02-2018, 10:08:36 PM   #5
SQ13
Wrong. You’re thinking of the other end. This part could probably be replaced with driveshaft and exhaust in place. With those two removed, there’s plenty of room.
Old Tue, Jan-02-2018, 10:32:09 PM   #6
Nonetheless, It's still a PITA to get the housing out while not ruining/bending the thin metal. You reuse the metal with this type of poly bushing, but the OE rubber is bonded to that metal housing, so you have to scrape it clean as far as I can tell.
Garagistic makes this, but I couldn't get it to fit, it was just too tight so I returned it. it seemed like I could have shaved/drilled some of the poly or sanded down the shift arm, but I came to the conclusion that... (see next paragraph)
The most important thing, though, is that this doesn't do much beyond bring in a little more NVH - the shift arm doesn't move much at all back there -the OE rubber piece is just there to locate the arm - it doesn't provide any bush or suspension.
This is total waste of time/$ IMO & IME.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · fan/SAP/washer delete · CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Wed, Jan-03-2018, 12:24:19 AM   #7
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Thanks guys, looks like for the level of effort involved versus the benefits received I may pass on this for now.
Build///Journal
IG: @Khan_Art_
Old Wed, Jan-03-2018, 01:03:27 AM   #8
redline8000
M-Power Hungry!
The only way I could see doing a job like this and getting that deep into it is if you just simply replace the whole shifter for a short shift kit.
Old Wed, Jan-03-2018, 01:20:20 AM   #9
Based on their pictures, it looks like this comes with its own metal surround.
Old Wed, Jan-03-2018, 01:22:46 AM   #10
Good catch. That really helps imo, but you're still doing a mod that will do nothing but make your shifter slightly stiffer and vibrate more
_
Discussing Turner Polyurethane Shifter Arm Carrier Bushing in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
