Old Sun, Oct-21-2018, 10:29:35 PM   #111
L0ADED
L0ADED's Avatar
Default Re: Comprehensive CSL Intake Thread
Originally Posted by EYEHAVEYOU View Post
Anyone have any tips for getting the throttle body boot clamps on? Having a real tough time with them (the clamp that’s closer to engine side)
Put them on the boot and clipped on the first tab before installing the intake. Clock them so you can easily access them without removing the air rail in the future and snap them in place using a good set of needle nose pliers preferably with teeth if you don't have the special tool. It will take a good amount of force (two hands) to snap them in place.
Old Sun, Oct-21-2018, 10:36:43 PM   #112
^ bang on, I'll just add that I like to have straight needle nose and the offset or angled
needle nose pliers too as some situations favor one over the other. I'll even sit in the engine bay (mostly on pass shock tower/top of engine, just to get in a great position to get enough leverage for cyl 5 esp 6.
I prefer the clip to need to come up to snap rather than down, that way the clip's tabs are facing more towards the front of the car - more exposed (3 o'clock instead of 9). You can set this up ahead of time as L0aded said, and snap them on the first level before putting the airbox on.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats zero options ~3200lbs JOURNAL
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies WPC'd OE bearings oil catch can fan/SAP/washer delete CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/550) + tall RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates SPC alum rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
OE CSL trunk Sportline 8S 18"x8.5/9.5" MPSS 245/275 APEX 75mm Studs 12mm/10mm F/R spacers Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Mon, Oct-22-2018, 04:04:51 AM   #113
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
Reputation: 0 EYEHAVEYOU is on a distinguished road
Thanks for the tips guys, I eventually got it with this in mind - using very large/long pliers made the job much easier too, just by virtue of having more leverage. This video proved useful
For anyone else tackling this I would suggest getting some worm-gear clamps as they should be much easier to use, just make sure they are 10mm or smaller width or else they won't fit on the rubber boot.
2006 M3 ZCP 6MT - Interlagos Blue /// Imola Red
2005 M3 ZCP 6MT - Alpine White /// Imola Red (Gone)
Jump to top EYEHAVEYOU is offline   Reply With Quote
Old Mon, Oct-22-2018, 04:05:36 AM   #114
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
One more question though - for those who went IAT/MAP, what did you do with your MAF? Mine's just hanging free in the engine bay now, I wonder if I should zip tie it off somewhere? Any other ideas?
Old Mon, Oct-22-2018, 04:56:50 AM   #115
L0ADED
L0ADED's Avatar
Used a broken MAF to make a plug and play adapter for the IAT.
Old Mon, Oct-22-2018, 08:42:38 AM   #116
Or just buy the proper tool. Makes getting them on/off a 5 minute job.
Old Mon, Oct-22-2018, 12:47:08 PM   #117
HassanEido
HassanEido's Avatar
Lebanon
Amazon.com: Lisle 30500 CV Boot Clamp Plier: Automotive
Oe clamps look much cleaner and seal better. Having said that, I got worm clamps.Should be changing that soon
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Mon, Oct-22-2018, 02:51:10 PM   #118
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
Another question for the gurus here. I haven't properly attached my OEM snorkel to the Karbonius box yet, looks like there are 4 attachment points.
On RealOEM here it says I need 4 x Fillister head with washer (PN 07119901780), but when I was looking at the snorkel/airbox I kind of figured it would need a nut or something on the airbox side. Does anyone know if this is truly all I need?
Well that explains my problem, based on videos I thought needle nose pliers were the proper tool Will definitely pick some of these up for future projects with these kind of clamps
Old Mon, Oct-22-2018, 03:49:27 PM   #119
L0ADED
L0ADED's Avatar
The flange on the OE intake has threaded holes to accept those Fillister screws. With the Karb box, a black cap acorn hex nut would work well with the OE Fillister screws to keep it looking clean. I forget the size of those OE Fillister screws though.
Old Mon, Oct-22-2018, 04:40:15 PM   #120
ATB88
Reputation: 0 ATB88 is on a distinguished road
It's true that it is a lot easier with this tool, but the cyl 5/6 clamps still usually take me 30+ minutes and a ton of swearing to get on even with the damn tool. If it took me 5 minutes I feel like I'd be obsessively cleaning my ITBs every couple months :P
Jump to top ATB88 is offline   Reply With Quote
Discussing Comprehensive CSL Intake Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
