Old Fri, Nov-09-2018, 05:49:21 PM   #11
Haywood
Reputation: 0 Haywood is on a distinguished road
Default Re: Want to get into a 1999 M3
Originally Posted by pbonsalb View Post
I think over 60,000 E9xM3 were sold. 90% are probably on their original bearings. Of the 10% that have been replaced, 90% of the bearings that come out look prematurely worn, done on the verge of failure. Id guess the number of engine failures is in the 1% range but no one knows for sure. There is a court case against BMW that may reveal its numbers eventually.
Yes. About 57k globally. I was just referring to US/Canada numbers. Actually, the correct number is 25,600 for US/Canada.
Jump to top Haywood is online now   Reply With Quote
Old Fri, Nov-09-2018, 06:33:30 PM   #12
Originally Posted by Haywood View Post
I personally think that's overrated. Have there been some issues? Yes, but you only read about the ones on the forums. I bet it's less than 0.5% of e90x. There were about 25,600 produced in the US and Canada so it's still an extremely low number of issues. I had an '13 e92 and sold it at 40k miles. I had 2 Blackstone oil reports done and mine had normal wear. I would not be scared to own one of the best engines and M3's ever made, IMO.
2013s don't show bearing wear on oil analysis. They were after the bearing material changeover.
Old Fri, Nov-09-2018, 07:01:20 PM   #13
Sometime in 2010 bearing material changed to avoid lead. I suppose if you had every oil change from new you could identify increases in whatever new new bearings are made of — some kind of aluminum or maybe a tri metal. But even older E9xM3 with lead and copper bearings have failed despite good oil analysis results. I would not be confident unless I had the results every change from new. Cars with the newer bearings seem to fail at about the same rate.
Old Fri, Nov-09-2018, 07:17:05 PM   #14
mrbeverlyhills
mrbeverlyhills's Avatar
Reputation: 0 mrbeverlyhills is on a distinguished road
Thank you gents, I am looking for a 99 e36, rather than a newer car. I think a e36 will hold its value better and be an easier sell one day, if I can part with it. I think it would make a good car to teach my girls at the track; the latter cars have way too much grunt. Better to learn car control and maintaining momentum than gassing it between turns.
Any PPI suggestions are welcome here in LA; West Hills is a bit far for me although if I can get sellers there and the guy is good, I'll do it.
Jump to top mrbeverlyhills is online now   Reply With Quote
Old Fri, Nov-09-2018, 07:23:36 PM   #15
Sometime in 2010 bearing material changed to avoid lead. I suppose if you had every oil change from new you could identify increases in whatever new new bearings are made of some kind of aluminum or maybe a tri metal. But even older E9xM3 with lead and copper bearings have failed despite good oil analysis results. I would not be confident unless I had the results every change from new. Cars with the newer bearings seem to fail at about the same rate.
I didn't mean to imply that they were more reliable-- just that, AFAIK, there's no way to monitor the new cars via oil analysis.
I think the oil analysis is only completely useful once you've gone to BE bearings, anyway-- before that it just protects you from bearing wear (normal for all high revving engines), not the s65's bearing lottery.
Old Tue, Nov-13-2018, 05:55:37 PM   #16
Kaikane40
GermanGuy
Kaikane40's Avatar
Reputation: 0 Kaikane40 is on a distinguished road
What color are you looking for? Sedan our Coupe? If you are open to buying out of state, I may have something I can part with. I have 3.
Jump to top Kaikane40 is offline   Reply With Quote
Old Tue, Nov-13-2018, 09:53:01 PM   #17
Nate047
Nate047's Avatar
Originally Posted by cypher448 View Post
I had a PPI done with Marc Norris at Bavarian Workshop in West Hills and would highly recommend him. He's very nice and one of the more well known M specialists in the north LA.
+100 for Bavarian Workshop, I met Marc a couple years ago when I was doing tech articles with European Car Magazine on my E36 build, and we are friends to this day. Marc is awesome, honest, and like an encyclopedia on all things BMW. Well worth the drive (I'm in Venice)
Old Wed, Nov-14-2018, 12:44:00 AM   #18
cypher448
cypher448's Avatar
Reputation: 0 cypher448 is on a distinguished road
Yea he was awesome. I decided on his shop after reading about his custom E46 M3 wagon. Honestly it was worth the trip just to see the stuff around his shop: E9 coupe, E28 and E34 M5s, Z8, and that was on a slow day
Jump to top cypher448 is offline   Reply With Quote
Old Wed, Nov-14-2018, 02:57:43 PM   #19
LockDots
LockDots's Avatar
Damn, have E9X's really come down that much? Makes them look at lot more appealing to me now...
Old Tue, Nov-20-2018, 10:45:55 PM   #20
JJCTHE1
JJCTHE1's Avatar
Reputation: 0 JJCTHE1 is on a distinguished road
Looking at a clean, one owner car with stacks of records, 2 door, fairly stock and fairly clean but 150k miles. That last scares the crup out of me, but the records state most of the usual issues are dealt with.
Carpets are a little worn, some minor parking dings, scuffed stock wheels, new tires. 1 owner and CA title. White/black
Can anyone give me a value range? Seller is asking 15k. From my self admittedly noob here status, I would have thought that bought a sub 100k mile car.
Lastly, how about a righteous referral for a PPI in LA area?
Dont focus so much on it being 1 owner, that is definitely a nice plus but its not going to be what sells the car later down the road when you are the 2nd.
Here are your pros:
-White on black - definitely a top 5 color combo
-Its a 99 - last year made - in the hunt for my Dakar i would only consider 98.5 or 99
-It has service records - also a requirement for me, if I cant track most if not all of its history I normally dont buy the car.
Some questions:
-I doubt there is any rust, but did you check for it? Ironically both of my M3s are from Northern cal, both from forum members and both are absolutely pristine with no rust. I did the PPI at a BMW dealer, it went just fine.
-Are all the VIN tags in place?
-What kind of tires are on the car? (cheap new tires generally mean corner cutting or possible suspension issues, new Michelin or Continental is a good sign of a good owner).
-Any photos? Does it have a factory rear wing? (you will know by whether or not there is a 3rd brake light in the window).
-Of the maintenance items that were addressed, did they use OEM parts? If you arent sure, post pics.
-What do you mean by fairly stock? What is not stock?
The mileage is on the higher side and so is the price BUT if this was a 95% stock car with all maintenance up to date with absolutely zero stories, fresh good rubber, a documented good suspension and clean vaders it very well may be worth it.
The color certainly helps the price justification. Most AW 99s have dove or sand beige inside while most prefer black.
See why we are asking for pics!
Jump to top JJCTHE1 is offline   Reply With Quote
Discussing Want to get into a 1999 M3 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
