Old Wed, Oct-31-2018, 01:33:17 AM   #1
Pierre i am
ranch me brotendo
Pierre i am's Avatar
Reputation: 0 Pierre i am has a spectacular aura about
Default 95 M3 clock issue
I’m running into a weird issue where i’m unable to set the clock in my 95 M3.
The OBD computer works for every button except for the set/res button. Has one else ran into this issue?
Sam 2/23/16
https://m.imgur.com/r/funny/vrjdqZ4
Jump to top Pierre i am is offline   Reply With Quote
Old Wed, Oct-31-2018, 02:57:29 AM   #2
Default Re: 95 M3 clock issue
Try resetting your obc. Hold 1000 and 10 together to access the secret menu. Go to test 21. Reset.
Old Wed, Oct-31-2018, 10:00:49 AM   #3
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Hope it’s not the actual button, as entering any of the hidden menu options, including reset, requires a press of the set/res button.
Old Wed, Oct-31-2018, 03:48:53 PM   #4
Pierre i am
ranch me brotendo
You’re a lifesaver man. I was able to do the rest and then put in the correct time/date.
Sam 2/23/16
Old Wed, Oct-31-2018, 03:51:35 PM   #5
Pierre i am
ranch me brotendo
On a sort of related note, how SOL are you if you forget your obc login code? I have mine memorized but i’m curious lol
Sam 2/23/16
Old Wed, Oct-31-2018, 09:30:01 PM   #6
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
There is no single code. It’s the sum of day+month at the moment you unlock it.
Old Wed, Oct-31-2018, 10:17:01 PM   #7
Pierre i am
ranch me brotendo
I said obc when I meant the radio... my bad. It was still early for me
I then used google and found my answer lol.
Sam 2/23/16
Old Wed, Oct-31-2018, 10:44:58 PM   #8
https://www.ivgsoft.com/radiocode.php
This is what I use when dealer lookup codes have errors (this has happened once).
Old Thu, Nov-01-2018, 12:47:47 PM   #9
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
If you don't have the radio card anymore, but know the code, just make a note in your cellphone. Of course you can also do this as a back-up of the card.
On most second hand radio's the code is usually written on the unit itself, since risk of theft of these old units is virtually non-existent
Discussing 95 M3 clock issue in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
