Old Fri, Oct-19-2018, 08:26:20 AM   #1
NolliM3
NolliM3's Avatar
Default Curious...How Many Do Own Alignment?
As the title says, I am curious how many enthusiasts do their own alignment? I remember one member saying he does his and had posted a laser tool for toe in/out...can't remember his user name. Would love those that do share tips and experience. A four wheel alignment can cost $240 here from excellent shops.
Old Fri, Oct-19-2018, 08:43:12 AM   #2
Eric M3
shogun
Eric M3's Avatar
Reputation: 0 Eric M3 is on a distinguished road
Japan
Default Re: Curious...How Many Do Own Alignment?
I do it since about 10 years, using a Trakrite tool made in the U.K.
http://www.gunson.co.uk/product/G4008
demo
My 7 series DIY site: http://twrite.org/shogunnew/topmenu.html
Jump to top Eric M3 is offline   Reply With Quote
Old Fri, Oct-19-2018, 10:26:21 PM   #3
Nate047
Nate047's Avatar
There's a good series of write ups on MotoIQ about suspension including one on doing alignments. If you've ever been to an IMSA or similar type of race, you know pretty much every team aligns their cars with strings.
Old Sat, Oct-20-2018, 10:24:07 PM   #4
Reauxtide
Reputation: 0 Reauxtide is on a distinguished road
I do F/R toe using jack stands, fishing line, and a 1/32 tape measure.
Picked up used Turner steering rack spacer tool. Works well for a dead straight steering wheel.
I had a shop set my camber and verify my toe measurements the 1st time I set it all myself. I was within .02 of a degree.
Jump to top Reauxtide is offline   Reply With Quote
Old Mon, Oct-22-2018, 03:31:16 AM   #5
Eric M3
shogun
Eric M3's Avatar
Japan
Here another alignment DIY with a laser
http://www.bimmerboard.com/forums/posts/711044/
I also have tried that laser method on my E32 750 also to compare, but comparing the Trakrite method and the laser, the Trakrite is the most easiest way for me.
Old Tue, Oct-23-2018, 05:24:49 PM   #6
NolliM3
NolliM3's Avatar
demo Gunson Trakrite.flv - YouTube
Thank you Eric M3 for responding and sharing...I had been familiar with the Trackace that another member shared...cost-wise, tools seem to favor those who track their car frequently.
Old Tue, Oct-23-2018, 05:40:54 PM   #7
NolliM3
NolliM3's Avatar
Yes, I am learning that the string method of alignment applies to our cars very well.
Thank Reauxtide for responding...so you measure your toe in with 1/32 of an inches...so, it it easy to read and does 0.05 degree equals 1/32" or 1/16"? I was leaning towards 1/16."
Old Tue, Oct-23-2018, 09:44:52 PM   #8
Reauxtide
Yes, 1/32" marks to make it easy to read and seems to help with my accuracy.
When I align for HPDE's, I max out the TCK camber plates in the front and set the Toe to 0.
When swapping back to street alignment, camber plates go back to normal and 1/32" toe in each wheel which I believe gives a total toe of approx .05"or .10 Degrees (I can't guarantee that conversion to degrees is right...). Steering is stable, and haven't seen any abnormal tire wear.
I think I've also read suggestions of 1/16" per side, which I think is .1"or .20 Degrees.
Once you get the process down you can play with it and make small adjustments.
Last edited by Reauxtide; Tue, Oct-23-2018 at 09:46:44 PM. Reason: Whoops. Left out a bracket on my quotes
Old Wed, Oct-24-2018, 02:27:46 AM   #9
NolliM3
NolliM3's Avatar
Reauxtide, I now believe you're correct that 0.05 equals 1/32"...I have been shopping for a steel ruler 18 or 24inches with 1/32 per inch...I want to give self-aligning a chance,...waiting for the rear sway bar bushings and end-links to come in and install. I recently got a magnetic camber gauge bought from eBay.
Discussing Curious...How Many Do Own Alignment? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
