Old Tue, Oct-30-2018, 04:20:31 AM   #11
Contracheatcode
Reputation: 0 Contracheatcode is on a distinguished road
Default Re: Rear Upper Ball Joint Woes
Having just replaced all my rear ball joints and bushing, I was about to pretend like I had some good advice. I’ll leave that the Brett and the experts.
In the meantime, all I can do is sympathize and say “that sucks”.
Listen to the experts and good luck with whatever you try.
Mike
Jump to top Contracheatcode is offline   Reply With Quote
Old Tue, Oct-30-2018, 07:00:34 AM   #12
nholmes
Track Junky
nholmes's Avatar
So after two track days, it looks like the Loctite 620 is holding up. I certainly wasn't holding back on beating on the car.
Follow my build thread here:
Old Tue, Oct-30-2018, 01:36:38 PM   #13
BMWManiac
Turbo 97 M3
BMWManiac's Avatar
Reputation: 0 BMWManiac is on a distinguished road
Would you recommend coating the inside of the knuckle with the loctite prior to install? Or just on the bearing if you had to do it again?
1997 Artic Silver M3
CES Stage IV - 651rwhp/615rwtq@ 24 psi
Jump to top BMWManiac is offline   Reply With Quote
Old Tue, Oct-30-2018, 05:29:51 PM   #14
nholmes
Track Junky
nholmes's Avatar
Technically, the proper way to use it, is to coat one of the two sides of the mating surfaces with it and then put them together. This stuff is anaerobic, so it works best in the absence of air. The outside of my ball joint was still wet, since it won't cure in the open air. I assume the stuff deeper in on the backside was able to cure and help hold the ball joint into the knuckle.
I didn't remove the ball joint and coat one of the mating surfaces because I was lazy. That would have been my next step had this other method failed to hold it in place.
Discussing Rear Upper Ball Joint Woes in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
