Old Mon, Oct-24-2016, 04:56:11 AM   #1
bmwstephen
Default Seat belt tensioner (early vs late)
Hi again yall,
Trying to swap late model vaders into my early model car. Obviously one of the tricks is to swap the tensioners but I am having the following issues:
Later style tensioners into sport seats (previously had early style tensioners) - there is play when mounting the later style tensioner into the seat rail; cannot bolt all the way down against rail.
Early style tensioners into vaders (previously had later style tensioners) - early stule tensioner does not sit flush against the rail
Were there differences between the seat rails in the years?
Jump to top bmwstephen is offline   Reply With Quote
Old Mon, Oct-24-2016, 10:35:52 AM   #2
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: Seat belt tensioner (early vs late)
Seatframes of <95 and <95 are totally different. Although don't know if the actual rail part where the tensioner is, is different.
I once swapped later style pyro tensioners over to a seat with mechanical ones, but it was the same base frame. You need the bolts itself as well, as they are different.
Old Mon, Oct-24-2016, 03:04:33 PM   #3
bmwstephen
This actually sounds like my situation (the frames between my two set are the same, it just appears that the tensioner and mounting thereof is different).
Which bolts are you referring to? If its the one for mounting the tensioner onto, how does one remove it? seems like its impossible without going further and disassembling the rail when I last looked at it
http://www.realoem.com/bmw/enUS/show...22#52108201097
Old Mon, Oct-24-2016, 04:45:53 PM   #4
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Uh, the bolt is right there at the base. Don't understand you can't get to it.
Old Mon, Oct-24-2016, 04:49:18 PM   #5
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
When I swapped mine. One mounting bolt, one locating bolt.
Old Tue, Oct-25-2016, 01:03:08 AM   #6
bmwstephen
Edit nvm
Old Tue, Oct-25-2016, 03:05:33 AM   #7
bmwstephen
Curious, do you happen to know how mechanical tensioners work? The bentley manual calls for disarming it by turning the dial before removing it. Any reason to do so?
Old Tue, Oct-25-2016, 10:54:10 AM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Yes that blocks the little ball (I believe) from being able to be bumped away (like in a crash), which holds back the preloaded spring, that attaches to the belt buckle.
Old Tue, Oct-25-2016, 02:01:11 PM   #9
haus
haus's Avatar
Originally Posted by bmwstephen View Post
Edit nvm
Ugh, I was curious. What was the deal? I've never taken one of those apart and I saw your photo before you removed it.
'97 Cosmos (1 of thousands)
Old Tue, Oct-25-2016, 02:46:41 PM   #10
bmwstephen
Pain in the ass to remove with electric frames because it has to be done in the car and you have to be very strategic.
1) remove seat bolts mounting them to the car and remove headrest for wiggle riom
2) raise the seat bottom to the highest setting
3) disconnect battery to prevent airbag light fault
4) unplug electrical under the seat now and move the seat around so that you can start unbolting the seat belt tensioner (if mechanical tensioner disarm it first)
5) that pin is now accessible because the center seat frame would block it at its lowest setting; yank the locking clip behind it with pliers and angle the pin out of the socket
Discussing Seat belt tensioner (early vs late) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
