Old Fri, Apr-16-2010, 06:25:19 PM   #31
BlazenXLT
We've had one yes, what about second breakfast?
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
Originally Posted by The Dough View Post
M3 is the SUV of sports cars.
Totally. Mine's loaded up right now for an event. When I get all my equipment together, it never looks like it will fit, and it always does with room to spare.
Jump to top BlazenXLT is offline   Reply With Quote
Old Wed, Jun-09-2010, 04:43:49 PM   #32
TJe46M3
Reputation: 0 TJe46M3 is on a distinguished road
Originally Posted by delirium45 View Post
i should be getting my tire trailer mid- next week from my fabricator.
it's a modified HF trailer with tire rack and toolbox, hooked up to DocWyte's old hitch system. pics to follow.
Bump--
delirium45- do you have any pics to share yet? I'm curious to see how it turned out. Thanks.
2004 BMW M3 (6MT)
2002 BMW X5
Jump to top TJe46M3 is offline   Reply With Quote
Old Wed, Jun-09-2010, 05:50:57 PM   #33
docwyte
Track addict
docwyte's Avatar
Reputation: 0 docwyte is on a distinguished road
Probably doesn't look any different than what I had. He's using my old hitch and the HF trailers all kinda look the same. I posted pics of my trailer. Still have it, using it with my Porsche now...
'98 BMW M3 Track Rat
'08 Lexus GX470 Daily Driver
'15 KTM 1190R Beastly Moto
Jump to top docwyte is offline   Reply With Quote
Old Wed, Jun-09-2010, 06:15:42 PM   #34
THEHOUNDER
Ezekial 23:20
THEHOUNDER's Avatar
Reputation: 0 THEHOUNDER is on a distinguished road
Originally Posted by kaiv View Post
I'm loving those roof racks but I think I would be kinda be worried about theft (when parked at a hotel overnight before the track event).
Cable lock through the wheels...Never an issue.
2004 Silbergrau SMG/ Vulcan Racing Fab Cage /RRT Built S54/Aeromotions/ V-CSL Roof/Works Bell SMG/ Fabspeed Headers/ Epic tune/ /Cobra Sebring /Brembo/ GSP Gen 1 Pedal /Moton CS /Other junk and stuff
2012 Mercedes GL450 - Tow pig
2010 Featherlite 17'6" open
2013 e93 ///M3 -stock
Jump to top THEHOUNDER is offline   Reply With Quote
Old Wed, Jun-09-2010, 08:42:08 PM   #35
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
I think I'd just do like mpegripper and take them with me in the room ahah.
THEHOUNDER, all I need to replicate your setup is an OEM roof rack and the yakima bin? I'm completely clueless when it comes to roof racks; I'm assuming either the roof rack or the bin comes with the necessary hardware to attach both together? Then just get some straps to tie down the wheels in the bin and you're good to go?
TIA
I'm seriously considering this, getting tired of fitting all 4 wheels in the back through the trunk.
E46 ///M325i Touring journal
Old Wed, Jun-09-2010, 09:05:24 PM   #36
docwyte
Track addict
docwyte's Avatar
I couldn't imagine carrying 4 wheels/tires on the roof of the car. Just seems so ghetto to me as well as a huge PITA lifting a 50lb+ wheel/tire combo on and off the roof of the car.
I was very pleased with my tow hitch, worked great and I was able to keep all the tools etc in the tire trailer too.
Old Wed, Jun-09-2010, 09:31:07 PM   #37
TJe46M3
docwyte-
Not sure if you ever saw this below question I posted to you in another thread. Can you please let me know your thoughts?
Also, Mike Miller from the Roundel Magazine told me that the electronics to run the trailer lights might turn into a huge problem since the US e46 M3 wasn't built for a trailer. Any thoughts? Thanks.
The euro hitch will work, but you need to get the "normal" aluminum bumper beam and remove the diffuser when you're using the hitch.
Hey docwyte-
I found the "euro hitch" here: http://eurohitch.es/index.php?main_p...products_id=29
When you say ""normal" aluminum bumper beam" are you referring to part number 51128195324, which is the e46 330i rear bumper carrier? see: http://www.realoem.com/bmw/showparts...06&hg=51&fg=15
If so, are you sure that the e46 M3 rear bumper trim panel (http://www.realoem.com/bmw/showparts...83&hg=51&fg=15) will correctly re-attach to the e46 330i bumper carrier?
Thanks!
2004 BMW M3 (6MT)
2002 BMW X5
Old Wed, Jun-09-2010, 09:40:47 PM   #38
docwyte
Track addict
docwyte's Avatar
Your realoem links aren't working. You can use the euro westphalia hitch, make sure you get the coupe one and the one with the removable ball. You need to switch to the 330 aluminum bumper beam and it needs to be cut to fit the hitch.
The stock M3 bumper won't have any issues fitting over that bumper beam, it's the same as the M3 kevlar one with the exception of being aluminum.
You need to remove the diffuser to run the ball on the hitch.
Not sure about the rear tail lights, my old car was an '02 with the old style bulb tail lights and I had no issues with wiring. I used a standard hitch wiring harness. Not sure if it's the same with the later LED style tail lights.
Old Wed, Jun-09-2010, 10:20:23 PM   #39
TJe46M3
Thanks for the reply. I fixed the links.
I'm confused when you say "it's the same as the M3 kevlar one with the exception of being aluminum". It seems the M3 bumper beam has a completely different design than the 330i bumper beam because the M3 bumper beam is designed to house a foam pad if you look at the realoem diagrams. Whereas the 330i bumper beam is designed for use with a shock absorber, not a foam pad, if you look at the realoem diagrams.
Am I missing something?
2004 BMW M3 (6MT)
2002 BMW X5
Old Wed, Jun-09-2010, 10:56:51 PM   #40
THEHOUNDER
Ezekial 23:20
THEHOUNDER's Avatar
TIA
You will also need to purchase some 1 inch square metal bars/tubes and some bolts and create wheel stops so that wheels won't roll backward or forwards.
track, transporting, wheels
Thinking about transporting car kkamakasi Off Topic 3 Sat, Jul-05-2008 02:43:59 AM
Track wheels comapare CCW classics vs. Kodiak wheels rt's Jasoncor M3 Track: Racing and DE 1 Mon, Oct-01-2007 12:16:17 AM
Transporting the M JoeE46M3 E46 M3 (2001-2006) 5 Tue, May-29-2007 09:03:16 PM
need quick help.. transporting oem csl bootlid bmwJohhnyD E46 M3 (2001-2006) 7 Sun, May-13-2007 02:56:28 AM
CCW Track Classic Wheels: Street vs. Track |Drew| M3 Track: Racing and DE 6 Fri, Jul-29-2005 04:38:56 AM
Discussing Transporting Track Wheels in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
