Old Wed, Feb-14-2018, 03:18:16 AM   #1
aznniche
aznniche's Avatar
Default Turner Pulleys Tight Fit?
Is it normal the water pump pulley is 1mm away from the tensioner. It's so close I'm afraid it may touch it and cause damage.
Jump to top aznniche is online now   Reply With Quote
Old Wed, Feb-14-2018, 03:34:42 AM   #2
NevEragon
Reputation: 0 NevEragon is on a distinguished road
Default Re: Turner Pulleys Tight Fit?
Mine is the same distance away from the tensioner. It rubbing actually was my first sign that my water pump was going out.
Jump to top NevEragon is offline   Reply With Quote
Old Wed, Feb-14-2018, 03:38:10 AM   #3
erickrayos
I got UUC and its the same as well. very close clearance.
Old Wed, Feb-14-2018, 03:48:23 AM   #4
aznniche
aznniche's Avatar
It rubbed and didnt cause any damage? How did you notice? Loud noises?
I've been getting coolant spray on my shroud next to the alternator and a bit on the fan blades. I'm wondering if my water pump is hitting the tensioner causing this leak. I idled it but don't see anything coming out.
Old Wed, Feb-14-2018, 05:51:24 AM   #5
HassanEido
HassanEido's Avatar
Lebanon
I ground off the pump a bit to make it clear
Mods:
Modified stock airbox,afe plastic intake elbow Afe prodry drop in, electric fan conversion,SSV2 catless headers, custom 2.5" dual sec1, custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3,tms pulleys,Cat Cams 280 272, custom dyno tune, csl box pending
357.7 whp 283.5 wtq
Old Wed, Feb-14-2018, 04:51:24 PM   #6
Mveneros
Reputation: 0 Mveneros is on a distinguished road
It's normal, I just did my Turner pulleys a few days ago and was concerned of the bigger size and clearance to the tensioner. Just make sure to torque down the pulleys properly as a loose water pump pulley will come in contact with the tensioner due to such a small clearance.
Jump to top Mveneros is online now   Reply With Quote
Old Wed, Feb-14-2018, 04:52:26 PM   #7
X2 used a file.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Euro Headers Euro cat sect 1 Dinan sect 3 BMW Motorsport 4.10 Besian D/A pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Discussing Turner Pulleys Tight Fit? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
