Old Wed, Feb-14-2018, 12:36:30 AM   #1
Mike_M
Mike_M's Avatar
Reputation: 0 Mike_M is on a distinguished road
Default Engine with spun rod bearing. What to do?
So I over rev'd my engine and spun a rod bearing.
I have sourced a used engine with labor and half the miles of my car at a decent price.
What could I get for the engine with the spun bearing? 140k miles. Lots of maintenance before this problem occurred.
What's the best line of action? Should I put a new used engine in or fix my current one?
Jump to top Mike_M is offline   Reply With Quote
Old Wed, Feb-14-2018, 12:56:22 AM   #2
cloizou
Reputation: 0 cloizou is on a distinguished road
Default Re: Engine with spun rod bearing. What to do?
Sorry to hear your loss! I had a similar issue before. I would recommend putting the used motor in, you will save a lot of time and money. While the motor is out, do the rod bearings, cpv gasket, any transmission work (clutch etc.) and headers if you want.
As for resale, you can part out pieces and make a decent amount back. Accessories, head, oil sump, exhaust and intake manifolds.
Good luck!
Jump to top cloizou is offline   Reply With Quote
Old Wed, Feb-14-2018, 01:02:10 AM   #3
FK
You would have to asses the damages on your existing motor to have a decent idea of what it would be worth.
Old Wed, Feb-14-2018, 01:15:00 AM   #4
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
In my experience most people go the used engine route as it's a simpler and less labor intensive.
If you go that route definitely do 1) rod bearings 2) vanos/valve adj and 3) cpv etc on the used engine prior to install.
The only potential downside of getting a used motor is you might not always know what you're getting. I've seen people get a cracked block or really filthy motors.
If you want to reuse your motor, you will need to essentially rebuild it which involves full disassembly. You will need to figure what to do with the crank (regrind or replace) since it will most likely be damaged. You will likely need to replace the rods or at least the one that spun. You will also need to flush oil filter housing, cooler, lines etc for debris. More work but you know what you're getting though.
Out of curiosity how high did you see your tach go?
E46 ///M325i Touring journal
Old Wed, Feb-14-2018, 04:20:57 AM   #5
Mike_M
Mike_M's Avatar
Yea that’s what I was fearful of as I know how well I took care of my engine.
But wouldn’t the benefit of rebuilding be that there’s a ton of new parts? Would it be about the same cost as a used one?
I got quoted about $4k for an engine with 68k miles installed.
Old Wed, Feb-14-2018, 04:46:14 AM   #6
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
That is a fantastic price including labor for a 68k mile engine. I'd be concerned with the quality of work you get at that price an be looking out for any hidden costs.
Current BMW stable: '00 R1100S, '09 HP2S, '12 R1200GSA, '00 323iT (S54 Swapped), '00 332iT (stock), '03 325iT (stock), '04 ZHP Imola/6MT (basic suspension mods)
Jump to top GeorgeH is offline   Reply With Quote
Old Wed, Feb-14-2018, 04:48:16 AM   #7
Toasty
Reputation: 0 Toasty is on a distinguished road
I'm not at all an expert in this, but I see you're in San Diego as well, so it may be worth giving Lang Racing up in Irvine a call. Based on my (albeit limited) knowledge, if you are going to try and salvage the engine, they'd likely be the best place to start. I believe I saw a thread before where Andrew Lang (owner and namesake) talked about the procedures they have to save engines that have had catastrophic bearing failures, and I definitely know they regrind damaged crankshafts and rebuild engines.
If you are worried about the prospects of a used motor, this may be something to consider.
Jump to top Toasty is offline   Reply With Quote
Old Wed, Feb-14-2018, 05:05:19 AM   #8
m3 hal
$4k installed is a smoking deal for an S54. Even at normal prices the used engine will probably be the more economical route. Have you torn down the blown engine? There are probably bent valves too from the overrev.
Old Wed, Feb-14-2018, 05:06:37 AM   #9
herrubermensch
herrubermensch's Avatar
Reputation: 0 herrubermensch is on a distinguished road
We do rebuilt S54 shortblocks with Pauter rods and WPC treated bearings for $5k. Heads typically require at least decking, pressure-checking, checking guides, and replacement of valve seals. All of that can be done for another $1k. Or if you think your head is in great shape, you can just bolt it on to a rebuilt shortblock. So a rebuilt motor will cost a little more, but it will have zero miles on it, you will know what you are getting, and critical parts (rods and bearings and rod bolts) are significantly upgraded.
--Peter
Jump to top herrubermensch is offline   Reply With Quote
Old Wed, Feb-14-2018, 05:08:08 AM   #10
Mike_M
Mike_M's Avatar
Apparently he flips 'M' cars so its a quick process for him and he's had the engine for awhile.
But that's the thing, you never know.
Discussing Engine with spun rod bearing. What to do? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
