Old Sat, Feb-10-2018, 09:32:17 PM   #1
dredpyrt
Reputation: 0 dredpyrt is on a distinguished road
Default Battery Change...Lots of dash warning lights
I installed a new battery in my 03 and it runs and shifts fine but ive got some warning lights. ABS and SMG failure are on plus the E-brake lamp is solid yellow. Ive only done about 12 miles since the new battery and i had no issues before although it has been sitting for awhile while i tackled other projects. Does it need more miles or am i looking at a problem? Thanks!
Jump to top dredpyrt is offline   Reply With Quote
Old Sat, Feb-10-2018, 10:05:12 PM   #2
tjkenny15
tjkenny15's Avatar
Default Re: Battery Change...Lots of dash warning lights
Your alternator in good shape?
Oem battery or similar?
2005 BMW M3 INDIVIDUAL - Estoril Blue
Jump to top tjkenny15 is offline   Reply With Quote
Old Sat, Feb-10-2018, 10:23:11 PM   #3
dredpyrt
Autozone Duralast H7-DLG. As far as the alternator...good question. I didnt have any issues previously.
Old Mon, Feb-12-2018, 01:55:39 AM   #4
qualicas
qualicas's Avatar
You didn't replace the battery while the car was running? Did you possibly put it in backwards and connect it even briefly?
If none of the above. Shut everything off, disconnect the NEG cable for 10 minutes and reconnect. Everything should be good.
Old Mon, Feb-12-2018, 03:19:06 AM   #5
whips333
whips333's Avatar
Auto zone batteries are useless for these cars
Jump to top whips333 is online now   Reply With Quote
Old Mon, Feb-12-2018, 04:46:35 AM   #6
dredpyrt
No on putting the battery in the wrong way. Positive and negative have color coded covers on the posts plus it really only fits one way. I'll disconnect it and see what happens.
Old Mon, Feb-12-2018, 02:31:01 PM   #7
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Auto Zone and Advance Auto batteries are both Johnson Controls batteries, and both as a result are on the low end. Same company that now owns Optima and was seemingly responsible for that brand crapping out.
I'd use them in my lawn mower.
Andrew
Current - '05 Interlagos E46 M3 SMG Delete 6MT Coupe - 3350lbs
911 Journal/Build Thread
No fun no care
Jump to top TheSt|G is online now   Reply With Quote
Old Tue, Feb-13-2018, 01:12:49 AM   #8
dredpyrt
Swell...I assume there is a eye wateringly expensive solution.
Old Tue, Feb-13-2018, 01:40:57 AM   #9
Steve M3
I have a Walmart battery in mine and it has been just fine. I would try to disconnect the battery, as mentioned above, first. If the codes are still there then read them and see what's going on. Once you write them down, try to clear them and see if they come back. If they don't, then you can probably write it off as a one-time random deal. Good luck!
Old Tue, Feb-13-2018, 03:16:29 AM   #10
SQ13
Iíve had the same battery you have for a few years now, and I have never run into electrical problems, other than starter going out (not caused by battery).
Discussing Battery Change...Lots of dash warning lights in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
