Old Sat, Feb-10-2018, 07:56:11 PM   #1
stogybear
stogybear's Avatar
Reputation: 0 stogybear is on a distinguished road
Armenia
Default Whatís the best way to reduce NVH?
My car is a tick over 81k miles and Iím starting to feel a lot of noise and vibrations. I plan on swapping the control arm bushings and rtabs soon, but is there anything else that will impact nvh dramatically?
2005 AW M3 - 6MT - Bay Area
Jump to top stogybear is offline   Reply With Quote
Old Sat, Feb-10-2018, 08:50:43 PM   #2
BTB
BTB's Avatar
Default Re: Whatís the best way to reduce NVH?
What sort of noise/vibrations?
Pretty much any rubber has some effect on nvh. Diff/trans/engine bushings, csb and guibo should pretty much take care of the drivetrain
My Journal
Old Sat, Feb-10-2018, 08:54:27 PM   #3
stogybear
stogybear's Avatar
Armenia
The steering wheel vibrates a bit at highway speeds. Hitting bumps feels really rough too.
Old Sat, Feb-10-2018, 08:57:14 PM   #4
Kwakjoe
Kwakjoe's Avatar
Have you replaced the FCABs?
Old Sat, Feb-10-2018, 09:10:08 PM   #5
lmtfi
lmtfi's Avatar
Tires, avoid low-profile wheel/tire setups, bushings, alignment, suspension stiffness.
Old Sat, Feb-10-2018, 09:46:10 PM   #6
EricSMG
40 something
Is your car modified? What age/mileage are the following:
fcabs
rtabs
rear shock mounts
front shock mounts
spring pads
bumpstops
shocks
steering guibo
Also, what tires/sizes/mileage?
Old Sat, Feb-10-2018, 10:08:57 PM   #7
icecream
Registered Apples
icecream's Avatar
fcabs
rtabs
rear shock mounts
front shock mounts
spring pads
bumpstops
shocks
steering guibo
Good starting point. I would look at the tierod and balljoints too.
I'd just do everything at once cause as soon as you replace one thing, something else will wear out or the part you replaced won't be the culprit.
Old Sat, Feb-10-2018, 10:32:49 PM   #8
Toasty
Reputation: 0 Toasty is on a distinguished road
I'm surprised no one has suggested yet the ultimate mod to make your M3 more compliant... changing out your E46 chassis for an E92 one!
My car's steering currently has a dead spot/sloppiness that I find unacceptable, and I assumed the problem was just the steering coupler was worn out, but reading around a little bit in threads like these has put the idea into my head that other suspension components could contribute to this as well. Is there an easy way to pinpoint which items are the culprits behind my sub-optimal steering? Or should I just change everything out at once to be safe?
Jump to top Toasty is offline   Reply With Quote
Old Sun, Feb-11-2018, 02:42:26 AM   #9
stogybear
stogybear's Avatar
Armenia
fcabs
rtabs
rear shock mounts
front shock mounts
spring pads
bumpstops
shocks
steering guibo
Just bilstein pss9 coilovers that have about 40k miles on them. I think my front tires are getting old and dry too at this point. Good list, thanks,
Old Sun, Feb-11-2018, 02:59:51 AM   #10
m3vancity
Reputation: 0 m3vancity is on a distinguished road
call me crazy but at that mileage Id consider motor and transmission mounts as well.
Jump to top m3vancity is offline   Reply With Quote
Discussing Whatís the best way to reduce NVH? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
