Old Sat, Feb-10-2018, 02:34:34 AM   #1
Joshe46
Joshe46's Avatar
Default K&P Engineering stainless steel reusable oil filter
Hey fellas,
Came across this on turner today.
https://www.turnermotorsport.com/p-4...shed-end-caps/
A reusable stainless steel oil filter. Hmm, whats everyoneís opinion??
Would you be comfortable using this?
In my opinion at $100 Iím not sure about it, especially considering how much of a pain IMG_7864.JPGand messy cleaning it out would be, not to mention the cost of all the brake clean used.
Jump to top Joshe46 is offline   Reply With Quote
Old Sat, Feb-10-2018, 02:37:35 AM   #2
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
Default Re: K&P Engineering stainless steel reusable oil filter
Uh, what exactly is the point? An oil filter is like $8. If you changed your oil every 5000 miles that's over 60K miles before you break even on an oil filter that probably has worse filtration properties. Sounds like a terrible idea.
Jump to top ctres is offline   Reply With Quote
Old Sat, Feb-10-2018, 02:40:12 AM   #3
Kwakjoe
Kwakjoe's Avatar
^ This
Jump to top Kwakjoe is online now   Reply With Quote
Old Sat, Feb-10-2018, 02:40:15 AM   #4
rovert604
rovert604's Avatar
I think it would make sense if you had a separate container where you bath car parts in a reusable degreaser. Then all the heavy stuff just falls to the bottom of the bath.
But yeah if you donít have that I think using all that brake cleaner might take 20 oil changes to break even.
--Trevor in 604--
Vancouver, BC, Canada
Old Sat, Feb-10-2018, 03:51:39 AM   #5
Joshe46
Joshe46's Avatar
Completely agree with you guys. I donít see this as ever breaking even compared to normal filters. I donít believe it is worth it.
Old Sat, Feb-10-2018, 04:12:03 AM   #6
mrgizmo04
mrgizmo04's Avatar
Yeah, no thanks
'85 528e 164k miles (sold)
'05 M3 6MT coupe
All DIY: 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Rogue RSM with reinforcement, WPC rod bearings, Beyer driveshaft, full SS (SS stepped V1, catted S1, resonated S2, SS sport), Sachs clutch/flywheel, rear main, VANOS bullet proofing with anti-rattle, valve adjustment, cooling refresh.
Old Sat, Feb-10-2018, 04:16:57 AM   #7
RedM3/4
I'd compare it to the best paper tech, specifically, what micron size does it filter?
Regardless, I buy a box of Mahle at a time, about 6.xx each back when I got the box several years back, but I do low miles/year. So at 5k miles per change, 12 filters, 60k miles of filters for say $78 and I don't have to clean anything.
If you do a ton of miles and the specs are .. say 5 microns, might be worth it, but still, having to clean it every change, dunno I'd mess with it.
ADS
Old Sat, Feb-10-2018, 05:20:48 AM   #8
bigjae1976
Lower micron ratings will result in more pressure. Might cause more oil to bypass the filter which would make the filter less effective.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sat, Feb-10-2018, 11:57:10 AM   #9
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
Would make a great pen cup.
Jump to top Chapelle is offline   Reply With Quote
Old Sat, Feb-10-2018, 05:36:49 PM   #10
djjvr
OEM+
djjvr's Avatar
Denmark
Per the Turner website
"Features:
- Consistent filtering across entire filter surface
- Superior ASTMF316 filtration performance
- 7 times the flow of comparable paper oil filters
- Magnetic Prefiltering
- Progressive rate bypass combined with high flow characteristics of the filter media avoids unfiltered oil bypassing the filter during cold startup and high rpm
- No more cutting apart messy paper filters for trapped debris inspection
- Proven in Motorsports, Military and Aerospace applications for years. Technology is FAA approved for use in aircraft.
- At regular oil changes, clean to K&P's specifications for continued used - a true lifetime filter."
That all sounds good and interesting. However, watching the cleaning video idk if I would want to deal with that when I can just discard/recycle my old one anyway.
"Sucking at something is the first step to being sorta good at something!"
Build Journal
Discussing K&P Engineering stainless steel reusable oil filter in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
