Old Sun, Feb-11-2018, 07:36:09 PM   #21
Kcalhoun27
Reputation: 0 Kcalhoun27 is on a distinguished road
Default Re: sunroof fix
Well that certainly doesnt look good. If it helps, i had the usual issue, and i used a plastic mallet and rag to gently slide the cassette forward. Full disclosure, i have no desire to keep the sunroof and will be going cf panel, but a stuck open sunroof needs to be fixed, so i closed it and pulled the fuse
Jump to top Kcalhoun27 is offline   Reply With Quote
Old Sun, Feb-11-2018, 11:44:09 PM   #22
trumpsterfire
Reputation: 0 trumpsterfire is on a distinguished road
Originally Posted by Dirty Elf View Post
i think i found the problem
Had the same exact issue. I ended up replacing the whole cassette and the motor. If the gear is on your motor is in good shape you should be able to reuse it. The previous owner of my car kept trying to use the sunroof after it the worm drive had started to slip and ended up destroying the teeth on the gear.
Jump to top trumpsterfire is offline   Reply With Quote
Old Sun, Feb-11-2018, 11:54:06 PM   #23
Dirty Elf
BSME
Dirty Elf's Avatar
Reputation: 0 Dirty Elf is on a distinguished road
iím going to go with a carbon sunroof delete i think. car is not a daily anymore so no need for the roof hole
First Road Trip
2004 Silver-Grey ///M3 Coupe
Jump to top Dirty Elf is offline   Reply With Quote
Old Mon, Feb-12-2018, 01:58:48 AM   #24
qualicas
qualicas's Avatar
Gee, mine looked a lot like that one.
Old Tue, Feb-13-2018, 01:48:45 AM   #25
budget76
Reputation: 0 budget76 is on a distinguished road
I had the same issue on my 330XI. Here's the thread I started on it, with a good video
fixed it as talked in the thread and it worked for another year until I sold the car. I did it with the headliner in place, which made it much more of a PITA to do.
http://www.e46fanatics.com/forum/sho...165&highlight=
Jump to top budget76 is offline   Reply With Quote
Old Tue, Feb-13-2018, 02:51:31 AM   #26
Red Rider
Red Rider's Avatar
Reputation: 0 Red Rider is on a distinguished road
Originally Posted by PSUEng View Post
You've got either one of or both of the plastic guide pieces broken on either side (two different pieces on each side.)
In order to inspect, remove the glass from the top.
Here's a great DIY that I used:
http://www.lincomatic.com/e46sunroof/e46sunroof.html
Very nice write up and thanks! Just got my 01 M3 and the sunshade is busted... this will help a lot in the repair.
Jump to top Red Rider is offline   Reply With Quote
Old Tue, Feb-13-2018, 08:08:34 PM   #27
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
This, headroom, and weight are the reasons why sunroof delete was my only required option.
WTS - OE CSL Trunk, Mint Condition, Uninstalled and with Hardware - $1150
911 Journal/Build Thread
Discussing sunroof fix in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
